Help BASIC A 12 tutorial for new user?
Well Android does dominate over Apple in the world market, something like 75% to 25%, but here in America iPhones have something like a 55% lead over Android's 45%. Even if you exclude the U.S. aberration with its really high profit margins and focus just on the world market don't forget that Android's bigger numbers are based on low to mid-range phones with their inherent low profit margins. Apple does adjust its pricing to be in accordance with a country's standard of living but on average Apple's profit margin numbers are still higher than with Android phones. So yeah, it's nice to know Android is leading in numbers of phones but Apple is making a lot more money just doing what it's been doing.
On speaker phone, screen blacks out and call drops
1. When I make a call on speaker phone and hold it in front of my mouth, after a few seconds the screen will black out. How do I prevent this?
2. Also, when I make a call in front of my computer, many times my calls will drop. If I make a call from the living room, no dropped calls. Could Wi-fi signals interfere with cell phone signals and cause calls to drop? On the other hand, I have noticed that when the other person can't hear me, this seems to occur right after the screen blacks out. What is could be causing the dropped calls? This happens quite frequently.
1.maybe try adjusting your screen timeout. or maybe you are holding the phone to close to your mouth that the phone thinks you have it next to your head and thus shuts the screen off.
2.have you tried using wifi calling?
Pixel 6 Pro
I thought the little green light indicates that an app was using the camera and/or the microphone?
You are partially correct and so was I. When I first started using my phone, the green light was constantly on and driving me crazy. The longer I used the phone, the less I saw the green light. As of now, I almost never see the light. However, you are correct too. There are different green lights, differentiated by the icon within it. The microphone and camera do illicit the light with their own icons. I'm not sure which icon the light had in the beginning. If I had to guess, I'd say a battery. (If anyone knows for sure, please correct me)
I hope this helps.
Help Strange things are even worst..
hey @Milo Williamson i'm not sure i understand what the problem is that you are having. are you talking about your homescreen? what launcher are you using?
No home screen but the app that is built in called "Moto" that allows you to customized everything, the app itself, I can do themses on it really easy but if I do the "long" customization part like go to the text, it saids it on the main page, somehow suddenly I am able to customize it just now, but how it just glitches out and have nothing to change it forever. Huh... I was set for screen shots too.
please help
just because you do not understand something does not make it strange. all of the processes you listed are just systems apps running. most of them can be explained via a google search.
here is what i found for you:
Com.sec.android.deamonapp
https://grouphowto.com/com-sec-android-daemonapp/
Com.sec.android.app.simsettingmgr
has to do with your sim card
Com.wssynxmldm
https://grouphowto.com/what-is-com-wssyncmldm/
Com.samsung.android.dialer
that is your phone dialer
Com.samsung.android.incallui
https://grouphowto.com/com-samsung-android-incallui/
Com.android.vpndialogs
https://grouphowto.com/com-android-vpndialogs/
Com.samsung.accessibility
https://www.samsung.com/us/support/answer/ANS00062641/
Com.google.android.packageinstaller
https://www.makeuseof.com/what-is-com-google-android-packageinstaller/
com.android.settings
that is your phone's settings
Com.sec.android.emergencylauncher
https://androidforums.com/threads/com-sec-android-emergencylauncher.1110961/
Com.samsung.android.app.telephoneui
that is your phone app
Com.samsung.android.messaging
that is samsung messaging app
Com.android.nfc
https://www.androidauthority.com/how-to-use-nfc-android-164644/
Help identify status bar notification icon!
yeah you are gonna need a better screenshot than that. at first sight it looks like twitter, but i am not so sure on that. the problem here is two fold. one problem is that picture sucks and really can't make out what it is. and second, there are just too many apps with notifications out there to be able to know just by looking at an icon. unless it is something like twitter or facebook, it is going to be very hard to know.
just ask the person what it is. 9 times out of 10 the icon is from a phone that belongs to somebody else. the only way to know for sure what it is is to get into the phone's notifications. if you can't get into the phone or ask the person what it is, then you will most likely only get guesses from us here.
we get this question on a daily basis, and most go unanswered.....but you never know.
