You want CDMA/EvDo and Automatic but I'm pretty sure these settings don't change anything. These settings are locked in the radio chipset and the only way to actually change them is to use a program called QPST to edit the radio configuration.
If you notice if you try to change CDMA Network Preference it doesn't actually select and it always shows CDMA/EvDo on the menu. And system select would change between Home network and Roaming but since Virgin Mobile doesn't allow or support roaming so this setting is locked to home and can't be changed.
The M must have roaming enabled in the radio config. If you use QPST to view the v's radio config roaming is set to home only. I don't think the rom has the ability to override this but I'm not 100%
