In using global re, maybe nordic is better.....
My global is smooth.
Is this really true about the screen brightness? For God's sake, why can't they just leave well alone? What's wrong with letting us choose for ourselves? I don't like my screen to be below 100%!
I don't think I want this update anymore.
does anyone know how to open the secret menu from the home screen with 2.1? last time we can open it after pressing menu back back.......and so on. i tried it a lot of time but i cant open it.
My issues so far:
MMS don't work, not sure if it's the phone or Rogers (the carrier).
I imported my contacts and it worked fine, after restarting the phone, now there's one contact per telephone number/e-mail address (for example, I had Joe Blow 555-1234 joe.blow@sonyericsson.com under one contact, now there's two "Joe Blow" one for the telephone number, one for the e-mail address...).
I think I'm going back to 1.6 X10a very soon...
I'm from Quebec too. I done the update too and it's working fine for me. Did you add your APN settings? The auto configuration doesn't work. Means that you might be able to browse on the Internet, but not update applications or in that case use MMS. Here is a link on what to setup. For the contacts, it looks like it is using your SIMcard contacts. I don't think you can use more than one number per entry in that type of contacts. Did you have your contacts on Google? That's what worked best for me...Just updated, is it me or does the phone feel abit well laggy?
Hey BingoI'm from Quebec too. I done the update too and it's working fine for me. Did you add your APN settings? The auto configuration doesn't work. Means that you might be able to browse on the Internet, but not update applications or in that case use MMS. Here is a link on what to setup. For the contacts, it looks like it is using your SIMcard contacts. I don't think you can use more than one number per entry in that type of contacts. Did you have your contacts on Google? That's what worked best for me...
Any reason for this?It is laggy at first but it stops being laggy after a while![]()
..I often used the sound button, anyone knows a good widget that can put it in vibrate without having to go in the menus?
Thanks. Tried all of these so hopefully will sort itself soon. Off to bed now, angry.
Audio Guru
Then add widget and pick Audio Guru (Mode). You get a small touch bar of 3 items Normal/Vibrate/Silent.
You can change the size of it to but I opt for 2x1 altough 3x1 is good as well.
....or
Curvefish apps
SilentMode OnOff CurveFish
It does vibrate too. Check out website, some good stuff.
One last thing, did you root your phone? Maybe this could cause some issues...
My market downloads just stick at "starting download" since 2.1 upgrade and Titanium backup restore.
I've tried everything:-
- deleting google mail account
- taking out battery and sim
- emptying caches and data
- 3g and wireless
Any other tips before I smash my phone up?
Yeah I rooted and my contacts are ok. I know there is a "group" button beside the search bar in the address book, maybe there are settings regarding your issue?
