[APP] Riddle Tower - A riddle app inspired by GodTower and NotPron
Hello everyone
Hopefully this post is not against the rules of the community. If something is off please let me know so i can remove it/fix it.
Riddle tower is a game i always wanted to make but having close to no free time it was really hard to start learning unity. The last 3 months i got some free time and now i published it at Google play store.
I understand this game is not for everyone but i am sure that everyone who played these kind of riddle games in the past will get a nostalgic feeling.
I am more than happy to listen to your feedback and also i can keep this thread as a small walkthrough to the game to help anyone who is stacked with some hints.
Have great day everyone.
You can find the game by searching "Riddle Tower" on google play store.
https://play.google.com/store/apps/details?id=com.riddletower
Be the first to answer
Root [SOLVED] How do I root my phone?
Hello! Sorry to bother you so long after this post was made, but I don't plan to use root to hack games. I want it for things such as TowelRoot, internal audio recording, and unlocking my phone's full potential. I don't really hack games any more because it's no fun.
Anyway my point is, if you actually DO know a way to do this, could you tell me? I researched and researched and it doesn't look possible to me.
Towelroot only works on Kitkat with a kernel exploit. CF Auto Root or install Twrp then flash SuperSu on Lollipop and Marshmallow.
OnePlus N10 5G Anyone here have one ??
My friend has it. He hates the phone but he wants something that is super easy to use, with no learning curve, etc. This is someone who struggles to use the camera. I'm not meaning to slam him or it, just saying. From what I have seen of it, it doesn't look too bad. It has a lot of storage built into it, which somewhat makes up for the bloatware. (ROOT, ROOT, ROOT for our team!) I believe it can also accept sd. The camera is probably mediocre, but then most of them are. As someone on AF said, if you want a camera, get a camera. Bought subsidized from Metro/T Mobile, it's not too expensive.
Lost phone in Airplane Mode - Help!!
Next time you want help, please don't be disrespectful to others making an effort to help you out. If it's not the outcome your looking for, then just Simply ask more questions without the smart remarks. Members will not want to help with that kind of attitude.
So let's keep this thread to a more calm and respectful discussion. We get your frustration, but don't take it out on the members trying to do their best to help you out.
You did not tell me anything. I'm not signed up for any of the services in that article and I doubt most people are. If you have any other suggestions, pitch it up. otherwise, have a nice life..I'll get somebody else that knows what they are doing to help.
Ciao.
Help Signing in with Google
Seems like I have had a Google problem that I discovered. I was sometimes getting getting requests by Google to login on websites, even though I thought I had disabled that option in my Google account. Well, somehow, I am sure by my fault, I found that I had two Google accounts active on my phone. It seemed that it looked like both were set to sync. I deleted the secondary Google account. I then in a short bit, hit and miss, phone text replies were sometimes missing from some people. I guess Google (Google Drive?) can or does store phone text messages. I had also noticed that sometimes I was getting my Google headline news on my Google search page in addition to that dedicated page when you swipe leftfrom the home page. Sometimes that was missing. I was also having trouble when I clicked on some of the stories. Some would open in the page as you would expect. Some would display below all of the headlines. It is my best guess that I had two Google acvounts running simultaneously, conflicting with each other, one storing some info. when in control, and the other when it was in control. That also explains the differing Google headline handling as well as sometimes getting webpage login requests. The solution, the best one anyway, might be a clean factory reset and reinstall of apps, testing one by one for other issues I had been having. I can do that after the first of the year when I get my Note 8 cleaned up, factory reset and working asmy main phone while this is down. On factory reset of this phone, restarting will also require that I do not let the second Google account be added. I think I am on to something.
Danny
Help Galaxy A12 Do not disturb Mode
I have a Samsung Galaxy A12 phone with the Android software version 12. Every Sunday I want my phone ringer to be shut off at a certain time for an hour. I've tried to do this with the "Do not disturb" feature. It appears to work fine, but I don't want to get a notification saying my Do not disturb mode is on every time I use my phone. I know it's on and it's a permanent setting for my needs.
I can't seem to get it to stop popping up in my notifications. I've tried to use the System UI Tuner App, but it says i's not supported. So is there a way to fix this? Or is there another App that does give you control over the notifications?
Missing Calls
Also make sure Do Not Disturb isn't on by mistake. Some Samsungs try to become self-aware these days and have 'adaptive' features such as auto turn on power save and auto enable do not disturb for some reason.
Also, FYI the A-series are budget devices and are not known for being the most reliable handsets. Unfortunately if you cling to expandable storage and headphone jacks as I do, they're the only 'modern' option left.
A word of caution. Calling Tracfone's tech support is a stress-inducing nightmare. You'd have less frustration debating a Christian about Athiesm. Their reps are very much in love with their scripts and treat people like they're idiots. I've had them repeat, over and over again 'try turning the phone off and back on!' even after I told them "hey, I tried that before I called you!"
Changing locale works in debug version of app, but only updates to EN or ES in release version?
Apparently by default they are! After looking it up, I simply disabled language-splitting within my build.gradle file, and now all languages that I give as options work perfectly!
Good news. If you're free and willing to help me, check out my free app and leave a 5-star, please. It's available on Google Play Store and just for a development exercise. Thank you in advance. :D
Notifications read on PC don't clear notifications on the phone.
Yes , if I swipe the notification it dissapears. But messenger i.e. acts strangely, as each time I receive a message, I get a notification on a badge, then I open MSG read it inside the app so the font of that message is no longer bold (meaning I've read it), I go back to main screen but the notification on the badge stays in its place as it was before. Only pulling down the notification bar and swiping it right clears the badge.
I made a separate thread on Motorola's forum too, I'm waiting for reply.
Filter
