Root What to do now??
jake.hybrid
Member
Well, I'm on .595, my quadrant score is about 1850... I am Overclocked and on ULV at 1.3 Ghz, I'm not sure if that is very good. I was getting about 2000 on Apex 2.0b previously. My method of going to .595 deodexed was SBF>.588 3 part update>straight to .595.
So I have three questions:
1. Is that a good quadrant score for GB .595??
2. Did I approach .595 the best/correct way??
3. Finally, what's the deal with the OTA and everyone freaking out? I want the OTA, but I will wait for root.
1.yes
2. if ur up and running, yes.
3. we have no lives.
I would dial back the overclock a little...im getting scores like that at stock clock speeds....sounds like you might be encountering some lag spikes occasionally during the test causing your score to suffer...I've scored in the 1900's @ 1.0ghz before...1.15 usually puts me 2000+
This was just now running completely stock clock speeds (300, 600, 800, 1000mhz) and undervolted using QuickClock
Oh wow, well I only scored like 1500 on stock. :/
Also, I figured bigger was better... :p
Edit: 1734 on 1.2Ghz... :/ on ULV
1911 on 1.2 Ghz on Low Voltage. :)
how can you stand that clock in the notification bar......lol
rooted/deodexed .595. my route was dxgbrooted, .588 rooted/deoxed (1 shot), .0591, and .595, oc'd@1.25Ghz.
Question tho, should we have the #1 or #2 kernel and whats the advantage if either?
