I'm sure it's possible to port miui over to run as a 2ndinit. And judging by the rough road LG has given us, 2ndinit ROMs may be the next level of development for new phones, I'm sure since I saw a potential LG mole running around the forum. Maybe the next phone will somehow block 2ndinit method....
It's called 2ndinit. The kernel is hijacked and loads CM10 instead, running it on top of stock firmware LOL... Only hitch is that the same stock kernel has to be used because of bootloader lock, so no overclock and such. Google 2nd-init, it's a great read![]()
Well, djrbliss has told me that LG does NOT use qfuses to determine unlock state.
Hey man im a spirit user but ive been following this tread really closer and i gotta say i admire the effort you are putting on unlocking the bootloader
Nope, not for unlocking the bootloader. I am now looking for where the rumored flag in the misc partition is located, with the hope that it works. If someone can figure out the physical location of the misc partition, it would be very helpful.
ls -l /dev/block/platform/msm_sdcc.1/by-name
Anyone know what our encrypt partition is? It is full of just "FF" bytes.
Nope, we have a seperate trustzone partition that is named TZ.
Sounds like theres an encrypted image on the partition, hence the FF bytes which would signify a color code of some sort. If i were to take a guess its the key encrypted in a png or gif img.
Err, hex physical location. Such as 0x706000
Partition: MODEM at 0x000000800000
Partition: SBL1 at 0x000004800000
Partition: SBL2 at 0x000004880000
Partition: SBL3 at 0x000004900000
Partition: ABOOT at 0x000004A00000
Partition: RPM at 0x000004A80000
Partition: TZ at 0x000006000000
Partition: PAD at 0x000006080000
Partition: MODEMST1 at 0x000006080400
Partition: MODEMST2 at 0x000006380400
Partition: SNS at 0x000006800000
Partition: MISC at 0x000007000000
Partition: SYSTEM at 0x000008000000
Partition: USERDATA at 0x000048000000
Partition: PERSIST at 0x0001B3C00000
Partition: CACHE at 0x0001B4400000
Partition: TOMBSTONES at 0x0001C5000000
Partition: RECOVERY at 0x0001C9800000
Partition: FSG at 0x0001CA400000
Partition: SSD at 0x0001CA700000
Partition: DRM at 0x0001CA800000
Partition: FOTA at 0x0001CB000000
Partition: MPT at 0x0001CD000000
Partition: TZBAK at 0x0001CF000000
Partition: RPMBAK at 0x0001CF080000
Partition: ENCRYPT at 0x0001CF100000
Partition: RESERVED at 0x0001CF800000
Partition: GROW at 0x0001D0800000
Maybe this might be helpful, or maybe not.
