Phone won't start.
Force Restart your Phone.
Do a Hard Reset
Re-Flash the Firmware From Scratch
If you tried all the things to turn on your Phone and still your Phone will not start, go and visit the phone repair store in your neighborhood Or It might be time to shell out for a new smartphone if all else fails. If you are from the USA, I would suggest iFixScreens.
Ufed and fde , fbe encryption !
Well there are some mitigating factors to your paranoia on UFED
-- Cellebrite, the owner and developer company for UFED, only sells its product to governments and law enforcement agencies so any bootlegged copies someone does buy off of source like eBay will be unsupported and unlicensed. So simply because someone may actually buy the product, that doesn't mean they'll actually be able to use it. Possession doesn't automatically and magically add knowledge.
-- Of course it's a remote possibility someone (i.e. retired cop) who has worked with UFED in a work setting and knows how to use its various modules will buy a copy and go out in the world snapping up people's phones to extract data, but that's something that's more prevalent in TV shows and movies. Here in the real world if you're really so fearful there are people lurking around and waiting to get your phone, it's time to stop using it. Remove the SIM card and any microSD card, go into Settings >> Accounts menu and delete your Google account, then do a Factory Reset and destroy the phone with a hammer.
Personally I think you're being too apprehensive on this matter and should just ignore all the fear mongering in the news media and such. Yes there are some really moronic people all around us who have no problem using something like a bootlegged copy of UFED to exploit others, but their numbers are really minuscule. Just be sure to always have a lock screen enabled when you are out in public, don't leave it just sitting around unattended, and stop letting other people borrow it.
Thank you
Phone contacts on SD Card storage. (Waiting for new phone)
Well any previous postings I made were based on the postings you had made so anything before the revelation you don't have a good WiFi no mobile data connection takes priority. At this point, I'd suggest you have somebody who is tech savvy to look into the matter as setting up something like syncing contacts should NOT be such an arduous task. Diagnosing anything over an online help forum with only some necessary info is a problem when there are relevant details in question as opposed to just a quick hands-on evaluation of what is and isn't working that might be the source of the problem -- i.e. at this point it still needs to be determined if your WiFi connection is working (are other apps and services working out OK now?); when viewing your Google Contacts list is all your data showing properly (phone numbers in the phone number boxes, email addresses in the email address boxes, etc.); are other Google services syncing or is it just Contacts?
Oh as for what you're perceiving to be a contradiction, it's not a matter where you need a lot of bandwidth to sync something like Contacts listings, it's just text data. A 1Mbps connection is quite adequate. In contrast, watching high-res streaming video does require a good amount of bandwidth, typically 25Mbps or more. So you do need a stable, reliable online connection for anything as fundamental as contact syncing, but it's also conditional because different tasks require very different amounts of online access speed.
The same contact appear online in one phone and not online in another
Hi!
i have two phones, the personal and the one for my job, both have the same whatsapp version.
One contact in specific, appears online in my second phone, and not online in the main phone, why is that?
Perhaps that person has two phones also?
I have received messages, lets say at 1pm and the last seen for that contact is 8am (WA didn't updated his last seen on my main phone) yet on my secondary phone he will be online (your situation). Another weird situation is that I will appear online at 3pm but my phone has been with the screen off since noon but this can be also due to WA web or WA desktop, which I use both on my computer (one for each phone), and when you close your browser or app, it takes time to update the online status.
Also, I don't think WA updates the info instantly for every user.
All In One Free PDF Scanner & Merger App
Scan4PDF is a Free PDF Scanner & Merger app that can be used for various purposes. It allows you to scan your documents and convert them into PDF documents quickly.
This Cam Scanner merge pdf app can also merge multiple PDFs into a single PDF in a matter of seconds.
This will saves your time and make it easier for you to read the PDF File.
This article will go through some of the best features of the SCAN4PDF application that make something apart.
You can easily save your PDFs or share them with friends and family.
We use abrasive technology and techniques for merging PDFs.
Our app offers a strong and adaptable user interface that is simple to use.
Our app is simply available on Google Play, so don’t waste any time and download it right away.
Free CamScanner & Free PDF Scanner App
You can scan the document with our in-app camera scanner, which uses your phone’s camera.
Our free cam scanner can efficiently and precisely scan any image format without compromising the image’s quality.
You can also select the document or images from your phone gallery and can easily convert those images/documents into PDFs.
