Wierd.
I really don't know what to do next. Perhaps one of the big guns around here could impart some of their wisdom..?
As a first task put Task > Wait for a specified period of time, and then the actual tasks.Hello, I'm a newbie....alot of cool information here.
Questions:
1. How do you make a task take place after a specified amount of time following profile conditions being met?
Depends on what you want those profiles to do. Do you want them to run one after the other from start to finish, or start up one after the other and then run all together?2. In a related question, how do you instigate more than one task to take place sequentially (as opposed to at the same time) after profile conditions are met?
Thanks in advance.![]()
), so it is imperative that this connection doesn't remain open all the time.Hello Tasker maniacs
I am as amazed as I could be by Tasker. It's the only app I have purchased and I would gladly pay double the price because it's totally worth it. I created some Profiles to use both with my ZTE Blade smartphone and ASUS Transformer TF101 tablet (both rooted). The profiles work great. Thanks to everyone in here for their efforts and help (just reading the thread was a great eye-opener).
I have a problem and I don't know were to start from. Since my tablet doesn't accept a SIM card, whenever I'm away from WiFi hotspots or home, I decided to tether my phone and use it's data connection as a WiFi hotspot for the tablet. The phone has a setting that makes the WiFi turn off when the screen turns off (that's for preservation of battery). The problem is that, when this happens, the WiFi signal providing Internet to the tablet gets lost. Furthermore, when I turn the phone's screen on again, I have to restart both devices in order to continue tethering, because otherwise tethering just doesn't accept to function at all.
My data connection plan is charged by my carrier via data volume, counting download+upload volume (500MB for 5 euros...), so it is imperative that this connection doesn't remain open all the time.
What I am looking for is two Profiles
One will be run in the phone and do the following:
- Create a button in the phone's home screen (lets call it "TE2TRA") to toggle tethering on/off. When pressed, this should also turn the phone's data connection on.
- When this button is pressed, it should also:
- either disable the turn-off-screen-after-x-minutes function (so that WiFi doesn't get disabled) therefore keeping the tethering active (but this would "cost" me battery from the screen being turned on for as long as I am using the Internet connection)
- or allow the screen to turn off, but keeping the WiFi (and therefore the tethering) active for the tablet to use (which, battery-wise is much better of an option)
- Restore everything to its previous state when the TE2TRA button is pressed again. Also, turn the phone's data connection off.
That's from the phone's side.
From the tablet's side, I want to create a Profile that will do the following:
- Use the "Say" command to inform me that "Tethering has started" when the tablet successfully connects to the phone's access point.
- When no data is received via the tethering connection for x minutes, again use the "Say" command with a message saying "If you won't be accessing the Internet anymore, stop making your carrier rich and turn tethering off in your phone".
Any ideas? Has anyone done something similar to share?
How would you implement this?
TIA
Hi guys, great ideas over here, now I got a bit of a problem setting one profile.
What I want to do is to make tasker launch a specific app when I run another app, and when I end this app make it kill the first one.
First I made a profile called TRANSPARENT. When I run SMS/MMS app it will run also an app called TRANSPARENT SCREEN and return to SMS/MMS to type. Obviously this causes a loop since returning to SMS/MMS will launch again TRANSPARENT SCREEN, so I included a variable that gets set after TRANSP... runs, this way the task will only run when this variable isn't set.
Now, the problem is how to clear that variable when I exit SMS/MMS. I tried creating an exit task that clears the variable, but the problem is that when SMS/MMS launches TRANSP... it is also exiting, so the exit state becames true and the variable gets cleared and I got the loop again
What I need is that when I exit SMS/MMS, TRANSP... gets killed since I only need this app running when SMS/MMS is running too.
any ideas?
For those interested....I know many of you wish Tasker would recognize gestures/orientation/light levels while the phone's screen is NOT on. I have a workaround...you must have an OLED screen for this to be beneficial though. Just use the 'Screen Filter' app. It already has Tasker integration in it. With the screen filter app, you can dim your screen down to 2% (thats as low as the dev lets you go...but its basically black). So, I just set my screen display to never timeout and then dim down my phone's screen all the way with the filter app. Now all your sensors will work in Tasker, but the phone screen appears to be off. Also, OLED displays have no backlight. Dimming the colors down actually makes the screen display light up less...thus conserving battery. Since the filter app dims the screen to virtually black...there isn't really ANY battery drain due to the screen being "on". LCD displays have a backlight so this trick WILL NOT conserve battery and is not recommended.
surely though if your setting your phone to never timeout, then its not locking the phone at all right?
Anyone know of a way to put the DATE on the Status/Notification Bar so that it is always visible (like the Time) using Tasker?
I find myself pulling down the status/notification bar everyday to see what the date is and if it was always on top, next to the time, would make it better for me.
Thanks![]()
Hello Tasker Brain Trust!
I have a problem I need help with please. After the last Tasker update or so, I lost the NEW option of separating my tasker profiles into different TABS. I had 1 tab set up of people to Text saying Happy Birthday on their respective Birthdays.
Since the last update, the extra TABS are gone, and some of my profiles are NOT SHOWING UP now. On top of that, I text somebody Happy Birthday this morning, and I don't see that profile anywhere in Tasker...it's like they are hidden/un-accessable.
Any help appreciated![]()
There is a *very* faint down arrow in the top-center of the screen. Below "Tasks" and "Scenes". Slide that down to get back the tabs.
