Any Z Fold 4 tips?????
Fair enough - I don't mind being the exception. The Z Fold 5 is expected to be a small improvement over the 4, but rumors are already trickling that the Z Fold 6 will be a major change.
I would definitely miss this main display when writing on the go, as I can use Word and see the entire page. Still undecided and I'm sure I'd have some regret right after selling this one. I hope, for all of you, that the foldable phone doesn't end up like VR or even 3D TVs. We were in deep with both technologies and the plug got pulled on us.
Amazon Music screwed up downloads on Android 13/One UI 5
Today, I wanted to download some songs to re-create the 'nature rock' playlist that I use for my Saturday hikes in the woods. I had just gotten a Samsung A03s to replace a dying Samsung Galaxy S5, and so far love the new phone (first for me) but it had one major issue that caught me off guard.
First, Amazon Music downloaded the songs I wanted, but Samsung Music (preferred music player) couldn't see anything but the Over The Horizon song it comes with. I tried rebooting the phone, rescanning, and attempting to browse via My files to no avail. I also tried many other file manager apps (even my old standby, a spare APK of ES File Explorer 3.x from Android 2.3) but no dice. Apparently, Amazon changed the location of downloaded files, even including purchased MP3s. It took me a long time (try two hours) of messing around and then viewing random Reddit posts but they did something to Android 13 to really screw with my sanity.
Apparently, Amazon Music no longer saves under the 'com.amazonmp3' folder like it did since, like, 2011? It has changed to the 'Android/Data/com.amazon.mp3/purchased' folder, but as of Android 13, that folder is no longer viewable (Why Google?!). So the only 'official method' is to use Amazon Music to play the downloaded songs. Their app would work for that I figured, so since that 'Nature Rock' playlist is indeed backed up to Amazon cloud, it shows up in the app. I had downloaded it ahead of time planning on playing it today. Unfortunately, while when I downloaded it, it had 50 songs, today, when I chose to play it, it only had 7. Literally more than 3/4 my songs are gone. Trying to look at all the purchased songs, a good 50% now show up only accessible via 'Amazon Music Unlimited'.
Oh, hell no! No way. I cleared data from the app (we're on hour 3 now, I planned my hike at 10, now it's 1) and re-logged in. Now all my songs show up, even all the 50 in that playlist, only now I no longer trust the app to work when I expect it to, like say, next week, will it go back to 7 again? I need to find out how to get them to show up under Samsung Music. I own the damned songs, they're MP3s, they obviously downloaded since they take up space, but only Amazon can see them (until it 'forgets again')
I don't know what Android 13 borked, but I was able to use an app called 'FV File Explorer' that can see and copy from /Android/Data/* so I was able to use it to copy the music to the Music folder on my SD Card, and rebooting, now Samsung Music sees all of it. I recreated the playlist in Samsung Music, and after 5 literal hours of hair-pulling frustration, it's back to where it was on my S5. But this is exactly why I despise modern tech, modern software. It can make the simple act of playing offline, purchased MP3s a royal, headache inducing pain in the empennage. I don't know why they keep trying to fix what ain't broken. So far this is the only major issue with my new phone, and hopefully the last. It otherwise works fine despite it being low-end. I still have to plug in the Type-C cable in twice before it recognizes the charger, but that's a Type-C bug that will likely never get fixed (much like how loose it feels, not like the far more secure 'click' I got from Micro USB)
Lockscreen pop up picture (solved)
I know what you're saying. I'm on a Samsung Note 20 Ultra. The pop up itself isn't a picture in the options I could even choose. The lockscreen is the "Dynamic Wallpapers" where it changes to a new picture every time I go to unlock the device. The homescreen is a static image (one from my gallery). I could trial and error a static image on the lockscreen moving forward?! Thanks for the response.
Is it possibly one of the included wallpapers on the device? Not sure which device you are on but on my phone if I long press the homescreen, I have an option to view pre installed wallpapers. Anyway, when I select a wallpaper, photo, solid color, etc. to set as wallpaper there is an option for homescreen, lock screen or both. Maybe you can do something similar and set your usual wallpaper as both or select something different for your lock screen?
