.dalvik would require a reboot, i imagine it just wipes cache part, it will rebuild itself as you go, just a cache. I use one sometimes called cache cleaner ng or something like that. It was on a 2,1 rom and i stole it. Honestly i almost always do it in recovery, i only started using the cache cleaner on the 3.0 sense rom because rebooting was always a risk.
and (from what it sounds like) a half hour process too for your rom that is LoL
kinda. those cleaner apps(i assume youre referring to the caulkins wipe all zip file) do more than just wiping the cache. I havent seen any (but i also havent looked) cleaner apks in the market, but if you wipe certain parts in the system, the system needs to rebuild them (i.e. the dalvik) and thats usually done during the initial boot after the wipe is performed, so it stands to reason that any cleaner apk that doesnt require a reboot would be ill effective.