You can easily merge PDFs by selecting two or more PDFs and clicking on the right shape button.
Our app will start processing and give you the result of the merged pdf file in a fraction of seconds,
You can easily save that files in your phone storage by hitting the save button.
Simple steps to use the Scan4PDF cam scanner
STEP #1 Open our application; firstly, you can see the login page, so you can easily log in with google, or if you don’t want to log in, click the “skip” button and directly redirect to our app’s homepage.
STEP #2 On the homepage, you can easily see the “SCAN” button; click it, and our cam scanner feature will use your phone’s camera to scan documents;
You can use your phone camera to scan documents or select the images from your phone gallery.
STEP #3 After selecting or capturing the image, you will see the crop feature. You can easily crop the part of the image that you want to choose and then click the right button to save and move further.
STEP #4 Now quickly scan more images as you want, easily save them as pdf, click save, then export them to your phone storage.
PDF Merger
With our PDF Merge feature, you can easily combine multiple documents into one PDF File.
You can merge multiple PDF files into a single PDF file.
You don’t need to install any software or download anything from the internet before you start working with the Scan4PDF powerful feature.
Steps of using Scan4PDF PDF Merger
STEP #1 Open our app and select the PDF Merge feature in the middle of the app interface,
#2 Select at least two or more Documents to do PDF Merging,
#3 After selecting files, click the right shape button. You will redirect to the next page, and there, you will see that your all files (that you have chosen)are on one page; now, to save them, follow STEP#4,
#4 Now, at the bottom, there is one column in which you have to fill/give the file name to the file that you have merged.
#5 Finally, save that file in your phone storage and share it with your friends and others.
Image To PDF Converter
Our image to pdf converter can be used for the following purposes:
Effectively and reliably convert your images into PDF files without losing any kind of their quality.
Scan4PDF supports popular image formats, like JPG, PNG, BMP, and GIF.
If you want to merge multiple images into one document with minimal loss of quality, then the Scan4PDF application is best for you.
Steps for Using Scan4PDF Image to PDF Converter
STEP #1 Launch the Scan4PDF application and choose the Merge PDF option in the upper-right corner of the app’s UI.
#2 Now choose the images you want to convert to PDF format, and at least choose MIN.2; the maximum is up to you.
#3 After selecting the images on our app, click the right shape button, and it will start processing, and in a few seconds, you will receive a pdf including all of the images you have chosen in one pdf.
#4 Now, on the upper side of the app, click the save button, where you can print your PDF or save it to your smartphone.
Use SCAN4PDF SAVED PDF Feature
If you need to save your PDFs, not export them now, but in the future, so you can easily store them as drafts and access them in the “SAVED PDF” column on the app’s main page.
In the future, whenever you want to export or edit the pdf(Like to add another document or image in your existing PDF so u can also edit that), You can easily do this using the functionality of our app. And then export them.
Exporting Feature Of Scan4PDF
After using Scan4PDF features like
➼Merging PDFs from the app,
➼Scanning documents with your phone camera’s scan functionality,
➼Integrating multiple images into one pdf.
You will export the PDF to your phone storage.
We have many features for you while exporting the PDF
You can export the file with two features Print and Save it as a PDF,
Print Feature Of Scan4PDF – free pdf scanner app
You can directly print the PDF files from the app in the print feature.
When you select the “print” feature in the app, it will automatically start searching the printers near you.
Or you can click the “Add Printer” button and start printing your PDF.
PDF Saving Features Scan4PDF “Save as PDF”
Click the “Save as PDF” button at the top if you want to save those PDF files to your phone.
Now you will get many features of exporting the PDFs on your phone starting with first,
Color: In this option, you get two options to choose whether you save it as original with color or save as in the black and white color(B&W).
Paper Size: In this option, you will find various paper size formats for saving your PDFs; you can choose the paper size, and the app will instantly display a preview result with the paper size you have selected.
Orientation: In this option, you can change the positioning of your files in the PDF between two oriented options 1)Landscape and 2)Portrait.
Pages: Lastly, you can alter the number of pages you wish to export. You can select all or a range of pages while exporting that respective pdf.
Conclusion
If you are looking for a fast and free PDF cam scanner that delivers high-quality scans, In other words, if you’re looking for the best free pdf scanner app & Merger app that allows you to scan your documents and save them into PDF format, then SCAN4PDF is worth a try. It’s free to download and use, straightforward, and also supports merging and merging multiple PDFs into one PDF file.