This worked, or solved the inquiry at least. I disabled "Dynamic lockscreen wallpapers" and this image is the default image if I don't select ANY other wallpaper. I think it was flashing briefly when all the images selected to show in dynamic mode had been seen and it was starting the set over again...which happens to be about 30 different pictures. Finally, solved. Truly appreciate you taking the time to chime in and locate the issue!
How to update "Redmi Note 9" to higher Android version?
which redmi note 9 do you have? the 4G version? what is your model number?
i do not have your phone and i see that there is a Redmi Note 9 and a Redmi Note 9 4G. just the note 9 can be upgraded to android 11 while the note 9 4G can be upgraded to android 12.
and as @Dannydet suggested updates will depend on your carrier and manufacturer. if you know your exact model of the phone, you can do a search and see if there is a firmware update available for your phone. keep in mind that firmware updates are very device specific and installing the wrong firmware can have seriously bad consequences.
Help! Google Message App Issues on Android Phone
Long press on the icon on your home screen and choose delete or move it to the top for removal. Then swipe up to bring up your app drawer, scroll to your messages app icon, long press on it and drag to your home screen.
Yep, that is exactly what I did to fix it, prompted by the first response.
Help Persistent Charging Connected Device Via USB" Notification
Android System - Charging connected device via USB - Tap for other USB options
I have had the same on a Galaxy Note 9 ... And think I have figured out why ...
This is an Android OS Issue ... Not Hardware Related !!!
The Phone has been connected to an extrrnal device (game controller, Flash Drive, Android Auto, or similar) and part of that connection was to change the USB Connection Defaults to suit that device. Reconnect the device and see if you get different options.
1. "AndroidAuto" was what changed the settings for me ... after I re-connected to AndroidAuto, and changed the preferences about auto-start and auto-play-music etc, the error message/notification went away.
2. My Phone charged again when cable was connected and I tapped the Notification "Android System - Charging connected device via USB - Tap for other USB options" and chose "This Phone" ... You MUST connect Charging Cable first, to get option for "This Phone"
Hope that helps ...
Beauvaidos
Unable to start up x86_64 phone emulator in Android Studio on a Mac
Trying to start up a x86_64 based phone via the Android Studio Emulator, but it freezes at the white screen showing "Google". Here are the particulars:
1. Intel Core i7 chipset on the Mac
2. Android emulator uses API level 33
3. system image is from system-images/android-33/google-apis/x86_64
In Android Studio, when I hit the "run app" icon, as mentioned, it tries to start up the emulated phone, but freezes up.
I have tried --
1) installing intel-haxm driver via Mac "brew"
2) in Android Studio: "wipe data" on the emulator, then "cold boot" of the emulator but same problem.
3) tried at the command line: "emulator -avd Pixel_XL_API_33_x86_64", but again freezes at white screen.
A small portion of the (adb) logcat (excuse the ctrl-M's) shows:
--------- beginning of crash^M
04-27 12:29:20.046 450 480 F libc : Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 480 (RenderEngine), pid 450 (surfaceflinger)^M
04-27 12:29:20.301 603 603 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***^M
04-27 12:29:20.301 603 603 F DEBUG : Build fingerprint: 'google/sdk_gphone64_x86_64/emu64x:13/TE1A.220922.012/9302419:userdebug/dev-keys'^M
04-27 12:29:20.301 603 603 F DEBUG : Revision: '0'^M
04-27 12:29:20.301 603 603 F DEBUG : ABI: 'x86_64'^M
