[FREE][APP] Dreamai - AI Art Generator
Hey! Just released my first android app. If you decide to try it, please let me know what you think. I would really appreciate your feedback. Thanks and hope you guys enjoy it! :D
https://play.google.com/store/apps/details?id=com.dreamai.aiartgenerator
Bring your ideas to life with the power of AI! Create stunning AI-generated images by transforming your words into stunning works of art. With a wide variety of styles to choose from, you can customize your creations to your liking with unlimited freedom.
No art skills are required! Dreamai’s AI art tool makes it easy to turn your imagination into reality.
How does it work?
- Type your ideas
- Pick an art style or create your own
- Watch AI work its magic as it creates your design in seconds.
Discover your inner artist!
Explore your creative potential and bring your artistic ideas to life. Dreamai leverages cutting-edge AI models, such as Stable Diffusion, Midjourney, and DALL-E, to generate an endless stream of artwork based on your unique prompts. The only limit is your imagination!
Explore the community's creations.
Get inspiration from AI generated images from the community. Freely use their design or prompt, and modify them to your liking.
Discover new styles or create your own.
Choose from an infinite variety of styles such as fantasy, anime, and cartoon, or combine your likings to create your unique style. Join our special styles events and earn rewards for your magnificent design.
Share your stunning artwork!
Go viral by posting your masterpieces on social media or sharing them with your friends! Your creative creation can be used as an avatar profile icon, NFT, or new wallpaper.
ISO An Android game i used to play!
Why not just look in your play store purchases? The play store keeps track of all the apps you bought and downloaded. There are so many games out there that unless it's something popular, I doubt somebody will know of the game you speak of.
I was in middle school and I didn't have a cellphone. I played it on a friends phone. Said friend no longer keeps in touch.
Bottom Speakers on Google Pixel 6 Stop Working Sometimes
i don't have the phone, but i have yet to come across any android setting that can change what speakers to use for notification sounds. have you gone into your phone's settings and did a search for speaker settings? or speaker notification settings?
if you can't find it, maybe take it in to your local cell provider and see if there is a technician that can take a look at the phone.
Cant flash with odin
With different results in different Odin logs there is a common aspect:
<ID:0/007> Complete(Write) operation failed.
Given all the variables you're tried (Odin versions, Samsung driver update, working via ADB instead) that reoccurring error message indicates that phone's internal storage chip might be failing. If so, that's a hardware matter that typically involves replacing the entire logic board.
And as a side note, it's not a good idea to just randomly try flashing different ROMs (you initially indicate using SM-G930F firmware and later using SM-G930FD firmware) ROMs are typically model specific and not interchangeable.
but when i flashed CF-auto root file via odin it worked perfectly fine however it took 3 tries.
Moto G8 Plus (XT2019-2) Corrupted device, cant run in RSA software
I agree with @ocnbrze Take your phone to a trusted, nearby phone repair shop and have them look into this for you.
From your description, instead of just focusing on your phone's Camera app you've created a more complicated fix/repair/restore than necessary. Rough analogy being you're using to sledgehammer as opposed to just a basic hammer -- a minor software issue with the camera app doesn't require flashing the firmware.
It's just not a good practice to unknowing experiment with things like Fastboot nor flashing possibly questionable ROMs. Maybe with a secondary phone you don't need and just want to teach yourself about Android fundamentals, but not on daily usage phone.
System update problem
Sorry for delay in replying to the suggestions. I had be trying to do the update using my mobile data connection. On looking carefully at the screen info. with the update instructions I saw that using Wifi connection was suggested as better option. I went to my public library, logged on to their wifi service and the update functioned correctly with no mention of "turning off data saver" function (which as mentioned before I never had ON at any point).
Update process took about 1 hr. and at the end system was updated and seems to be just fine. No need to try Reset. As said before I am NOT totally "tech savvy" and maybe using Wifi is normally the way it is done.
SO, problem solved and thankyou again for suggestions/help.
There may be a setting that restricts system updates to download over wi-fi only. If you can find it you can toggle it on/off as needed.
a52, a52s or a53
I'm well aware that OEMs are also using letters/numbers. Still confusing. Car manufacturers do the same. Maybe I'm just gettin' too old for this ****
Thankfully my two vehicles have names. Saturn Ion, Honda Ridgeline.
Even my computers have names. Dell Vostro. Dell Latitude. I was brought up to believe that if it's not important enough to give it a name, it's not going to be of very good quality. That rang true as every foreign car in the USA in the 80s was utter garbage, be it a Subaru XT6 or a Honda CVCC to a Bricklin SV1. All junk.
I believe Dell calls a majority of their laptops "Latitude", and has done so since 1994, with "Vostro" for their desktop PCs.
And it's arbitrary numbers that identifies the particular models. Same same with Lenovo(formerly IBM) calls their laptops "Thinkpad", Samsung with "Galaxy" for phones etc.
I've never seen or heard of a Honda Ridgeline or Saturn Ion, but I suspect they've got some other marques outside of the US, in other parts of the world. That's what carmakers do, especially the likes of VW, GM, and Toyota.
