Best video editing app
I am using a Samsung Galaxy Tab S8 Ultra.
I used to use kdenlive on my PC, but I'm now living in a motorhome traveling around and it is easy to keep my tablet charged. I can't use my PC unless hooked up to power.
I was hoping for decent Android software but they are only good for 10 second clips by the looks of things.
The lightweight video editors on mobile are only really good for very short-form content, like for TikTok or something.
I make some videos for lessons, but I'm using iMovie or Final Cut Pro on a MacBook.
Help Tablet Samsung Galaxy A8 32GB
Give some thought into your quest to move apps from her tablet's internal storage to a microSD card -- keep in mind this is not an optimal solution to add storage capacity, it is a workaround kluge. Current microSD cards are quite robust now and adequate as cursory storage media, but she's better off having more internal storage memory to begin with. If upgrading to a tablet with more internal storage isn't viable however, using a microSD card does involve some compromises
-- microSD cards are faster now but still not as quick as just relying upon internal storage, so basic reading and writing of data (mostly writing) is always just a little bit faster when it involves the internal storage. Yes it's just milliseconds in difference but this applies to everything -- interactions between the operating system and apps, copying/moving/deleting files, etc. -- so depending what she may or may not be actively doing there 'could' be some lag on occasion.
-- some but not all apps will be able to be 'moved' to the card. A better, more accurate term will be 'split' Some apps have to be left as is, requiring only internal storage. Those apps that you can 'move' are actually divided with part staying within internal storage and part on the card. So yes you free up some storage space in the internal storage but at that point it's now a matter where she has to leave that microSD card always within her tablet. If she does use the card to manually transfer files and things to her computer/laptop or her phone, once she pulls the card out that creates a situation where those split apps are now unable to function properly until the card is back in place.
But those caveats may or may not even apply depending on how she's using her tablet. And that's the thing, we all use our mobile devices differently to do different things. For the most part though, evaluate just how much impact 'moving' apps will help. Unless she has installed a really sizable number of apps, even the total amount of apps themselves may not account for a significant amount of storage space. You really need to look in the Storage menu in her Settings menu and focus on what content is taking up a lot of storage and what needs to be left as is.
Just making idle assumptions, there's going to be a lot of saved photos, videos, and music files. Those will typically take up a lot of storage space, especially in aggregate. Especially video content, if she has a high res (i.e. 4K) video file of a movie saved, that itself could use 2 or 3 GBs of space (lower res videos are still sizable but not as much) Use the 'My Files' file manager app to move or delete files and folders. (Samsung includes that handy, but basic file manager with its devices).
Regarding deleting whatever apps she doesn't need or use, that's going to be a conditional matter. Apps she's installed will be removable, but there are going to be a number of apps that came pre-installed by Samsung that won't be Uninstallable by you.
Help app data backup
Thanks guys, there are a few apps that are registered to an old number but currently work and I can't migrate it across to the new phone. Easiest way I used to use was Titanium but that was in the rooting days. Also linked to old social media accounts that I no longer have access to. I'm assuming it isn't possible without root was just on the off chance if someone knew if there was a way
Using Hey Google to cancel an alarm
Hmm, maybe it's cause I didn't say "henceforth"... I didn't think of that! LOL
@Unforgiven , I always create mine via voice command, so that's not it. Thanks for the note, though! I'll have to remember it.
@Milo Williamson , I'm not sure what you mean about the volume. Do you mean to lower the volume enough so that OK Google can hear me? If so, that wouldn't be the issue since it replies with "you can do that in the app".
Phone's volume all the way down before heading out,ergo you would not have that problem..
Slow charging Samsung A02s
The night before last I was practically going crazy because the A02s was not charging. I tried assorted combinations of cords and wall warts to no avail. In desperation, I used the Stylus setup, a complete nono I'm sure, and it worked. It's still not the best but sort of ok for now. The flashlight remains woobly...oh well.
pictures only to myself removed+fix?
I believe your right, about Verizon and yahoo. but the vpn link is for cell phones right? If i am sending it from my pc should not the vpn be on my pc? I am not to familiar with vpn!!!
You can get Psiphon for PC(Windows) as well. https://psiphon.ca/psiphon3.exe
Psiphon is really the only free VPN I actually trust.
But I use Astrill VPN and Nord VPN(both paid) all the time myself, on phone and computer because I'm in China.
Help Files disappearing
I would have no idea how you would test this, unless you had a file you knew would disappear and a control file you know would not. The only thing I can think of is to run a memory diagnostic test on it... but that may brick the phone by overwriting the operating system. If it's under warranty, you may want to back up your data and talk with Samsung. Usually their first solution is a factory reset.
keyboard changed language
Still don't know how at the same time I picked up an unknown contact.
Which email service are you using? (i.e. Google's Gmail? MS Outlook? Yahoo Mail? etc.)
Along with email that usually also determines things like Contacts and Calendar. As an example, Gmail includes an annoying option buried deep in your Google account settings menus that you need to specifically disable, "Save contact info when you interact with people." It's just another way Google does its data mining (a 'trick' to automatically add contact entries to your list that you don't necessarily even want to save). So try looking in the settings menu related to your email service for something similar. Things like this are now typical, our personal info is the price we need to pay to use 'free' services.
Filter
