Unless the phone is already rooted - the OP hasn't answered any questions about what they are trying to do or what the state and status of the phone is.Also you can't install a stock rom via SD card. You need a computer program to do it called Odin. The only way to do what you are asking is to root the device and have a custom recovery installed on the phone. But even rooting you still need a computer.
this is an english only site.Grazie per la risposta. Hai ragione, oltre al codice, che ho anche intuito, sai dov'era il problema? Solo nel filtro intent in particolare nel tag type. Grazie lo stesso, ottima risposta. Buon 2023!!!!
Thanks for the reply. You are right, besides the code, which I also guessed, do you know where the problem was? Only in the intent filter specifically in the type tag. Thanks all the same, great answer. Happy 2023!!!!
@RequiresApi(Build.VERSION_CODES.M)
override fun onCreate(savedInstanceState: Bundle?) {
super.onCreate(savedInstanceState)
setContentView(R.layout.activity_main)
val rollButton=findViewById<Button>(R.id.rollButton)
val resultsTextview=findViewById<TextView>(R.id.resultsTextView)
rollButton.setOnClickListener {
val rand=Random().nextInt(SeekBar.generateViewId())
resultsTextview.text=rand.toString()
string hexString = "192386180500";
byte[] keybytes = new byte[hexString.Length / 2];
for (int i = 0; i < keybytes.Length; i++)
keybytes[i] = Convert.ToByte(hexString.Substring(i * 2, 2), 16);
byte[] keybytes = BitConverter.GetBytes(long.Parse(hexString, System.Globalization.NumberStyles.HexNumber));
// Get an instance of shared preferences
val sharedPreferences = getSharedPreferences("STEP_COUNTER_PREFS", Context.MODE_PRIVATE)
// Get the current total step count from shared preferences
val totalSteps = sharedPreferences.getInt("TOTAL_STEPS", 0)
// Register the step counter sensor listener
sensorManager.registerListener(object : SensorEventListener {
override fun onAccuracyChanged(sensor: Sensor?, accuracy: Int) {}
override fun onSensorChanged(event: SensorEvent?) {
// Increment the total step count by the number of steps taken
totalSteps += event?.values?.get(0)?.toInt() ?: 0
// Save the updated total step count to shared preferences
sharedPreferences.edit().putInt("TOTAL_STEPS", totalSteps).apply()
}, stepSensor, SensorManager.SENSOR_DELAY_UI)
for (int i = 0; i < numDevices; i++) {
BluetoothGatt gatt = mBluetoothGatt[i];
BluetoothGattCharacteristic charac = btWriteGattChar[i];
charac.setWriteType(BluetoothGattCharacteristic.WRITE_TYPE_NO_RESPONSE);
charac.setValue(dat);
gatt.writeCharacteristic(charac);
class Item {
private String name;
private int price;
// Other variables and methods
class User {
private int balance;
private List<Item> inventory;
// Constructor to initialize balance and inventory
public User(int balance) {
this.balance = balance;
this.inventory = new ArrayList<>();
// Method to purchase an item
public void buyItem(Item item) {
if (item.getPrice() <= balance) {
balance -= item.getPrice();
inventory.add(item);
} else {
// Insufficient funds
// Other methods to get balance and inventory
requestitems = new ArrayList<>();
I can't download it in the states. It says, "This app is not available for any of your devices"
