Help ebook downloader from apk on bluestacks
just an fyi apk are a file format that installs android apps to your device. most computers should be able to handle ebooks, there is no need to use an android app to do this. i don't know any of the apps you listed, but i'm sure they have websites where your pc can access them.
four apk that i told above is only on android
https://play.google.com/store/search?q=ipusnas&c=apps
https://play.google.com/store/search?q=eperpusdikbud&c=apps
https://play.google.com/store/search?q=ibi+library&c=apps
https://play.google.com/store/apps/details?id=com.appsfoundry.eperpuswl.id.telkomsel
Android Dumbphone?
That member hasn't logged on for a year, so it's unlikely they will answer your question. But my impression (on a very quick scan of that post) was that the latter two show Settings > Apps, which may well be after removal, while the first shows a home screen with just a few icons on it. You do not need every installed app to appear on the home screen (for that matter you don't need any of them there if you don't want).
To be honest though the first one is a poor screen layout: if you just want a few icons on the screen you can put them at the bottom of the screen, where they are easier to reach, rather than up at the top. It's only iOS that forces you to fill screens from the top, and that's one of the most stupid features of that operating system ;).
There is no particular layout here. Based on the layout of the icons seems to be deducing that the reduction of clutter is the aim of the dumbing-down, which is not. Rather, the central aim to dumb-down a smart phone, and in the process create as many as possible difficulties to installing or enabling any applications, except those that are really essential, according to the needs of the individual.
Help Are these two whatsapp the same?
The Samsung launcher is called One UI Home on recent devices - it was probably called TouchWiz on older ones. On my s21 I can access its settings via Settings > Apps > One UI Home and from there there is an option One UI Home Settings. But searching for "home" or "home screen" in the system settings also produces this.
For the Android 12 version there is an "app icon badges" switch in there, can't say for older versions. I don't actually use the Samsung launcher myself, so don't know much more about it.
Build a basic app
I Could build an app with 10-20 buttons with links to your favourite websites.
very quick and easy one to build.
just got around to building it today
here my git hub account, feedback would be great if anyone want to download it and look at the code, took me just under 2 hours
https://github.com/JasonEdwardesUk/Websites/find/master
I need more practice at github(branches etc)
[Free][App] World Clock
I want to share with you a new application. It helps in dealing with time zones and time differences. It works simply) You add any cities, and the application shows the current time in these cities. The application will be very useful for you if you often travel, or call up with loved ones, or work in other time zones! Try it, you will need it!
https://play.google.com/store/apps/details?id=dev.metamodern.timezo
Help How to logout chrome?
I want to use the android chrome browser without any google login. I press the top right round button (in screenshot example) and the menu does not have any way to logout.
Do not have sign out button on android chrome. (There is a sign out button in pc chrome, but not in android chrome.)
android chrome screenshot https://i.imgur.com/za2B0MA.png
1. How to log out in android chrome?
2. how to remove the 2 other rows "session expired"
Hmm... Season expired, presuming that session did expire on their own, never in my years I did get that error message, probably with someone else sneaking in, try logging out of all accounts, before anyone did attempt to, could be a glitch on that end, how many devices did you log in from your accounts?
If you have multipule log ins on different devices, sometimes when they do idle, then it will say "Session expired.." Try logging out of your different devices first, and limit yourself with that, see if that did help out.
2) You want a Chrome browser that does not allow that, I am afraid the only exception is either fire fox or even edge itself..
Help My Samsung A71 is not charging. I need help with a decision.
https://www.gsmarena.com/samsung_galaxy_a71-9995.php
Non removable battery.
Time for a new phone.
Depends on where in the world you are, what country you're in, as to what repair techs might charge you.
Where I am, China, new battery for a Samsung is probably equivalent of $30, and can usually be fitted while you wait. And for a Samsung A71 that's less than two years old, is definitely worth getting it repaired.
Yeah, If it were that price it would be worth it. I am in the UK and from what I can tell people charge about £80 to see what the problem is.
Filter
