Root [wip] what can be flashed through recovery
Now would you know if its safe to install if I already have adrenaline injector?
Sorry for the lateness. New job, lost time. No, it's normally a bad idea to mix and match speed tweaks. both the adrenaline injector and the cosmo tweaks use build.prop tweaks as a default, doubles in your build.prop can lead to system instability. The tweaks we're using are hardware manipulators and can run the risk of harming your device.
I've never had trouble changing the lock screen background before, but after installing the LTE2 2nd-init Recovery ver 1.1... I can't change it from the default wallpaper gallery. Anyone able to confirm/deny this?
I updated to fw F from the torrent using the usual methods. So I can only deduct this issue is from the 2nd-init.
I also installed google now, emoji, ac!d, walkman, but these have worked fine in the past without this issue.
I clicked on the link that's in the OP but I don't see where to download the 4.2 keyboard on that post
I recently installed adrenaline injector n want to remove the internal external switcher that it installed. Is it possible?
So what is i install all of the packages then can i clear the cache and dalvnik or do i have to wipe it after each install?
So can someone answer that has tried it, as soon as possible, is it safe and worth it to flash the Bravia 2? Want to do it, but do not want to deal with a factory reset or anything like that...
EDIT:
OK, so I just flashed it, on CM10... Anyone else who does, do not be alarmed if you see a blue screen during the CM bootup animation, and then the animation freezes... It will eventually finish booting up and run fine.
Nice guide
EDIT:
Nice guide
That happens to me anyways, has nothing to do with bravia 2
and for those who want to know whats being flashed... its just a gps.conf:
Code:
NTP_SERVER=1.pool.ntp.org
NTP_SERVER=0.europe.pool.ntp.org
NTP_SERVER=1.asia.pool.ntp.org
NTP_SERVER=2.north-america.pool.ntp.org
AGPS=http://xtra3.gpsonextra.net/xtra.bin
XTRA_SERVER_1=http://xtra3.gpsonextra.net/xtra.bin
XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin
XTRA_SERVER_3=http://xtra4.gpsonextra.net/xtra.bin
DEFAULT_AGPS_ENABLE=TRUE
DEFAULT_USER_PLANE=TRUE
DEFAULT_SSL_ENABLE=FALSE
INTERMEDIATE_POS=1
QOS_ACCURACY=50
QOS_TIME_OUT_AGPS=95
QOS_TIME_OUT_STANDALONE=80
QosHorizontalThreshold=1000
QosVerticalThreshold=500
AssistMethodType=1
AgpsUse=1
AgpsServerType=1
AgpsServerIp=3232235555
SUPL_HOST=supl.google.com
SUPL_PORT=7276
SUPL_SECURE_PORT=7275
SUPL_NO_SECURE_PORT=3425
SUPL_TLS_HOST=FQDN
SUPL_TLS_CERT=/etc/SuplRootCert
ACCURACY_THRES=3000
CURRENT_CARRIER=common
PHONE_TYPE=UMTS
Disregard that last question but can I install the supremacy trilogy along with the adrenaline injector?
No, you never mix hardware acceleration tweaks. Both tweak packs use build.prop mods to do the job, having doubles of a build.prop mod in your collection is just asking for trouble
(edit) been spending alot of time playing with my gtab 2. Found a couple of mods that would make nice additions, I'll add them in when I'm not so backed up.
I was wondering if this in-call volume fix (which is for the Galaxy S2) that makes the calls louder could potentially be used for this phone, does anyone know?
I am a newb when it comes to this - but maybe we can take parts from it and see if it works?
EDIT: Btw - I tried the GPS fix zip before and it didn't work. I tried 2 different ones and they both gave me errors. No brick though.
EDIT2: (Gotta love edits) - I remember also (before I made the account) I had trouble installing the 4.2 keyboard from the .apk - And the link in the first post is dead so I used this one: http://ftp.qbking77.com/Files/android42_keyboard_signed.zip
