New App: Max Impact Search Engine (Version 2)
- By App Update
- Apps & Games
- 0 Replies
EXTRA INFO
- Rating: 0
- Installs: 1+
- Download Size: 3.9M
- Version: 2
What the US needs to do is enforce the laws that are already on the books.
Chicago, with some of the toughest gun laws in the country, have had 224 killed, so far, in 2022.
https://graphics.suntimes.com/homicides/View attachment 162757
Íts a novel idea, but why not keep people that are charged with homicide in jail, until trial, rather than letting them out to kill again.
It's a true statement that when guns are outlawed only outlaws will have guns.
These mass shootings aren't being done by lawful gun owners.
I have asked the developer but not had a reply yet....I'm not using an android box its a sony bravia android tvno clue, have you asked the developer? what android box are you using?
yep.....i'm all about privacy........LOLChrome? That's private, yep sure
This was going to be my recommendation as well.Try the phone in safe-mode, that is only the system apps and processes running. And if it's still glitching, freezing, and rebooting, then it's probably a fault that needs repair or replacement.
no problem, thanks, maybe someone will need and will find the link of this post.Welcome to Android Forums. Please be advised that you are responding to a thread that has been dormant for over eight years.
i can use that, and i DID use that... but why cant i use the built in android solution? why do i have to go to a manufacturers solution when there is an OS solution that should work, and has worked, and im familar with?
I use Proton VPN, and I have used Windscribe in the past.
https://f-droid.org/en/packages/ch.protonvpn.android/
https://windscribe.en.uptodown.com/android
If you're able to, I think it's high time to root it, and run a custom ROM. I will say up front that no community camera app is as good as the one from the factory ROM. But I can also say that I've never even seen such an error pop up in my time owning my us996 v20, and I got mine secondhand to boot.
Usually when websites have this there is an option to "browse" instead of drag. What happens if you click that (i.e. does it open a file browser)?I am trying to fill in an online form, requesting 4 documents which are in my Gallery. The form says for me to highlight each document and drag it onto the form. How do I do that?
My phone's OS is Android 10
