Backup and Restore App for Android V-6.0.1.
- By GameTheory
- Apps & Games
- 2 Replies
Without going into too much detail, you can remove ATT apps with the following ADB commands. You need to use caution. If you remove a system vital app, you may find yourself in a bootloop. Any apps removed with this method can be restored by factory resetting or running the last two commands below.I want to DISABLE or FORCE STOP or UNINSTALL all AT&T related app
Check if device is available to ADB...
Bash:
adb devices
List all apps on device and copy the package name of the apps you would like to remove...
Bash:
adb shell pm list packages -f
Remove app package...
Bash:
adb shell pm uninstall --user 0 PACKAGE_NAME_HERE
Reinstall app that was removed with the above^ command...
Bash:
adb shell pm install -r --user 0 /PATH/TO/APP_NAME.apk
To get the apk path for the command above^...
Bash:
adb shell pm dump PACKAGE_NAME_HERE | grep path