Help smiley faces ( emoji) not working
Thanks! I tried the default settings and it didn't work. I found out they weren't working when my husband kept asking why I was sending blank texts...haha
So I was having the same issue not being able to send emojis how I resolved my issue was by going directly in messaging app selecting the three dots on the right hand side. From there I selected settings. Select on advanced sms/mms settings and I scrolled to the bottom where the simple characters only was turned on I turned it off and it fixed my issue
Intermittent phone signal
My S5 has developed an internet connectivity and phone signal issue. I managed to fix the internet connection issue (knock on wood) by installing a "booster" app. However, my phone signal still fades in and out. One minute I'll have sufficient signal to make a call or send a text, and then a few minutes later I will have no signal at all (zero bars.) It does not matter where I am at. Whether I'm at home, or work, or driving, my phone signal is always intermittent.
Does anyone have suggestions on how I might be able to fix this?
If you upgrade yourself (not Samsung) to a newer Android version you can try making your phone calls via the wifi calling option. Today I use T-Mobile and use it on my Moto G stylus smartphone for the spotty cell signal areas of my house. 5 yrs ago AT&T gave us a cell booster box to attach to our router to help with the dead cell signals within our home.
Help FX file Explorer - How to make a file write accessible?
Instead of trying to use a file manager app, try using terminal app to change the Permissions feature of that system folder.
Possibly chmod 644 /system/media/audio/ringtones
Read up and be judicious about which r/w/x permissions you use.
If you don't already have a preferred terminal emulator installed, suggest you try the Termux app, it's a very versatile terminal
Disabling Time Adjustments
If your company is managing and maintaining 50 or so phones for its staff, there's likely to be someone in charge of a MDM (Mobile Device Management) service to remotely manage those phones? Which one?
If not, with that many mobile devices that should be implemented to keep employees from tweaking things to for their own purposes. Locking down the Settings menu is typical feature in most MDM services, a measure to prevent things like change date/time, installing apps, etc.
Icon?
I can tell you that it doesn't comply with current Google style guidelines.
Beyond that, anyone's guess as it's very blurred. I had an impression of a game piece, but could be completely off track.
Bear in mind that there are literally millions of apps, so unless it's a common one the chances of getting an answer are slim. Your best bet is probably to ask the person whose phone it's from, but usually these queries are from people who don't want to ask (or don't trust the answer).
Rooting my OnePlus
Sorry I meant OTA package autocorrect, ok I'll try
Please take care to detail your words. I have no idea what is meant by "the it's package". Did you locate the *payload.bin file (I think it was) for your particular phone to match the OS you have installed? Maybe that's what "the oxygen updater app" does ... If so, you'd have to locate that file to follow the rest of the instructions.
If you have busybox installed on the phone, an "adb shell" from your connected laptop would make the search for the file location rather trivial. In adb shell:
find / -type f -name \*[Pp]ayload.bin 2> /dev/null
Help How do I stop this Home button popup?
I've also seen instances where another app's 'draw other over apps' permission interferes with the default launcher setting as well, but not sure why. Check to see if the survey app has a draw other over apps setting and try turning it off. That would be in the application manager's listing for the app, and in the 'special access' category (Android 6.0-under) or the 'draw over apps setting' (Android 7.0+)
Game Mode (or Game Launcher) is built-in, and shouldn't be interfering like this. I'm guessing this is a Samsung phone? However, if that service recently got updated it might have caused some issues. See if you can find Game Mode in the app manager and see if there's a three dot icon on the upper right corner when in the app's settings, and try tapping 'uninstall updates' if it's there. You might have to tap the same three-dot menu when in the main app manager list to 'show all system apps' first.
Lots of useful advice there. I've checked as you suggest: both Bv Launcher (which seems to be the built-in, uninstallable launcher from the phone's maker Blackview) and Game mode have 'Not Allowed' in their 'Display over other apps' setting.
Anyway, this is hardly important in the grand scheme of things. Maybe it will fix itself at some point. Thanks for helping.
Help Factory reset [android phone] data retrieval
What do you think a 'factory reset' is? It warns you like three times that it will ERASE ALL USER DATA (in all caps). Sadly, Android never got the equivalent of iCloud where all your data syncs up soon after you login to your Apple ID (or in this case Google Account). That used to be a chief complaint in my transition away from Apple to Android; that all my games had to restart from level one, no progress saved, no apps backed up with the same version I used last, etc.
Move AF Community To The Top Of The Forum
We could also require new members introduce themselves, but at that point, I think we're creating too large a hurdle for participation.
However, I just noticed the "Welcome E-Mail" for new members was WAYYYY outdated so I turned it off and the "Welcome Private Message" was turned off. We should definitely utilize these, too.... not only to urge people to Introduce themselves but also to give them the run down of the site and how to get the most of it.
I think we're still very much trying to reconfigure the site so I don't want to craft something just yet, but I'd love to hear opinions!
Are you a vegetarian?
I never will understand the appeal of shows such as Duck Dynasty, Swamp People or 'Hillbilly Handfishin'' (please don't look up 'noodling' unless you got vore fantasies!!!) and that last one was on Animal Planet of all things...
Hunting is non-negotiable with me. I don't want to know you or talk to you if you're a hunter. I have a zero tolerance policy for anyone who dares hurt my antlered and hooved friends.
Filter
