Chair o' bed bugs
The current trucking company I work for has about a dozen terminals located around the country, several of these are training centers. Because of over flow, several people got sent to a local motel until space at the terminal open up.
The people who stayed at the motel ended up bringing bed bugs back to the terminal. They ended up trashing all the mattresses, sheets and blankets, the dorm area was sealed up and the heat was blasted for several days.
From my understanding the company gave each person effect by the bed bug incident $200-$300 to replace clothes and other items
Because all clothing and any thing else that could be taken on a truck was scrapped
Everything accept phones and electronic stuff
I was lucky and wasn't there, I arrive about three weeks after the incident .
Help Android forums is convuluted.....
I totally understand what you're saying, but technically it already is on the homepage since the sidebar has all the links that the quick jump has. On mobile they each take one click to reveal the same links. So it's kind of redundant.
What's New should really be in the sidebar.
Yeah, that's kind of what I'm saying. There should be a "What's New" no matter where you go.
Unable to restore phone content from USB drive using Samsung Smart Switch
My old S8+ had been undergoing repetitive crashes whenever restarted. Due to what seemed to be a battery failure. In anticipation to the worst to come I backed up the content of my S8+ onto a USB stick and performed a factory reset with the hope that the battery problem would be resolved for good. To no avail. So I bought the new A70 and you know what happened next...
Quick Find & Removal of Images from SMS/MMS
That 'SMS & MMS Search and Delete' app looks pretty interesting but apparently it's not available in the Google Play Store so it requires one to download the apk and sideload it. Just an off-hand caveat as that's a minor security issue to consider. But yeah, it does seem odd that there doesn't appear to be even some equivalent in the Play Store.
https://apkpure.com/sms-mms-search-and-delete/com.sbits.smscleaner
But just add to the reply @Dannydet made, if you don't have a good backup solution in place you really should set one up now. Don't rely on your mobile device's internal storage, or even a microSD card, for any kind of long-term archiving.
An app like 'SMS Backup & Restore' will allow you to back up your text messages and phone call log, and make it easy to do a restore if necessary or transfer if migrating your data to another device.
https://play.google.com/store/apps/...SMSBackupRestore&hl=en_US&showAllReviews=true
The Google Photos app is a basic photo manager (like Gallery) but includes a backup & sync function, that will automatically backup your photo library into your online Google account.
https://play.google.com/store/apps/details?id=com.google.android.apps.photos&hl=en_US
Whenever you need to access your photos you can either use the app on your device or use a web browser by going to:
https://photos.google.com
and access them using the web interface. Or you don't need to use the Google Photos app as your photo manager, use whichever app you prefer, the important aspect being to have that backup function enabled.
Android pie update v40
I found a setting that will keep updates from automatically installing once it's downloaded. Its in Developer Options. If you don't have developer options turned on go to software information and tsp on Build Number 7 times. Then go to Developer options and scroll down to Automatic Software Updates. Turn off "Apply updates when system restarts". At least that will give you time to stop the update.
Why is locked screen notifications not working?
Hello guys!
I have an issue with locked screen notifications.
When my screen is unlocked i receive notifications with no issues but as soon as the screen is locked i don't receive any notifications or even hear a sound if i received any message from any app, for example WhatsApp is working fine when screen is unlocked but when it's locked i don't get any notifications.
Android system: Lollipop 5.1
Phone model: Philips Xenium V787
I've tried the following solutions but none of them worked out:
- Settings> Sound & notification> Notification> When device is locked> Checked "Show all notification content".
- Checked app notifications in phone settings.
- Advanced Wi-Fi> Keep Wi-Fi on during sleep> Checked "Always"
- Reset WhatsApp notifications.
- Reinstalling WhatsApp.
- Cleared partition cache from recovery mode.
What I've noticed is that Gmail notifications work fine, even when screen is locked i still hear a notifications sound whenever i receive an email but for the rest of the apps, i don't receive any notifications at all unless the screen is unlocked or the app is opened.
Would appreciate your suggestions to solve this issue.
Thanks in advance.
USB Detection problems
I cannot get my laptops usb to pick up and access my tablet - it charges it, that is all
Something I forgot to ask you: why do you want to connect via cable? There are other ways to connect that don't involve any physical equipment. Since charging is not your objective, you don't need a cable.
I use Airdroid, which is an excellent app that gives you complete access to your Android device from a computer. You might want to take a look and see if it would work for your objective.
Help Help! Samsung Galaxy A30-A305F/DS Bricked
I tried to root my phone using the method in the following link: https://forum.xda-developers.com/galaxy-a30/how-to/root-galaxy-a30-magisk-canary-relaese-t3936481 and at first it worked. Then a few minutes later when checking for root, my phone was suddenly no longer rooted.
I then tried to open Magisk Canary, but that caused my phone to keep rebooting.
I went into recovery mode, formatted and then tried to root again.
Now my phone is stuck in download mode (I cannot restart, if I try it just goes back) and has a message saying... Downloading... Do not turn off target. There is a message in red saying Error Validating footer. (6).
Does anybody know how to fix this?
Help [SM-G9750] [SOFTWARE BUG] Video playback being throttled or not utilizing CPU / GPU?
Try this clip for example, it's 4K HDR encoded in H.265 / HEVC, I don't know if that makes a difference:
http://www.mediafire.com/file/m83ftn7n8d8le2s/Plane_Crash_Scene.mp4/file
Stutters in the default video player app for me. One thing to note is that it's smooth in portrait mode, but the moment you rotate into landscape fullscreen, it starts dropping frames. Now, turn on the screen recorder from within game tools and the stutters are mostly eliminated. What gives?
Another way to compare would be with a video player that lets you switch between hardware and software decoding, like MX Player. Watch the clip in HW mode and then switch to SW - it's choppier in HW mode for whatever reason. Using SW is not an option as the colours are not displayed properly and battery drain is much higher.
Regarding the clip - if it's against the rules to post such content, let me know and I'll remove it. There's a whole YouTube channel full of this stuff, I don't want to link to those as the problem I'm encountering is related to local video playback.
FWIW I don't have an S10 myself and don't know anyone who does, but on my Huawei Mate 10 that Plane Crash Scene video plays perfectly on it, using MX, Kodi, and the stock video player.
The 4K YouTube video just buffers, unless I drop it to 1080, then it plays. Which is likely my limited bandwidth.
Filter