04-27 12:29:20.301 603 603 F DEBUG : Timestamp: 2023-04-27 12:29:20.132342416-0600^M
04-27 12:29:20.301 603 603 F DEBUG : Process uptime: 6s^M
04-27 12:29:20.301 603 603 F DEBUG : Cmdline: /system/bin/surfaceflinger^M
04-27 12:29:20.301 603 603 F DEBUG : pid: 450, tid: 480, name: RenderEngine >>> /system/bin/surfaceflinger <<<^M
04-27 12:29:20.301 603 603 F DEBUG : uid: 1000^M
04-27 12:29:20.301 603 603 F DEBUG : signal 6 (SIGABRT), code -1 (SI_QUEUE), fault addr --------^M
04-27 12:29:20.301 603 603 F DEBUG : Abort message: 'Unable to generate SkImage. isTextureValid:1 dataspace:513'^M
04-27 12:29:20.301 603 603 F DEBUG : rax 0000000000000000 rbx 00000000000001c2 rcx 000075020db346ff rdx 0000000000000006^M
04-27 12:29:20.301 603 603 F DEBUG : r8 000074ff79a18660 r9 000074ff79a18660 r10 000074ff79a184c0 r11 0000000000000207^M
04-27 12:29:20.301 603 603 F DEBUG : r12 000000000000000d r13 0000750059e203b0 r14 000074ff79a184b8 r15 00000000000001e0^M
04-27 12:29:20.301 603 603 F DEBUG : rdi 00000000000001c2 rsi 00000000000001e0^M
04-27 12:29:20.301 603 603 F DEBUG : rbp 0000750029e22c28 rsp 000074ff79a184b0 rip 000075020db346ff^M
04-27 12:29:20.301 603 603 F DEBUG : backtrace:^M
04-27 12:29:20.301 603 603 F DEBUG : #00 pc 000000000005f6ff /apex/com.android.runtime/lib64/bionic/libc.so (abort+191) (BuildId: 007cb2313464df63debf8020e631c990)^M
04-27 12:29:20.301 603 603 F DEBUG : #01 pc 000000000000abba /system/lib64/liblog.so (__android_log_default_aborter+10) (BuildId: 6b5490b5683793c72167e11556e0b7d9)^M
04-27 12:29:20.301 603 603 F DEBUG : #02 pc 0000000000008712 /system/lib64/liblog.so (__android_log_assert+338) (BuildId: 6b5490b5683793c72167e11556e0b7d9)^M
04-27 12:29:20.301 603 603 F DEBUG : #03 pc 00000000001ef207 /system/bin/surfaceflinger (android::renderengine::skia::SkiaGLRenderEngine::drawLayersInternal(std::__1::shared_ptr<std::__1::promise<android::renderengine::RenderEngineResult> > const&&, android::renderengine::DisplaySettings const&, std::__1::vector<android::renderengine::LayerSettings, std::__1::allocator<android::renderengine::LayerSettings> > const&, std::__1::shared_ptr<android::renderengine::ExternalTexture> const&, bool, android::base::unique_fd_impl<android::base::DefaultCloser>&&)+23335) (BuildId: caf11998e449c0913886496d851f3e37)^M
04-27 12:29:20.302 603 603 F DEBUG : #04 pc 00000000005ead7c /system/bin/surfaceflinger (android::renderengine::RenderEngine::drawLayers(android::renderengine::DisplaySettings const&, std::__1::vector<android::renderengine::LayerSettings, std::__1::allocator<android::renderengine::LayerSettings> > const&, std::__1::shared_ptr<android::renderengine::ExternalTexture> const&, bool, android::base::unique_fd_impl<android::base::DefaultCloser>&&)+124) (BuildId: caf11998e449c0913886496d851f3e37)^M
04-27 12:29:20.302 603 603 F DEBUG : #05 pc 00000000006023d8 /system/bin/surfaceflinger (android::renderengine::skia::drawImageLayers(android::renderengine::skia::SkiaRenderEngine*, android::renderengine::DisplaySettings const&, std::__1::shared_ptr<android::renderengine::ExternalTexture> const&, std::__1::shared_ptr<android::renderengine::ExternalTexture> const&) (.__uniq.148735152540075350775156443829291153399)+760) (BuildId: caf11998e449c0913886496d851f3e37)^M
04-27 12:29:20.302 603 603 F DEBUG : #06 pc 0000000000600a38 /system/bin/surfaceflinger (android::renderengine::skia::Cache::primeShaderCache(android::renderengine::skia::SkiaRenderEngine*)+1720) (BuildId: caf11998e449c0913886496d851f3e37)^M
04-27 12:29:20.302 603 603 F DEBUG : #07 pc 00000000005fc1db /system/bin/surfaceflinger (android::renderengine::skia::SkiaGLRenderEngine::primeCache()+11) (BuildId: caf11998e449c0913886496d851f3e37)^M
