D
Deleted User
Guest
I have a rooted HTC evo and just upgraded to Gingerbread through the instructions on this forum. Thank you everybody for the details.
Overall, it has worked wonderfully and I am very happy. However, I have noticed one problem that is causing me major headaches.
Before upgrading, I could easily connect to wifi at home and work. However, after upgrading to Gingerbread on Sunday and then updating the radios per the additional instructions that many had recommended, I am still able to access my wifi at home (Apple), but not my work (Linksys E3000).
When it tries to login at work, it just shows "connecting" but then never connects. I tried to forget the connection and then re-enter it, but it did not work either. Even tried to turn off WPA security and SSID hiding, but it still wouldn't connect. Of note, I have no MAC restrictions set.
I didn't make any other changes, which makes me think it was either the upgrade to Gingerbread or the radios. Has anybody else seen this and does anybody else know the solution?
Thanks,
Sailguy
Thanks,
Sailguy