Trying to get into an old phone
The version of Colornote I use is from 2010, so I never get asked for any account just to open the app or use it.
If there was an old Google Account set to sync on Android 2.3 you will get errors and endless prompts to re-login as your original post shows, but you can keep backing out long enough to just delete said account and it will leave you alone. Or force it via Airplane Mode or disabling Sync. I'm quite versed in Android 2.3's way, given it's my favorite version of Android.
Help Unable To Restore Whatsapp Backup From Google Drive
EDIT: Yes, it's the same account.
I just tried that after reading it. Unfortunately it did not work. Thank you for trying to help me though!!
Whatsapp also saves chats locally (and daily) (either SD or internal memory). GD backups are once a week, I think.
I will try this: if you haven't backed up to Google Drive since you erase that chat, you can restore that backup into another PHONE. In my experience, when you uninstall Whatsapp, local backups remain and when you reinstall WA within the same phone, it will use that local backup, compare it to GD and restore messages and media according to date.
Good luck!
[FREE] (casual) Match the shapes
Matching Shapes is not as easy as you think.
Match the shapes are fast , intense and fun with several hardish levels that include : Different Shapes , colors and Alpha.
It's all fun and easy at the Start, but when items are pilling up with different colors and different Opacity.. you will get stuck on your sit trying to beat your last score.
Google Play Link : https://play.google.com/store/apps/details?id=com.itzik.samara.apps.matchtheshapes
Escape Room Unsolved Mystery
Start the new 100 doors and escape the room game adventure! In the Best murder mystery detective game and addictive escape game for free!
https://play.google.com/store/apps/...lved.mystery.puzzle.murder.case.investigation
50 levels free to play, and a new level escape game Play FREE forever! Unlimited mysteries!
The escape room is unique, simple, and fun, but full of challenges. After completing the level challenge and moving on to the next level.
Murder Mystery and Prison Escape with two categories of 50 levels escape games. If you are on the hunt for the best murder mysterious genre games combined with a new point-and-click escape game, you’ve come to the plan to escape. Investigate crime scenes to find clues, bring suspects in for questioning and analyze evidence to catch the killers.
Are you ready to prove your detective skills? You'll use your skills of deduction to solve over 100 riddling puzzles, and mysterious cases from multiple places, and explore the criminal investigator game. What awaits you in one of the new escape games.
Start the escape plan step by step and break out to Jail doors and escape the prison and increase your brain challenge level by breaking all the prison escape puzzles in this amazing jail escape. Feel the suspense before opening every prison door in this escape adventure.
Download now and discover who murdered
FEATURES:
• Simple to play, complicated to beat free
• Examine clues and analyze evidence
• Interrogate
• Investigate crime scenes
• Logical tasks to be completed
• Various Prison Rooms
• Amazing graphics
• Best Detective game
• 50-level jail room escape
If will love our murder mystery game, puzzles, and challenging riddles, With story-driven gameplay and lots of different theories to detect for each case, you’ll be finding clues together and solving crimes.
WhatsApp 'Last seen' problem (not what you think)
The thing that strikes me in your pictures is that there isn't space for the whole of "last seen today at xx:yy pm" to be displayed, so I wonder whether the scrolling is a consequence of that?
However I've not been able to test this because I've not been able to make that text large enough on my phone (Galaxy s21) that it won't fit! I've tried everything: setting 12 hour clock (to make the date/time longer), changing font size in the app's "chat" settings, changing system font size, changing system font style, using accessibility settings to enlarge everything, but nothing has made that string take as much space as it does in your pictures! However that's my guess at what is happening there, and I suspect that if you can shrink that text until it fits the scrolling will stop.
