Help Screen won't rotate, stuck in portrait
- By Unforgiven
- Smartphones
- 5 Replies
Wow, google photos for the win. Here you go.
just games? i would go with one of the bigger battery phones then. they got good reviewsyes for games
Yes it is a far complicated app though, Thom did an amazing spot on description of it a while ago he said "Well with Textra on it's own can sheild everything and have such an unquie shape to the app...." Something alongst those lines. Still it works all the time and do not delay itNo, first I'm ever hearing of it. Will my texts come through if texted to my phone number?
Hi!
Thanks for such a great app!
My daughter is 3 years old and I turn it on often before going to bed.
Saw you on the forum by chance
Glad to meet you here!
Updates often had an "optimising apps" stage on other phones which would happen after the reboot (and could be slow). I think the Pixels, with their A/B system partitions, do all of that stuff before the reboot.
It was never that fast on my Pixel 2, but as you could carry on using the phone while it was all happening that wasn't a big issue.
ThanksI created a channel for your app. Thanks for sharing and good luck.
ok then fish only tanks.....water changes are the key to keeping good water quality....as well as not over feeding.Yes, just for the fish. Thank you very much for such a comprehensive answer
