I have flashed the latest and still have no SD card access, am i missing something. Any help would be appreciated.
Whoa all the way to beta v 6 now.
if you flashed the v6 beta then it should be fixed. what did you wipe? what recovery are you on? do you have your card partitioned. try wiping dalvik cache and cache and reboot. if not maybe try and wipe and reflash the rom.
I rooted using Revolutionary and i wiped all data and cache. My SD card is not partitioned does it matter?
So I have a quick question...I kind of want to try this out at some point but I am not sure I want to partition my sd card because I am weird like that. I have been meaning to get another (perhaps bigger) sd card would I be able to partition that one, flash the ROM off of there and see if I like it then switch cards and nandroid back at my whim?
Would that be a way to save my current card as is and still be able to use this ROM?
I was wondering if my 32gb class 4 would be ok since I don't use many apps. The one app I do use a lot is Handcent. I do play a couple games but not very often.I really want to try this rom and I see everyone say get a class 6 or higher card. I don't have the cash flow at the moment or for the foreseeable future to get a new card.I was wondering if my 32gb class 4 would be ok since I don't use many apps. The one app I do use a lot is Handcent. I do play a couple games but not very often.
class 4 might work ok for you. it is just that by moving the apps to the card your apps will need the speed in order to perform well. now most everyday apps should be fine on lower speed cards but games and other more intensive apps will perform not as smoothly. try your card you have now and see. it is pretty easy to partition it and just as easy to undo it.
Sweet I'll do this tomorrow. So Handcent should work fine on the card then? I was thinking about selling my sd card to get a 16gb c10 card. I hardly use 5gb of 32gb! Any takers for a 32gb Class 4 sd card? Not sure of the make but I took it out of my HTC Thunderbolt before I traded it for my Evo.
Another quick question for this rom. Does it have the hacked hotspot or do I need to get the market app? I ask cause I use my Evo for internet service. Thanks!!
that is a good question. i have tried this rom but i do not remember if it had it or not.
but here is the hacked hotspot if you would like to try it:
[HotSpot Hack] Enable Hotspot on Gingerbread - xda-developers
Well I'm proud to announce that I got this up and running, and it seems that the hotspot is hacked since I'm on my laptop typing this. Can anyone confirm this since I can't be completely sure my hotspot subscription has been deactivated? Sucks there is no 4g yet! So far this is a sweet looking Sense rom!
I don't believe that 4G will ever work on this rom, just fyi![]()
I really like this rom too but i need my 4G!I don't believe that 4G will ever work on this rom, just fyi![]()
Weak!!!I really like this rom too but i need my 4G!
king did mention that he would "never say never" in his thread. so it might still be a possiblility.
If they get 4G running on this i'll get this again!