You can also integrate different files into this all-in-one PDF app — Scan4PDF.
Scan4PDF leverages the latest technology that most other scanner applications do not.
So why are you waiting to download this All In One best free pdf scanner app With Image To Pdf Converter and Free PDF Scanner & Merger App, simply available on Google Play Store.
All In One Perfectly Clear Photo Editing App
PixyTrim is the Perfect Photo Editing App for editing images, adding cool effects to an image, and converting it from a stable to an interactive image using the app’s editing features.
PixyTrim’s photo editing features include lighting and darkening, altering the contrast, cropping, and much more! PixyTrim photo editor took advantage of its ratio feature to be customized to the social media dimensions and shared on social media platforms such as Facebook, Instagram, and many more.
You can save your creations or share them with friends and family. We use abrasive technology and techniques for editing photos,
You can download our app easily from the Google Play store.
Perfectly Clear Photo Editor App PixyTrim’s Features Include:
Perfect Crop Image:
PixyTrim’s crop feature allows you to easily crop your pictures from left to right, up to down, as needed.
We have offered numerous sizes to assist you in resizing your images to meet your prospective requirements.
PixyTrim Offers Below Dimensions :
2:3
3:2
4:3
16:9
Rotate :
The Rotate feature allows you to rotate your pictures up to 360* degrees, and you set in your perspective needs and save them in your gallery.
Scale :
With the help of the scale feature, you can zoom the images from 12.5% to 100% per your needs and save them.
Perfectly Clear Photo Effects & Filters :
With the PixyTrim filters tool, you can customize the appearance of your images by adding the most delicate filters available in the PixyTrim app.
Our Color morphing and B&W (Black and White) features can significantly improve your images and give your pictures a more satisfactory look.
Our latest version has introduced some new elegant features to our app. You can try using them to make your images more agile. Now we present our new Special effects :
PixyTrim’s filters allow you to give your images a distinctive style and make them more attractive by simply adding effects.
Perfect Photo Editing Adjusting Feature :
PixyTrim has various adjusting features mentioned below that can help you improve and enhance your pictures :
Perfect Photo Brightness Feature
PixyTrim’s brightness photo editor app tool allows you to change the brightness of your image in seconds.
You can increase image brightness quickly by setting the brightness level from (-100% TO +100%)
Perfect Photo Saturation Feature
Saturation helps in the addition of a photo light effect to your images.
You can edit the image’s saturation by setting the saturation level from 0% TO 100%.
Perfect Contrast Photo Editing
You can make your image look awesome by using the Contrast feature by PixyTrim.
Edit your images with PixyTrim’s image contrast editor tool by adjusting the contrast level (25% TO 75%).
PixyTrim Perfect Blur Feature :
To bring focus to your images, you can use the blur feature of PixyTrim.
You can easily adjust the blur level by setting up the level of an image from 0% to 100%.
PixyTrim is the best blur photo editor app for your pictures.
Perfect Reduce Photo Editing Feature :
The PixyTrim app has the best features for compressing and resizing an image.
PixyTrim Reduce feature include :
Image Compression
Our image compressor feature allows you to compress the size of your image.
You can check the differences between the actual and expected sizes of your images.
You can easily save those compressed images in your phone gallery by clicking the download shape button in the upper right corner.
PixyTrim New Blend Feature
We have a photo blending tool in the latest version of our app. When editing pictures, blending offers additional creative options, which is very useful because it gives your images attractive effects. A parameter called “blending” modifies how colors interact with colors at lower levels in a visual effect. Your image’s overall look can be improved by just adjusting the blending settings in PixyTrim.
Features available in our Perfect Photo Blending Feature
Color overlay
The PixyTrim color overlay feature allows you to add or alter the color to your image as required. Our color Overlay feature adds color to an existing picture to make it more attractive.
Opacity
The opacity feature in the photo blend feature allows you to adjust the color opacity of your images from 0 to 100. Opacity is the measure to which everything in your pictures blocks light, and you can easily adjust the opacity of color in your image to suit your needs.
PixyTrim’s Perfect Edit Tool
Below features of PixyTrim’s perfect photo editor are available :
Drawing Tool
You can easily create or alter your images by using the app’s edit tools, such as adding lines and shapes, text and colors, and many more.
