MLB PLayoffs 2022
I still think we should have put Hader in when they new Bryce Harper was up next at the end.
VLC Media Player?
I would love for the tech to work better than it does. They are called aids for a reason. I hope that you can solve your battery draining issue. <LinearLayout
android:layout_column="1"
android:layout_row="0"
android:layout_width="300dp"
android:layout_height="40dp"
android:layout_marginLeft="40dp"
android:orientation="horizontal">
<TextView
android:text="Run For:"
android:textSize="30dp"
android:layout_width="0sp"
android:layout_height="match_parent"
android:layout_weight=".5"
android:textAlignment="center"/>
<Button
android:id="@+id/btn_down"
android:layout_weight=".15"
android:text="-" />
<TextView
android:id="@+id/run_time"
android:layout_weight=".2"
android:inputType="number"
android:text="0" />
<Button
android:id="@+id/btn_up"
android:text="+" />
</LinearLayout>
AppCompatTextView runTime = FindViewById<AppCompatTextView>(Resource.Id.run_time);
AppCompatButton up = FindViewById<AppCompatButton>(Resource.Id.btn_up);
AppCompatButton down = FindViewById<AppCompatButton>(Resource.Id.btn_down);
up.Click += delegate
Int16 time;
if(Int16.TryParse(runTime.Text, out time))
if (time < 10)
time++;
runTime.Text = time.ToString();
down.Click += delegate
Int16 time;
if (Int16.TryParse(runTime.Text, out time))
if (time > 0)
time--;
Issue has happened again, except it doesn't say No Photos this time. In the Photos tab, all I can see where there should be photos is a random date a few weeks back although my most recent photos were taken yesterday. When I hold down on the date it apparently selects 5 photos that are nonetheless invisible in this area (see attached screenshot).
The photos are still in the Library tab, and when I log into Photos on desktop, all photos seem intact in the Cloud (and indeed, on desktop Cloud I can see the 5 photos taken on the aforementioned random date).
It's just the Photos tab in the Photos app that's gone wonky so seems it might be an interface/UI issue. Tried clearing cache and restarting phone. Who can figure out how to get the photos to reappear?
I have disabled hardware encoding and decoding and this seems to have fixed it. Thanks
tell that to my z fold 4![]()
