mojosodope
Thank you
Yup, Tasker can do most everything.
However it can't make the proximity sensor do anything when the screen is off. I don't know if it's the same with flipping the phone, but I suspect that it is. Any profile based on orientation or proximity need screen on to trigger or exit.
Wifi only at home need task wifi toggle (triggered by position if you only use wifi at home - NOT GPS as that will drain your battery very fast) and wifi set on, another profile home to connect to your wifi SSID when detected by profile one.
Keep looking in the Tasker wiki pages for inspiration.
It takes more time to set up than most apps, but that is because it is so versatile and powerful. The Tasker Wiki has some profiles that you can use set up some on your phone, that is what I did when I first got the app. Now I always make my own, in fact just this morning I cleaned mine up and optimized some of my earlier profiles.
You definitely do not need to know any programming languages. If you just take a little bit of time to learn how to use the app you will be making very useful profiles in no time and the app will be well worth the money.
Hi All,
Does anybody know if its possible to put a tasker in the Status Bar, I can get the logo to appear, but what it to run when selected from the drop down?
Hope this makes sense?
Thanks
Binary
For incoming calls, you can set a profile, and use "Incoming Call" as state, and Tasker, Profile Status ReadSMS = off. Exit task: Tasker, Profile Status ReadSMS = on.
Or else you can set a profile using state "Incoming Call" to create a variable, and then use it in the "IF" condition on the original profile. i.e. "IF %INCCALL isn't set". Clear the variable on exit.
It should work, I did not try though.
For outbound calls, or probably both in and out, you can use App selection instead to disable ReadSMS when using dialer or phone apk.
If something needs explaing, please say so, or if something needs to be elaborated, please also do tell.Is there any way I can set Tasker to do the below:
on button press,
highlight screen text and copy it to the clipboard?
I just installed tasker today, but I am lining out the ideas for what I want. The trick for me right now appears to be figuring out the right set of conditional triggers for each situation I am looking for.
There are a few places where I stick my phone in a locker while I am in the building (the gym, and one of my work offices) so I am working out a scheme so the phone knows its in the locker
(loc>gym>screen off>) ???
so the phone will go silent, turn off Bluetooth, and reply to SMS with an away message.
For the office version, I may try tweaking it to forward a copy of the SMS to my email.
Next I'll have to figure a way for it to realize when I am in my car an turn on bluetooth only then, but I haven't come up with anything yet. I don't dock (Ford SYNC FTW!) in the car, and I come in and out of the office at irregular times, so neither docking or time will do it for me.
I can only help a little, but every bit counts, right?
Wifi toggle is what allows Tasker to turn wifi on and off during the periodic scans for your home wifi. Without the toggle, it will won't be able to scan if wifi is off. As you have wifi on all day, it won't apply for you, as I understand things.
I don't think that your monitor settings will apply for wifi, because you have wifi on all day long.
I would lower the threshold of the wifi signal strength even more, to 4 or something like that, to make absolutely certain it isn't that.
Do you have an exit task? If so, try inserting a wait task (like 10 sec) before terminating the profile. That might keep Tasker from deactivating the profile if signal dips momentarily.
Okay. So far so good. Thank You. I know understand, that the offscreen settings is irrelevant, when Wifi is on all the time and I now know the function og Toggle Wifi. Logicical enough. I've tried changing some settings in my router (dynamic channel to static channel and only n network devices). Also rebooted the phone, to be sure, that nothing is blocking the new settings. I'll keep an eye out for any miss behaviour.
I understand Your proposal to insert the wait, but it worked fine before the update. If I still have problems, I will try the Wait command in my exit task, but I can't see that it has to be the solution.
New question: How does the priorities function for profiles work. Fx. I've set my Near Wifi Home profile to priority 10, because I want to have it deactivate, as soon as I'm out of range, so that Bluetooth activates. I'm not that far from my car, so at the short distance, it has to fire off pretty quickly.
How many task can be set to a specific priority set? Can several profiles fx have priority 10?
As I haven't really used priorities, I am not able to tell you from personal experience.
The guides for Tasker state that priorities only apply if you have conflicting simultaneous profiles. It will not fire up a new profile faster if the priority is set high. It will only make the profile with the highest priority take precedent over the others if two or more profiles conflict.
Hmm, I'm still experiencing same problem. I had my phone in standby with screen off. The profile switch to off (could hear it because I've set a sound to play when it goes on and off). It didn't go on again for a while (5-10 min.). So I turned on the screen (profile was still off). I looked in the profile, and the Wifi Near state context. Did a search via the hour glass, for networks (because You also can see the network strength here), and my network strength was 9. As soon as I closed Tasker again the profile turns on again. Something is deffinetly wrong. The activation signal was set to 8. Man it's annoying. Hope anyone has a guess to what it can be, weather it's a phone setting or something else.
My problem with my ReadSMS is it just talks over my Pandora at the same volume so I can't hear either. I don't think there is a way to pause pandora/lower the volume. Is there?
I've tried putting it on another media channel besides "media" but my bluetooth player only uses that stream. How does Navigation lower the volume and speak directions while they are both using the media stream? Any help?
The Media controls I think only really work with Youtube and Google (Play) Music
Okay, now I've tried to set the activation signal strenth to 4. Still the same.
Strange!
I read about a possible solution to weird profile behaviour after updating here on AF in a Tasker thread. Can't recall if it was for OS or Tasker update.
If I remember correctly, you should import the backup you made before the update. Make a new backup of the profiles after having updated. Uninstall Tasker and then reinstall it, and reimport the backup again.
For whatever reason, that seemed to work. I am not certain that I remember it correctly, or that it will help you in any way. Try searching for it in the forums...
Wow, that was cumbersome. Okay. I will try that. Thankz.
