Help X10 2.1 Update - Issues/Problems
I hear what you're saying but the fact remains: They have needlessly reduced the screen brightness. One doesn't need to sample 2.1 to forge an opinion on this.
Yawn... I think we've done this one to death now! *logs off*
those videos are done in a poorly lit environment to enhance the visibility of the screen
I stand by my remarks about the brightness it's no more than 60% of what 100% was on the 1.6 version and YES I can see a difference! and a lot of the time i like to use full brightness if i'm outside
My screen is plenty bright. Maybe not 100% of 1.6 but not much less. I'd say 90%. I wouldn't want it any brighter. But It sucks that the auto is gone. I always used that. Maybe it drained the battery.
I would like to retire this issue once and for all. The screen brightness overall in 2.1 is better than in 1.6 there I said it, marginally better in brightness and way better in colour. What I did was this, both my wife and I have X10, mine on 2.1 Nordic and hers still on 1.6. I went to Android Market screen (lots of whites) and compared them side by side. It was no contest 2.1 was a tad brighter and the whites were way whiter, in fact the whites in 1.6 looked like antique yellow in comparison. Both phones were set at their respective 100%. The wife and kids all agreed that my 2.1 screen colour and brightness was better. At work the next day I compared my 2.1 to two different friends 1.6 and asked about a dozen peoples opinions. They all said the 2.1 phone looked way better. I will concede that the lack of an auto feature sucks for some although mine has been set at 100% since day 1, battery be damned!
So on a final note: Unless you can repeat what I have done and get different results can we please consider the subject closed. Thank You.:cool:
Im having a really weird problem. i use handcent sms for my messaging and turn off all notification of the stock sms. everytime i receive a text, i get the alert from handcent but then i also get some stupid icon in the status bar that says i have a new message. ive even tried clicking on the notification and it does nothing. anyone have any ideas bout whats goin on?? Its very annoying. the only way i can clear it from the status bar is to click the clear button.
I still can't get the market to update my apps. It just hangs at 'starting download'
I am in Oz, and I changed the semc version and product name to 1234-8465 to get the 2.1 update.
Should I change them back now to 1234-4764 to get the market working again ?
Anyone else having the same problem ?
Cheers
Edit: And I have tried this select Settings > Application Settings > Manage Applications > Market > "UNINSTALL UPDATES", but there is no Market listed in my applications ??
Quoting myself again, sorry !
I ended up having to reflash the world generic FW this morning, and surprise surprise, the Market worked again. Not sure but one of the files in "system..."said UK, and when I opened MAPS it offered saving to xxx.google.uk, and I couldn't signin to "TALK", it just kept hanging. I think I exhausted all the option for a Market -fuk-up fix.
Maybe something to do with hemispheres (COMPASS, MAGNET - etc ???)
I had no sooner finished re-installing my apps with Titanium when my receptionish called me about a package....
Got my HTC Desire HD today.
While on charge for about 3hrs I decided to turn on - temp root - TB backup, then moved onto some app installing.
Sorry to say, but from an out of the box phone it shits all over my X10 - 2.1, i gave my X10 to my 7yr old tonight to play angry birds, he loved it cause he had "Dad's work phone", even though he has 3 PSP's that also shit on it.
Good luck fella's. Mine's for sale. I have enjoyed the early 2.1 Nordic -> World Generic hack that sees me well ahead of most in OZ, but as I said, out of the box today, the HTC D HD with 2.2 is killa.
Now I have just gotta work out how to parse my login and google email addy to fitzysHTCDHD.....
Must set my fav to another forum (Spencer UK)
Cheers
Fitzy
typed almost flawlessly (except for spelling mistakes) with Internet pass-through.
But there is a solution! For some reason when you're stuck at "Starting Download" you need to open Google Talk (or just Talk in 2.1) and it will start downloading. If it still doesn't work, try logging out of Google Talk and logging back in, you might have to do this a few times before it works.
Tried that too but Talk wouldn't even open. It's all sorted now though, thanks.
Try turning it back on and sending yourself a message - do you get 3 notifications?
Have you got another mail program?
Since upgrading to 2.1 Inserty dosen't work as well as it did. I have made a few entries with phone numbers but when inserting the text into the SMS app the phone number isn't included so I have to add recipient. Anyone else with this problem? I use the original SMS app.
