How do I change the lock screen time?
- By Sunny Rio
- Ask a question
- 18 Replies
There's too much information, it could be many things. For example does someone in here know if that particular app is for my OS and hardware version?
Thanks for the suggestion, sadly all the trustworthy looking options for split screen don't work even with Dev tools enabled.this is not an android thing but your phone's manufacturer is what determines how your phone fully works. each manufacturer can add what we call a skin on top of android. for example samsung's OneUI. each "skin" makes the android experience different from other manufacturer's.
on my z fold 4, split screen is pretty easy to do. you can even save splitscreen shortcuts!
there are apps in the play store that can do split screens. maybe those might make it easier for you:
https://play.google.com/store/search?q=split+screen&c=apps
other than that, the only option is to either get used to it or go back to the older device.
you might be able to get it to work, but some things maybe be broken. not sure what as i never tried using the gear vr with any other device other than a samsung phone.Probably be a dumb question but here goes. I have a LG G7Thinq phone. I also have a Samsung vr headset for phone, model SM-R323. It worked when I had a Samsung phone. I can fit the LG into it but they do not recognize each other. Is there any way to use the LG phone with the Samsung VR headset?
Fixedhttps://2pwn.tk/android/ginna/recoveries/ofox/
Takes me to some bullshit adult blog of Japanese shit....
thanks!I restarted her phone and it works now.
bq was well-known in Europe, but there are no major updates anymore for android 8.01 at least not from bq. It's 5 yrs old and it's my wife's who has no idea what happened. It has Everything on it b/c she uses it more than her laptop and I doubt that she's backed up anything. What interests me is the app, which I can't find anywhere and it doesn't give any info. I can move all over the screen, but as soon as I press it, it disappears and a grey horizontal bar scans up and down the screen. I'm going to try to transfer what's on her phone to an *empty' sony xperia XA2 and hope the transfer, if it works, doesn't export the distortions into the the Xperia. Can't chuck this thing until I can recover its info.von bq? i can't even find this device on the web. you said all of a sudden? was this after an update? how old is the device? how long have you had it for? if things are messed up, have you tried just re-booting the device? and last resort you can try a factory reset. and the very last resort i would look to get a new device and preferably a device that is not off-brand.
so the a52 does not support wireless charging. you will need an charge adapter the plugs into the usb c port. you will then need a case to portect and hold the adapter in place on the back of the phone. one of the problems will be that the usb port is now occupied and unplugging the adapter can be difficult to do.The USB C port is sometimes unreliable. What item is the best to allow induction charging in the A52, especially fast charging?
You most likely disabled your keyboard.
One of those screens should get you into language and input, where you can enable the keyboard again
