Root which ROM to flash?
I am wondering this same thing. I kind of want to get into building a theme, so i am trying to find a rom I love and stick with it. But so many new roms keep coming out every day.
Virus' rom always seems to get good reviews and both his and MikG's roms seem to be the base for a lot of other guys out there, so that should tell me something I guess. I am liking kingsrom alliance and shifted evolution which i believe are both based of one or both of these roms, can't remember.
I love sense 3.0 stuff, but I am also hearing CM7 can get some crazy battery life. I've DL'd it, but haven't tried it yet, pretty sure I have tried all the rest except for MikG, I usually seem to go for one of the roms that uses his base. But I might have to try 2.0
Help me decide, lol
Help me decide, lol
what deciding is there to do. try them all. come on feed the addiction. you know you want. come join us flashaholics and just flash away.:D
i really love cm7/tiamat combo best battery life by far out of anything i tried in the past. and cm7 is a great rom. aosp roms do take more tweaking and fixing, but once you get past that then you are in like butter.
however, i also really like the kingdom rom right now. so much so that im willing to wait for a custom kernel to come out and have a so so battery life. i need try out the latest mikg and the latest king roms that just came out. too many to flash and with too little time to do it. but i have to feed my addiction.:D
I got VirusROMs Kingdom to work just fine on my phone recently. I really love the ROM and everything works. At this point, I'm done flashing the Evo. I get the 3D later this week and this one will be going to the wife. It isn't so technical that she can't use it (speaking of the ROM), so this is a perfect scenario.
Oh trust me I am already a flashaholic. Its to the point that I often flash a new rom every day. I am probably not even giving each of them enough time.
I know I would get bored of the look of cm7 I think. I would probably have to use a different launcher and maybe beautiful widgets. I'm guessing all that might bring the battery life back in line with some of the other roms I am running now???
well with aosp roms, you do not have a battery hog called sense. so a launcher like luancher pro(which i love) should not be an issue. plus there are a ton of themes out there for cm7. plus launcher pro is very customizable and you can always make it look different if you want. with cm7 and tiamat kernel i get anywhere to 20-35 hours of light to moderate use.
I want to make a star wars theme for my phone. Thats why I am trying to pick 1 rom. If I went with cm7 I would likely use launcher pro or maybe go launcher, I hear they are both good.
What part of sense drains the battery? Cause like I said, I really enjoy the look of sense and will likely buy beautiful widgets if I go with cm7, just to get some of that look back. But will that drain my battery just like using sense would?
well actually sense is not really a battery drain but more like a resource drain to me at least. it is why the kingdom rom is so huge with sense 3.0.
with my cm7/tiamat combo i use beautiful widgets and launcher pro with no drop in battery life. just to give you some ideas this is what granite has done: http://androidforums.com/evo-4g-all-things-root/322488-super-mario-bros-theme.html. you can always post a question on theming there. i know he was working on some theme on cm7.
Yeah I have been following granites thread. Mario/Nintendo was a 2nd theme idea I had. But after seeing some of the notification bar icons in this theme [Theme]Star Wars for LibertyX 1.0 - xda-developers
I really want to do something like that. Launcher pro doesn't give access to those right? For that kind of stuff I am guessing you need to edit the framework.
Maybe I need to look for some cm7 themes or setups people use.
yeah looks like frame work stuff and not launcher pro. i would pm granite or post on his thread and see if the notification bar can be pulled out and re-assembled to your theme.
Okay, gonna install cm7. Where do I get that kernel(tiamat) and how do I flash it? Before or after I flash the rom, and is it done the same way as the rom? Anything else I need to know?
You can download it from here: Tiamat AOSP Kernels
I have had the best battery with 3.3.8 but some have good luck with the 4.x series also.
Flash your rom, reboot, then reboot to recovery. Wipe Davlik-cache and cache, then flash the kernel and reboot. CM7 has governor settings in CM Settings. I think Tiamat defaults to Smartass which is my preference also.
ok with cm7 you need a few things:
1.you need the latest gapps file http://androidforums.com/evo-4g-all-things-root/284413-roms-kernels-download-page.html
2.you should try the tiamat kernel http://androidforums.com/evo-4g-all-things-root/284413-roms-kernels-download-page.html
3.you may nned to flash the gps fix xda-developers - View Single Post - [INFO/FAQ] Unofficial Cyanogen Mod Nightly (6/6 - I'm taking my ball and going home!)
4.you may need want the sprint vvm How-To Reinstall Your Sprint Visual VM under CM7!!! - xda-developers
told you there are a few fixes and tweeks. if you need help you know where to go.
Hmmm. Do I want th regular or the sbc one?
sbc all the way!!!!!!!!!!!!!!
I tried to find some info on this online while waiting for your reply and it seems like a lot of people are against sbc saying it can kill your battery.
I didn't have time to set up CM7 last night so I flashed virus rom again today. Battery life sucked for some reason.
I am starting to really like kingsrom alliance. He is updating very quickly. First sense 2.1/3.0 rom that I know of with working netflix
well there are a lot of pros and cons with sbc. i think that the pros far out weighs the cons in my opinion. i was on cm7/tiamat for a good 4 months with sbc and my phone never exploded. and my battery life was the best. checkout this thread:http://androidforums.com/evo-4g-all-things-root/319636-sbc-no-sbc-kernel.html. novoxx77 post#18 explains it better then i can. hope that convinces you to at least try it.
Thanks. Sure I will try sbc assuming I can make myself take the time to customize CM7