04-27 12:29:20.302 603 603 F DEBUG : #08 pc 00000000005fb2dd /system/bin/surfaceflinger (android::renderengine::threaded::RenderEngineThreaded::primeCache()::$_3::operator()(android::renderengine::RenderEngine&) const (.__uniq.64102821644698991011622682901256404626)+93) (BuildId: caf11998e449c0913886496d851f3e37)^M
04-27 12:29:20.302 603 603 F DEBUG : #09 pc 0000000000251e8c /system/bin/surfaceflinger (android::renderengine::threaded::RenderEngineThreaded::threadMain(std::__1::function<std::__1::unique_ptr<android::renderengine::RenderEngine, std::__1::default_delete<android::renderengine::RenderEngine> > ()>)+700) (BuildId: caf11998e449c0913886496d851f3e37)^M
04-27 12:29:20.302 603 603 F DEBUG : #10 pc 0000000000351be5 /system/bin/surfaceflinger (decltype(*(std::__1::forward<perfetto::base::ThreadTaskRunner*>(fp0)).*fp(std::__1::forward<std::__1::function<void (perfetto::base::UnixTaskRunner*)> >(fp1))) std::__1::__invoke<void (perfetto::base::ThreadTaskRunner::*)(std::__1::function<void (perfetto::base::UnixTaskRunner*)>), perfetto::base::ThreadTaskRunner*, std::__1::function<void (perfetto::base::UnixTaskRunner*)>, void>(void (perfetto::base::ThreadTaskRunner::*&&)(std::__1::function<void (perfetto::base::UnixTaskRunner*)>), perfetto::base::ThreadTaskRunner*&&, std::__1::function<void (perfetto::base::UnixTaskRunner*)>&&)+85) (BuildId: caf11998e449c0913886496d851f3e37)^M
04-27 12:29:20.302 603 603 F DEBUG : #11 pc 00000000005fb059 /system/bin/surfaceflinger (void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (android::renderengine::threaded::RenderEngineThreaded::*)(std::__1::function<std::__1::unique_ptr<android::renderengine::RenderEngine, std::__1::default_delete<android::renderengine::RenderEngine> > ()>), android::renderengine::threaded::RenderEngineThreaded*, std::__1::function<std::__1::unique_ptr<android::renderengine::RenderEngine, std::__1::default_delete<android::renderengine::RenderEngine> > ()> > >(void*)+73) (BuildId: caf11998e449c0913886496d851f3e37)^M
04-27 12:29:20.302 603 603 F DEBUG : #12 pc 00000000000ccd2a /apex/com.android.runtime/lib64/bionic/libc.so (__pthread_start(void*)+58) (BuildId: 007cb2313464df63debf8020e631c990)^M
04-27 12:29:20.302 603 603 F DEBUG : #13 pc 0000000000060d37 /apex/com.android.runtime/lib64/bionic/libc.so (__start_thread+55) (BuildId: 007cb2313464df63debf8020e631c990)^M
04-27 12:29:23.096 637 656 F libc : Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 656 (RenderEngine), pid 637 (surfaceflinger)
Of note to me in this log portion--
(1) I do not see /system/bin/surfaceflinger on my Mac
(2) Abort message: 'Unable to generate SkImage. isTextureValid:1 dataspace:513' - this sounds important. Is it?
Pls let me know how one can get around this issue of the emulated phone freezing up.
And definitely, if I am asking on the wrong forum, pls let me know and I will direct this question elsewhere. Thx.
Stopping music/radio apps from starting up by themselfwhen connected with bluetooth?
Open the Spotify and Tunein Radio apps, and look for any settings related to Bluetooth auto-play or auto-start. Disable these settings if they are turned on.
Thanks
Tune-IN has a selection "Autoplay" with description "Turn ON to resume your last stream when tune In launches" and this is deselected. Few other chocies are enable and nothing seems to apply.
Nothing on Spotify setting seems to be appropriate.
Thanks!
..Tom
Parental control "APP" on Amazon Tablet?
No worries. Come back and tell us which one you ended up with and why you like it.
I've decided to go with Mobicip "Lite" version. It seems there are a couple of good free ones out there, such as Kaspersky Safe Kids and Google Family Link, but they are not compatible with Amazon Fire. I'm primarily concerned with web/app filtering and blocking, and Mobicip "Lite" for $2.99 per month seems to fit the bill.
Filter
