sign up to heytap?
Before it updated, were you signed into an Oppo account with your phone? Because they moved Oppo ColorOS cloud accounts over to Heytap, which is a third-party cloud services provider that Oppo(BBK) now uses.
More information here:
https://support.oppo.com/en/answer/?aid=neu7839
"HeyTap Cloud/OPPO Cloud are terms that can be used interchangeably.
OPPO Cloud is now migrated to HeyTap Cloud Service to provide users a secure and reliable cloud storage space. Everything you store—photos, videos, music, contacts, messages, notes, browser bookmarks, calendars, and other personal information—can be conveniently accessed and managed in HeyTap Cloud."
I believe it's similar for Realme, Vivo, and OnePlus phones as well, as they're all from the same manufacturer. BBK.
Samsung Galaxy A32 5G - carrier choice?
I just got a Galaxy A32 5G from TracFone and was told by TracFone tech support that it's on Verizon's network. I would prefer to be on the AT&T network as they have better coverage in my part of rural Minnesota.
Am I correct in assuming that this phone will work on the AT&T network if Tracfone sends me the correct SIM card?
Thanks
The phone definitely has both CDMA and GSM capability. Whether it works with an AT&T SIM would depend on whether it will accept an AT&T SIM by default, or if it only accepts Verizon SIMs by default and would need to be SIM unlocked in order to accept a different SIM.
Android Studio error: "CocoaPods not installed or not in valid state."
Where does Android Studio expect to find CocoaPods? Could this be a path problem?
I have Bumblebee 2021.1.1.
I'm trying to test my app on my iPhone from Android Studio. The error I get is
Warning: CocoaPods not installed. Skipping pod install.
CocoaPods is used to retrieve the iOS and macOS platform side's plugin code that responds to your plugin usage on the Dart side.
Without CocoaPods, plugins will not work on iOS or macOS.
For more info, see https://flutter.dev/platform-plugins
To install see https://guides.cocoapods.org/using/getting-started.html#installation for instructions.
Exception: CocoaPods not installed or not in valid state.
I ran gem list and the list of installed pods include:
cocoapods (1.11.2)
cocoapods-core (1.11.2)
cocoapods-deintegrate (1.0.5)
cocoapods-downloader (1.5.1)
cocoapods-plugins (1.0.0)
cocoapods-search (1.0.1)
cocoapods-trunk (1.6.0)
cocoapods-try (1.2.0)
I ran
sudo gem uninstall cocoapods && sudo gem install cocoapods
I ran
flutter clean
I restarted Android Studio.
I ran File > Invalidate Caches… > Invalidate and Restart.
I ran
brew install cocoapods
brew link --overwrite cocoapods
I ran
cd ios
pod install
This threw this error:
[!] CocoaPods did not set the base configuration of your project because your project already has a custom config set. In order for CocoaPods integration to work at all, please either set the base configurations of the target `Runner` to `Target Support Files/Pods-Runner/Pods-Runner.profile.xcconfig` or include the `Target Support Files/Pods-Runner/Pods-Runner.profile.xcconfig` in your build configuration (`Flutter/Release.xcconfig`).
I tried to open my Android Studio project in Xcode and got this error:
Could not open file.
What should I do?
Help 10" NuVision Android tablet not booting
I was given a 10" NuVision Android tablet (TM101A620MPPM) that I'm hoping to rehabilitate and possibly install a custom ROM on. I've done 3rd-party ROMs before, mostly LineageOS, but I haven't been able either to get this tablet to boot or enter state where a computer (or ADB) will recognize it.
It makes no difference whether I simply power it on, or power it on holding the volume button either up or down, it turns on, displays the NuVision splash screen ... and hangs. I've left it sitting for a day or longer in that state and it's only ever got beyond the splash screen and to the juggling balls once. On that one occasion it took a couple of hours to get to the juggling balls but then hung there for another day without proceeding further.
I've also been trying to establish communication with ADB, ... without success. I've used multiple computers, Linux and Windoze, and multiple USB cables connecting to the various USB ports. In no case has any of the computers recognized that there was a USB device attached, nor has "adb devices" shown it was connected.
Is there anything else I might try to revive this thing, some secret incantation, sacrifice a yellow rooster under a gum tree during a new moon, etc?
How to integrate photoshop presets in app
Hey, so i'm looking for ways to use a photoshop action that i made and make my own app for those actions so that users can convert their images using my photoshop actions.
How can I do this? Where do I start and what should I look out for.
Hey, Hope you are doing good in 2022. I'm doing the same project that you have mentioned in 2019. I'm creating an android app for filters and I have created some filters in photoshop. Now I am finding ways to use these action files in android studio. So if you solved this problem 3 years ago I hope you can help me in this regard.
Reading the other replies seems like no one wants to help on androidforum.
Cases Pixel 6 Pro Accessories Reviews
I'm using a Whitestone bonded screen protector which works perfectly with the fingerprint sensor. A Ferilinso soft clear case with supposed military grade drop protection. I like both. I tried a dBrand case which protected better but weighed a ton.
Finally I'm using a Sinstar attachment which lets me use my 3.5 mm earphone plug and charge at the same time. It is very clean with the earphone but if I plug in or unplug the charging cable while using the earphones, the music shuts off.
Android phone cutting out during automated messages
Hello everyone, I have an LG smartphone model LG LML212VL, that is running Android 8.1.0, and is using Tracfone Wireless Pay as you go plan for service, and it has a strange issue that I cannot find any cause for....
Whenever I make a call, and get a robot (automated answering system) providing options, or menus, it cuts in and out, making it so that I cannot hear the instructions, and it cannot recognize my responses. :(
Basically, what I hear is bits and pieces of instructions, and 'I'm sorry, I didn't get that, lets try again' over and over until it either hangs up on me, or connects me to a live agent. o_O
If I am connected to someone, it is a good thing truthfully, as I would always rather speak with a human being than with a recording, but oftentimes, this is not the case, and I am missing out on accomplishing goals because of it. It is a real problem, mainly because SO MANY companies nowadays have robots answering their phones, long before you are allowed to reach an agent, forcing you to jump through a labyrinth of confusing hoops in order to get anything done. :mad:
It does not seem to be happening when I am talking to live people though, and only automated answering robots, so I am thoroughly confused by this behavior. Can someone give me a possible cause for this, and if available, a fix?? :cool:
Thanks in advance!!
Help Suspicious wifi activity
OK I saw online that something similar was being done to mess up iPhones and somewhere within 50 yards is a beacon that no one has claimed in the 2 years its been here. I wondered if it was similar because it looked like the wifi disable ssid was coming from my router since I can change from channel 1 to say 8 and the green one over the ATT network and the big blue one dissappear.
That sounds like the "Free Public WiFi." Windows virus, that was quite prevalent about 10-15 years ago.
https://www.npr.org/2010/10/09/130451369/the-zombie-network-beware-free-public-wifi
And I did see it myself, while waiting for trains and planes sometimes. And the safe solution to that was, don't attempt to connect your Windows laptop to WiFi SSIDs you don't know or trust.
Filter
