N6 Retirement Party
- By lunatic59
- Smartphones
- 48 Replies
Check your PM's(PS: if anyone has a nice Nexus 6 that they can donate towards my blight, contact me for shipping address)
Thanks for the advice - the problem is I only use the tablet when I am on the road - (in hotels or AirBnB) and there it is not possible to play around with routers. I may just have to take my cumbersome Windows laptop with me because Windows Remote Control has no problems in accessing the server without fiddling around with ports.Check that 3389 is open in your Windows firewall, and have you already set up port forwarding in your router?
https://portforward.com/remote-desktop/
I experienced the same problem with samsung galaxy J5 prime which says No need to enable but not appear in options menu like shown in the following video.Like two or three months ago, i opened up the developer settings with the "tap 7 times on the build number" method. And i used it, then i wanted to turn it off. To do this: i went to my application settings, found the "settings" app and cleared data and the cache. With this method, my developer settings gone.
So, i wanted to turn it on again couple of days ago, tapped on the build number and a pop-up showed up like this:
"No need, developer mode has already been enabled"
Then when i go to the main settings page, where the developer settings were in, there was no developer settings.
And yes, i know where the developer settings exactly is. So please don' t answer me like "check again", "tap on the build number for seven times", "restart your phone" or something like these.
And no, since i cant reach to the developer settings, i can't open the "OEM unlock" and "USB debugging" settings.
And i also tried the "Activity launcher" app but it didn't work too.
Please help...
How can I get around this ? Can I use hotmail for this purpose ?
But wiping the play store does not delete your apps or anything downloaded. All you need to do is re-sign in with the account you want.Thanks but there is nothing I need in the Play Store worth having to wipe out everything on my phone and having to set it up all over again. Besides, I don't think this is a phone problem as I have run into similar problems where Google has made navigating through their system difficult and later finding a way through it after many tries of different things days later. Some things on Google services seem to be made deliberately more difficult than they should be, one being deleting an account. There should be a straight-forward and up-front menu item to delete an account, there's not. The problem of being run in circles when selecting to sign with a different account and is a perfect example of this.
Everything on my phone works fine; only this one site is giving me trouble. I have an old Galaxy S6 here that I tried this morning. I tried it as a troubleshooting measure and I have the same problem on it because I used to use the same old deleted accounts on it, too.
I think I will eventually find an obscure way to get through this, eventually but, like I said, I don't need anything right now that is important enough to wipe my phone clean and start over. Losing about two years worth of blocked SMS numbers is just one reason.
Relax it is normal for push notifications be nullify, but you can head to each app and have it really activate, per app, head over to the app notifications and turn them back on. Preferablity I have most off.Hello everyone, everything good?
I'm having problems with push notifications (via Firebase) on some cell phone models (Samsung A and others), using Android 12 in an Ionic/Cordova app.
It turns out that I am not receiving push notifications on these devices, but on others with android 11, 10 it is normal...
Anyone with a similar problem?
Your welcome tooHeh, been using it for so long it's a bad habit now. I've tried others (including ddg) and keep going back, ugh. Was just wondering if there was an option I'd missed to stop it really. Besides, I don't know if I can learn to have that special hate for a new site
Thanks though!
