Help Can't Access Location
Try clearing your Chrome browser cookies, and/or try another browser. I looked at the Harris Teeter site with Firefox, but didn't see anything about location.
Do you allow any website to access your location?
I ask because I thought of doing this test myself, then remembered that I deny location access to all of my browsers (because I can't see why I'd want to let any website access that) and so I would never see the question anyway.
S22 Ultra demand could outstrip supply
The current pre-order situation, direct from Samsung in the U.K, for delivery on the 25th February for the Samsung Galaxy S22 Ultra 1TB model.
Other storage capacities for the S22 Ultra are, by-and-large, available as are the S22 5G and S22+ models.
Reports are that there is around a 4-5 week delay on the custom colours.
Some other countries are reporting a similar situation.
See... https://forums.androidcentral.com/e?link=https://shop-links.co/link/?exclusive=1&publisher_slug=future&article_name=ac-vb-p-0&u1=UUacUvbUpU0&url=https%3A%2F%2Fwww.samsung.com%2Fuk%2Fsmartphones%2Fgalaxy-s22-ultra%2Fbuy%2F%3FmodelCode%3DSM-S908BDRDEUB&token=h1Ky2OWm
(N.B. The 1TB S22 Ultra model and custom colours are only available direct from Samsung.com)
Vertical Constraint Widget Issue
I was able to uninstall Android Studio and then install Android Studio Arctic Fox | 2020.3.1 Patch 4.
This does seem to resolve the issue I was having but if I try to open my project I get the following error "This version of Android Support plugin for IntelliJ IDEA (or Android Studio) cannot open this project, please retry with version 2021.1.1 or newer." If I create a new project, I don't have issues.
I tried to create a new project and migrate my files over but then I ran into Gradle issues. I may just reinstall 2021.1.1 and adjust the margin settings in the layout code view and hope it gets fixed at some point.
huawei nova 8i google service rom
you would have to root it first. pretty much all things rooted, you should do your research over at https://forum.xda-developers.com/. it is a developers forum where the devs post their goodies with things such as how to root certain devices as well as custom roms. unfortunately i could not find a forum for your device. sooooo that means that there is no dev community.
just remember that no devs= no fun.
here is what you need to do:
1.unlock the bootloader. some devices just needs an oem unlock to be enabled. some might need a code to unlock.
2.install a custom recovery usually twrp is the best out there.
3.either flash SU or use magisk to gain root
4.make a nandroid backup using twrp.....don't know what a nandroid backup, just ask
5.flash a custom rom.....if there is one avalable for your device.
also keep in mind that not all devices are rootable.
and there is no stock android.....use there are basic code, but what your are talking about is a rom. and yes there are stock roms that can be flashed, but they are very device specific and will depend on the manufacturer.
hope that helps.
Help Pixel 4a 5G muting without activating mute
Thanks! I will try to do that but I rarely know when I am going to get a long call. I seldom initiate calls. Keep in mind the mute symbol is not activated AND I don't have to hit the mute function to unmute it. I just have to select "back to call".
My Pixel 4a has developed the habit of switching to mute at various times, including when I answer the phone, while I'm speaking, and generally random times. I have read this thread, but are there any other thoughts?
Apps alarmManager and work manager are unable to show reminders correctly
Subject:
Issue with alarmManager and work manager
Reminders are missing randomanly and mutiple reminders are comming for particular session, we have used alarm manager and workmanager for populating the reminder.
Description:
we are developing a healthcare app where we need to populate the alarm notification at a specific time like in the morning, afternoon, evening, night.
case 1 : Missed Reminders when the app is in deep sleep mode or in the idle state we are not getting reminder on all version of andorid till android version R.
case 2 : Mulitple reminders are coming when the device is actice during that time we are facing multiple reminders.
For alarms we are using.
1. Room Database for storing the alarm time.
2. Alarm manager's setExactAndAllowWhileIdle() method we are using for setting the alarm.
3. Broadcast reciever for getting the pending intent and showing the alarm notification.
4. Workmanager we are using to set alarms in the background.
if anyone can help us out how can we populate alarm notification at particular time, doesn't matter if mobile is in deep state or idle.
we have gone through with mutilple solution for it but it seems to us nothing is working properly.
Filter
