Blu J5L G5 C5L2020 A5L Studio x5
Heres what they told me about there zte blade A31lite. I think the standard A31 and A31 PLUS 6" phone has t-mobile compatible on the ebay link pics but is as big as my g power 2021. Read the ebay message i received from them about the A31 lite international model. May have been on amazon reviews. I was looking for a smaller zte phone similar to my quest 5. The A31Lite was the next option zte told me unfortunately they didnt sell them outright and i think said that the phone may be compatible.
Tho this seller lists as tmobile compatible 1gb 32gb zte blade a31 lite international model.
ZTE Blade A31 Lite 32GB 4G LTE GSM Factory Unlocked Android Smartphone New | eBay
ztea31lite-jpg.164569
Ransomware
Oh I run Windows 11 too on two systems (another runs Vista, and one runs XP) but I prefer the UI of Vista and XP over anything 'modern' but I credit Windows 11 for at least attempting to reboot skeuomorphic UI. Still about as half done as Windows 10 though. Stops at icons.
I longingly await the death of flat UI design.
I'd steer clear of MalwareBytes though. That Crapp has caused the PC at work to run like an i486. It chews through RAM, makes it freeze every 8 hours, and has somehow redirected Google searches to some foreign clone (results are quite hilarious though).
I'm convinced it's either malware or owned by Cheetah Mobile with how it affected the system. If it's not doing the above it's slowing the system down popping up endless things about updates. I hate it. I turned it off three times but stupid boss keeps re-enabling it. I never heard of it until I saw it in action, but I'd rather stick with tried and true Norton or McAfee.
Resetting phone, unlocking?
However when setting up i skipped the setup and never signed into my google account on either phone.
Unless you've gone through the process of loading a custom, third-party ROM on an Android phone, the first time you start it up the setup process requires you to enter a valid Gmail address and password. It's not something that you can just ignore and skip past.
When you just did the Factory Reset on those phones,what you should have done is go into the Settings menu and remove your Google account first, and then do the Factory Reset.
Help Change Knox Guard State
lol.....the op already has a post there:
https://forum.xda-developers.com/t/how-to-change-knox-guard-state-from-active.4520279/
so a "custom FW" means a custom firmware, correct? which basically means you have a custom rom installed, yes? if so, do you have a custom recovery as well?
Its actually a stock firmware which is basically an intermediary FW to prepare the device to be flashed to the final FW of this provider. However, to flash the device to the final FW, I need to get rid of this Knox Guard in Active state. Not sure how to do it. I tried somethings I saw online like changing the date to avoid the 7 days lock in period but got no luck.
32gb phone + micro sd 64-128gb expandable storage use
The camera has an option for saving to sd card. And files select all photos has an option to move all to "internal storage" im guessing if i had an sd card inserted then it would possibly have the move to sd card option.
That would leave me with 22gb taken up with 7 apps i use that dont come installed on the phone and 10gb free.
One thing i will say is my zte quest 5 would often crash and this one has snapdragon 662 processor either 2.0ghz motorola had told me and seems alot faster then the 16gb quest 5. It is a bit larger by 1.5"
Possible to cast from Android smartphone to Chromecast 3 without use of dedicated WiFi/router
This looks promising...!!
Nice. I'll try this out as soon as I get the time.
Also a big thanks to all the others in here, sending advice and even screenshots.
Thanks so much for helping out and pointing me in the right direction. :) Highly appreciated.
And apologies for answering a bit late but I was a bit tied up in the past days.
I'll report back here with the result.
Thanks to you all once again...!:)
[FREE] [APP FOR KIDS] Little Stories. Bedtime Books
little-stories-bedtime-books-150-png.5337267
The “Little Stories” series present fairy tales, in which your kid plays the main part. It's quite simple – just enter your kid's name and gender in the settings window and enjoy reading fairy tales about your son or daughter.
To make it even cooler, we've added beautiful melodies and wonderful pictures to help you raise your child by giving him or her only positive examples.
Let love and kindness fill your family leisure to make your life and the world around happier!
Download in Google Play Market
Why “Little Stories”?
• No analogs in the world!
• 21 exciting fairy tales so far and more to come
• 1000+ pictures
• Gender determines the choice of illustrations
• Nice music accompanying each story
Hello!
I am Mark Daniel, I was download this story on google play store and read with my kids. That is very good end interesting bedtime story for girlfriend kids. I appreciate of its creator.
Thanks
How Does Google Assistant Track Stocks Daily?
Somehow I set up my Google Assistant to track a particular stock symbol every day, and Google sends me the price as an Android notification once per day. How do I maintain that stock list?
Various references online suggest you need to maintain a watchlist on Google Finance. That is definitely NOT the source of the stock I am tracking. My Finance watchlist has a short list of stocks created years ago and Google Android seems to have no knowledge of that list, or at least it does not use it for daily notifications.
In "All Assistant Settings" there is a section named "Stocks" but when you enter this section there are no controls, and nothing is listed. It looks like the section has been disabled somehow.
So where in Google Assistant am I supposed to maintain a list of symbols to track daily? I am running Android 13 on Pixel 6.
Filter
