Root What's Wrong With This ROM?
D
Deleted User
Guest
I recently installed the "MUIU" ROM, and it keeps giving me a message saying "The process android.process.acore has stopped unexpectedly. Please try again.". I go to report OR force close, however it just keeps appearing. What's the problem?
No, I didn't do a full wipe, I didn't think that was necessary. Also, the reason I flashed this was to get a ROM (Unlike GingerBread) with a self-timer on the camera. However, although it keeps giving me that error message, it has not erased ANY of my stuff (I assume because I didn't wipe it), and despite being like that for a whole day, the buttons that didn't work before, are actually currently working.
OK great but before you do anything else, please read all the faq's in teh "All about rooting" sticky thread.
how many times have we said to him read up on the guides
im not being harsh but im not helping this dude any more.
not wiping when changing rom ?
pft
Everyone on this site is only trying to help you, by not doing what is being advised you are only annoying those trying to help and also by not wiping you are also risking more complications and therefore requesting more help from the very generous people here, do everyone a favour and read the faq and learn from everyone's advice and not by making mistakes. Everyone will help you if you help yourself.
Okay, first of all I would just like to confirm that I am in NO way at all doing ANY of this on purpose. I will admit I posess a great amount of stupidity, that some of you have experienced in the past. I am truly sorry for wasting your time. I will now FULLY listen to you and no longer show any stupidity. I will start off by reading the FAQ... What after that?
Initiall just start off with the "rooting FAQ" and read all of that, just to get a bit more of an idea.
Let me know when you've finished ;)
I just finished reading it... At first it felt like a waste of time, but then I started reading stuff I didn't actually know about. What now?
Whats your knowledge like on the memory options available? If not great, the ROOT memory FAQ is also a good read.
I was actually going to ask you something similar to that topic... Is there another version of the MUIU ROM that like the custom GingerBread one lets you move all applications to the SD card?
Dunno much about miui but miui xj may be the one to go for. It's also gingerbread. Think it has dark tremor a2sd but would need g
To check the thread
Which version are you using? As SUroot mentioned above MIUI XJ is the best rom around at the moment and it has Dark Tremor A2SD on it so you get more internal space on your phone..You just simply activate it by typing couple of command lines..
Okay, so after I get MIUI XJ, I have to to?
flash the rom, reboot and download terminal emulator from the market, run it and type:
su
a2sd cachesd
this will move the dalvik cache to sd ext (i hope you have created an ext partition?)
if not you will need to make a bootable copy of gparted (its in my sig) run it and format your sd card creating a fat32 and ext partition.
then you will be good to go
dont forget to copy the contents of your sd before formatting it, then copy back after formatting.
Can I just ask a question though?... Why is this "MIUI" ROM the only ROM keeping my phone working? To be honest the only reason I'm keeping it is for a self-timer, because it is really just making my phone look like an iPhone... Are there any other Android ROMS with self-timer?
Don't know about self-timers - I did try the camera app from XJ in Oxygen the other day, but no luck (I have an earlier Miui camera working with Oxygen, but that doesn't have a self-timer).
Also don't know why your buttons work with this one but not others - your button problem isn't something I've come across before.
As for the iPhone look, you could presumably put a 3rd party launcher on top of Miui and hide that?