Thank you for the reply.
Sorry for the late one from myself. I've been having a lot of bother going on with my PC so only now got round to replying.
What you said triggered something in my head & I finally got the answer.
Settings > Display > Font size and style > Front size (right at the very bottom)
On my old Galaxy S10 the slider was all the way to the left. On this Galaxy S20, if the very left most setting is what we'll call "1" then it was on 5. Knock the slider to the left and it solves this WhatsApp issue.
What I don't understand is why this setting wasn't transferred over to my new phone when I used Samsung SmartSwitch, but at least we got there in the end :)
Help Doogee X10 home/back button not working Calibration changed
Some of those are names are I think MediaTek naming, and not things I've seen in any device I've messed with, but I can work out most of them. It clearly has more than just a ROM, I don't think it's absolutely complete as I don't see anything that looks like the radio firmware (which I'd expect to have its own image), but it would be strange to put anything related to touchscreen calibration in there.
I don't know where you got that firmware file from, but a search for "Doogee X10 stock firmware" produces many sites claiming to have it (none of the top hits were visibly from Doogee themselves). I don't know this phone, don't know about its versions or regional firmware, so would advise (as if you needed this now) making sure you have the right version for your device before trying anything. The truth is that flashing the wrong firmware can do a lot worse than mess up the screen calibration (you can potentially mess the phone up so badly you cannot flash anything else).
There are apps in the Play Store that claim to do screen calibration. Unsurprisingly these seem to be a bit hit-and-miss: they work on some devices, not on others. But it's something you can try: just search the Play Store for something like "touchscreen calibration" and you'll find some some suggestions.
Help Error Ruining Friendship
If what you say is true, and I would have no reason not to believe you, I would question why she does not believe you. You can on an open website, so I'll be very honest. get a new friend.
As for iPhone vs Android, I know of NO one who has an Android and I receive all the texts (SMS/MMS) from my apple friends and reply and they receive the replies. Might be deeper than just the blame Apple thing. Might not be.
vid/pic sharing app like snapchat?
I don't know what you mean by a "widget" for WhatsApp (the camera button in the message entry field isn't a widget, but it's the only thing I can think of). The way to get a choice of lenses etc is to take the photos first, then share them via WhatsApp: either select share from your gallery app or else use the paperclip icon in the WhatsApp message entry field to select and add them to a message. That's how I normally work, and while there is downscaling and compression the photo quality at least is still better than a screen shot (I find video quality OK for phone usage, though if you compare side-by-side with the original you can see that it's more compressed). There is a photo quality setting, but I don't know whether that affects video (I don't send a lot of videos, and generally don't need the highest quality for sharing stuff this way: I'd email the original, or upload it and share the link, if I wanted that).
Signal has media quality settings (standard and high), but I've never used it for sending media so don't know about what that means in practice. The problem with any of these apps is that you need to persuade everyone you want to send to to sign up.
Another option is to use something like Google photos, create a gallery for stuff you want to share and share that with people. That will allow you to share with higher quality, but doesn't have the convenience of being integrated with message threads. As with anything, there's a trade-off between quality and convenience in these things.
How Do I follow a URL Link Displayed On a Webpage?
I still have a problem that some URL links are in drop-down menus and I can't get those menus to open.
Did you try the app I recommended in your other thread (or a similar app)?
https://play.google.com/store/apps/details?id=com.quickcursor
Is this just one single link you need to click? You could also bookmark that link so you didn't have to open the menu.
Using google maps, weather channel, etc, etc?
I have been getting ' no connection" or similar on my Android 12 phone for several months, while all other apps work perfectly in the same place at 5G speeds.
. This included Weather (Google), Maps & Maps Timeline, the Google app and several other services, plus the Google account Avatar changed to my default first name initial rather than the pseudonym thingy I changed to for YT comments etc.
More than likely not connected to your issue, but it is a phenomenon!
Filter
