Help Is it safe to use a device that no longer receives updates?
- Ask a question
- 12 Replies
Just do not attempt Rooting basically it can really make your cell go haywire, and be careful what you honestly play with it around.
And suddenly your parent's are like "Dude you lost your skin tone?"I started it.... not you🤣
Me:
Yeah possiblity.It’s possible that the wrong account was selected during the data restore or the network connection was unstable.
I'm really sorry, I forgot I had this account and found a very old report saying the password has been compromised. Please could you delete it and the data associated with it.
Don't forget the Makers MarkWrapping up the 2024 holiday season
i have an outdoor projector that projects onto my porch. i have my chromecast hooked up to it. i also have an amazon echo speaker that i use for sound. works great!!!! so you should have no issues using a bluetooth speaker with chromecast.Is it possible to cast the audio track from Netflix to a chrome cast speaker (and ofc keeping it in sync with the video)?
If that's not possible, what is then the best solution to make Netflix playing sound on a portable speaker?
So welcome back.Just logged in for the first time in 12 years and saw this old script I did. I don’t remember how to do any of this stuff
Mariano Rivera. Sure. Jackie Robinson. Yes.The ultimate answer is 42.
it should automatically backup your screenshots. and if there a lot of photos then you will need to give it sometime to backup everything. also it will depend on the speed of your wifi signal. if you have slow internet then it could take a long time to backup. but once it is backed up, then going forward it should be a much quicker process.Since it hadn't been done it's quite a few. Also, he wants to be able to back up screenshots. It took a while for me to find where to choose backup but there's only documenrs. I made sure that was on at least. How do we tell it to back up screenshots and generally have a wider choice of options? It's a Samsung A15, maybe a few months old. I'm not sure of the Android version but I bet 12 if not higher.
Almost did today, you bums!!!Already washed it machine wise..
Seriously a slippery bath since I was born, always fret of falling.
Our quick question is:Hi
1. If I want to buy a tablet that only has the wifi feature (e.g. Samsung S6 Lite Wifi version) and no sim card slot tray, how to use my data sim card to provide wifi/internet to the tablet?
2. Is there some device that I can put my data sim inside then the device will give out wifi signals, so that my tablet can connect to the wifi signal to connect to the internet?
3. Is there some device that I can put my data sim inside then I can connect a cable from the device to the tablet usb port, so that my tablet can connect to the internet?
4. Does this type of device work https://www.amazon.com/300Mbps-Hotspot-Devices-Portable-Business/dp/B0D5R2B6DW/ref=sr_1_14
5. Does this type of device work https://www.amazon.com/NETGEAR-LTE-Broadband-Modem-LM1200/dp/B08R813HLW/ref=sr_1_8
Thank you
👍 I totally agree. It's taking all my willpower to stop myself from going on a political rant about the oligarchy. 🤣Oh aye. In a profit-driven system it's essentially inevitable once any company gains any significant market power, since corporations are legally obliged to be entirely self-serving entities.