Have nobody else tried Inserty with 2.1?
hey guys..just updated mi phone from 1.6 to 2.1. now its showing this unknown icon in status bar...its look like a sim card with a round thing on top of it.... looks like same as sim toolkit icon in menu???
any suggestions why its there? and how i can get rid of it.
This could be an envelope with an @ symbol over it (New email)
or it could be a square with 2 round arrows on it (problem with sync or sign in)
The widget where in 1.6 you can turn on/off Wifi, Bluetooth, GPS and Sound (ringer, vibrate, off) has changed to Wifi, Bluetooth, GPS, Sync and Brightness.
I often used the sound button, anyone knows a good widget that can put it in vibrate without having to go in the menus?
Did you find a way to solve this? The sound/vibrate/silent button on the widget was one of my most used features in 1.6. I don't want to have to trawl through the menus each time I want to set my phone to silent and vibrate!
Re above widget called status switch will do the trick :)
I`m having the market problem since updating and can`t get into anything. Have tried all the usual tricks (the ones i can do on 2.1) and nothing.
Anything out for this issue on 2.1?
I use the side buttons... it's not perfect but it's faster than going through the menus.
I got my phone free with Orange for threatening to leave and they halved my line rental :)
As for the phone; it's awesome. Love everything about it. My friend has an iPhone 4 and I look at it like it's dated and chunky with a midget screen. The X10i is sleek, well made, exciting and full of Android excitement.
One of the best gadgets I've ever bought*
*I realise it was free
:D
The iphone might be chunky, but try sitting side by side with someone who's got one and go on the net.
Having told my mate how awesome and fast it was, we sat side by side, going on the net, ebay etc etc..............and i was so ashamed.
The x10 is pants.........slow and not full of android excitement!!!
The SEUS updated my X10i yesterday. Though (thankfully) I have not had many of the problems listed above to contend with, I have only one major query at the moment.
The phone-book appears to have lost the option from the menu button of 'display group'. It now appears you have to go through a list unchecking and rechecking boxes in a menu accessed from a button to the top left of the search input. Which is a pain.
Does anyone know if there is a quicker way to display a group of contacts, or even create a group on the phone? If not, are there any decent free phone-book apps that can be recommended?
It seems odd that such a useful function would be discontinued or made that much harder, but that's the nature of software updates, I suppose.
Thanks for helping me out.
PJG
Many thanks for this. Why one earth SE have two widgets for these controls is beyond me. Have to say I hate the way Status Switch cannot sit centrally on the screen, really bugs me, but that's me being picky!
I have another problem or should I say observation though - why have all my contacts now got two mobile numbers listed, both the same, but still, seems very odd? It's frustrating because when I go to call someone, it asks me which number I want to ring, even though they are the same number!
Is this anything to do with the Facebook syncing? How can I fix it?
Thanks
The 3G icon is changed. Now there's an H. What does H mean and is it the same as 3G?
Ya i have the same doubt as you . I'm really new to this phone as yesterday i just bought this x10i (upgraded under SE service centre)....
Pro
- i have try out the youtube video and it seems to be better than the 1.6 one
-I think the "HD video" is also improve
Con
-The brightness of the 2.1 is darker than 1.6 .
-I think the battery flat easily too
since upgrading to 2.1, when i get in the car and the phone connects to the parott car kit i get the same noise coming through the speakers like i have a text message...its just saying its connected as when i look at the phone...no text message!!.
Is there anyway to stop this as its loud when i start the car and it goes off...i have updated the car kits FW to the latest but still the same
Thanks
Since i updated to 2.1 i couldn`t download anything from the market, it just sat there as downloading.
Spent the last 24 hours trying and trying different things but nothing worked.
So, eventually did phone reset, set up another g.mail account and tried again. It worked, downloaded straight away.
phone reset again and tried with my old google account and nothing downloaded. Reset and back into new one and hit an issue giving me a result.
It won`t download anything already listed in my gmail download list. Anything new downloads fine, anything in the list just hangs.
Does anyone know how i can reset my download list either in my gmail account or in the phone. I`m thinking that this should solve the solution for me (and hopefully anyone else with this issue)
EDIT**** clearing the market cache and download manager worked. Now up and running. Old email account doesn`t work at all though. Never mind!
Thanks
You can "FORCE" the status switch widget to sit centrally if you use ADW Launcher as your homescreen instead of Sony's default
Ok im not sure whats goin on here its not a really big deal as theres other apps I can use :)
But for some reason since updating to 2.1 when I take a vid (namely HD) media scape wont show them as recent or even that I veiwed them.