Add/Edit Colors
We offer plenty of colors to you, so you can add them to your images and make your photos more interactive and engaging.
The app offers 12 elegant colors, so you can use your ideas to add to them and improve the images.
PixyTrim Collage Maker
You can make the best collage of your images with the PixyTrim collage’s grid maker; you have more edit options for making the most delicate collage.
You have various editing choices at your fingertips to create the most pleasing collage possible.
Below are many editing options you have to make the perfect collage :
Lots of layout grids
Adjust Border width
Edit Border color
Alter Border-radius
Change Background Wallpapers
Perfect Photo PixyTrim Ratio Feature
This feature helps you change the image’s aspect ratio to meet your requirements.
The ratio feature of PixyTrim allows users to alter the aspect ratio of their image based on various social media posts and dimensions and can share easily from the app.
Below ratios are available in our perfectly clear photo editing app for modifying for various social media posts:
Facebook (FB Mobile Cover Ratio, FB Post Ratio)
Instagram (Ig Story Ratio, Ig post “1:1, 4:5 Ratio”)
Movie Screen Ratio
Twitter (Twitter Header Ratio, Twitter Post Ratio)
Youtube Cover Post Ratio
The ideal photo editing software is PixyTrim, which enables you to add creative effects to your pictures. PixyTrim is the greatest software for your photographs and the best photo editor app available for editing your photos and giving them a beautiful appearance. Your works can be saved or shared with loved ones. You may try utilizing our app’s new, beautiful capabilities that have been added in the most recent edition to give your photographs more agility. An effect called a blending setting is added to the image to change how colors interact with colors on lower levels. Simply changing the blending options in PixyTrim will enhance the appearance of your image.
The PixyTrim color overlay feature allows you to add or alter the color to your image as required, with over 20 filters available within the app to make your attractive photos outstanding from the crowd.
With the use of opacity functions available in the PixyTrim blending feature, you can add color or change the color of your image with the range of colors available in the app.
To edit your images with the best and most unique effects, try out our app, which is available on the Google Play Store. With our app, you can edit your images in a variety of ways, such as adding text, adjusting effects, adding color, and drawing.
Why are you waiting now? Use the PixyTrim application to improve the appearance and aesthetics of your image right away.
[APP] [FREE] Health period PMS ovulation
this does not collect data does it? i'm just worried that data could be collected and used to prosecute women if they have an abortion now that Roe V Wade has been over turned. sorry to turn this political, but i have a friend who lives in Texas and she is freaking out right about it. and has since deleted any menstrual or women's health app on her phone.
so i just want to make clear on your privacy policy on this app.
Thank you for your question! We understand your concern!
How do we maintain your privacy?
We know you care about your privacy and we do too! That's why all of the data collected through our app is confidential, only available to you – not us or any other third party. Your information will be stored solely on your phone so there are no worries that it could ever get into wrong hands!
Contacts to Word
This is an app that was missing from android Google Play or Huawei App Gallery.
Contacts to word is the best way to get a well-formatted document with your phone contacts.
It is good because supports ALL contacts fields INCLUDING avatar!!!
It's lightweight, does not need internet connection, no ads, it's safe, not using third party libraries!!
Also it has settings that affects the layout and the list of the exported contacts!!
The layout is good looking, printable, readable with icons for every contact field!!!
You can see your contacts on the PC as if you see them on your mobile phone.
View attachment 163445 View attachment 163446
Nice sales pitch :)
Night Light - Blue Light Filter for android
It is true that blue color provokes a decrease in visual acuity. The fact is that the rays of this spectrum are focused directly in front of the retina, which leads to blurring of the image. Therefore, it is best to avoid it at night, and your application is very useful for many. Also, if you need to change the color background in your entire room in order to study better at night, for example, I can recommend these smart light bulbs that you can install in any of your rooms. Using them, you can set any color from the rgb model, for example, at night you can set a light yellow color that will please your eye.
RPI Question
This being an Android help forum and your Pi is running Linux you might find posting your queries on Raspberry Pi's help forum will result in more and better feedback. Your posts will be viewed by a lot more people using a Pi running the same OS (It would help if you stated just which model of Pi you have and which Linux distro and version. Vague references can be interpreted in many different ways while specifics can make a big difference.)
https://forums.raspberrypi.com/
https://www.raspberrypi.com/documentation/
Filter
