Tv streaming apps like mobdro?
- Smart Home
- 14 Replies
I turn on tubi and youtube sometimes if I want to watch something off my Dish...
I have a Moto G Stylus 5G on T-Mobile. I should be able to unlock the device, but it's preventing me from doing so due to an unknown system error. I got the device second hand and have no way to contact the previous owner, but as far as I am concerned there are no other factors preventing me to unlock the phone. Is there any solution to this, or am I forced to go to T-Mobile for assistance?
have you tried this?Thanks, but I was trying to look for ways to unlock the device from my carrier, and I did want to avoid having to pay money too. Oh well.
here is the guide for you. please read carefully. i would recommend that you read all 4 pages of the thread. pay close attention to anything mentioning binary 3:Thank you for the reply. It's a A12 Model #SM-A125U.
All help is appreciated.
Tom
I appreciate the time you took to help me with this Backup question. Thank you svim.Avoid those cheap knock-off USB cables, they're made with substandard, surplus-bought components with minimal to no quality control. Or in other words, they're cheap for a reason. Buy a good, brand-name USB cable, they not that much more expensive. A reputable cable will have thicker gauge wiring inside, better insulation (often shielded), and higher quality plug ends. Power transfer is a secondary issue but data transfer is a major aspect, so by just spending a few dollars more you'll have a USB cable that lasts longer and will be able to move data more consistently and reliably.
just want to verify that this is what you did:I have a new Galaxy S22 and it rings FOREVER. I tried two of the MMI codes that SAY they'll reduce the ring time, but so far, don't work. Neither **61*321**00# nor **61*101**00# where I replaced the 00 with 10 or 15 worked. Can someone tell me HOW to reduce the ring time significantly on this phone?
Thanks for reply it's in portrait on my Nvidia shield but can only get it in landscape on Android box tried all settings but no joy?This all depends on the app itself, and each one is different. If the developer made it to be used in both portrait and landscape mode, then it will work. If not, then you are out of luck.
this does not help the op with saving room on the phone. yes you can backup your sd card to whatever hard drive you want. but you can't completely backup a phone to a hard drive. a complete backup of the phone can only be done if the phone is rooted and using a custom recovery to make a nandroid backup.Can I just use an external hard driver and connect it to the PC?
