virtual devices not working in android studio
[QUOTE = "James_Watson, post: 8054463, member: 1776497"] Хорошо, понятно. Эта проблема может быть вызвана неправильным расположением SDK.
В Android Studio перейдите в меню «Инструменты - Диспетчер SDK»,
Или «Файл - Настройки - Внешний вид и поведение - Системные настройки - Android SDK».
Нажмите "Изменить" рядом с "Местоположение Android SDK". Задайте здесь правильное местоположение Android SDK.
Если это пока не сработает, перезагрузите компьютер и попробуйте еще раз. [/ QUOTE] does not work, okay, I'll run it through the browser
Android 12 and Single Tap answer
Not being able to cancel with a single touch is even more important IMO: that happened to me last week when I pulled the Pixel 2 out of my pocket and found I'd hung up on my daughter before I'd got the phone out of my pocket.
I've decided that the best solution is a single tap accept/reject plus a flip case so that you can't touch the screen until you intend to... ;)
Help Data ONLY through wifi
Thank you, puppykickr...
no root is quite perfect for me... if it does what it says when it comes down it. You see, I also expected Android 11 not to ignore my settings of Downloads over wifi only. Yes, it took a while to click every app (three times), but it eems to have been worth it and I had webview turned on for wifi.
I allowed only contacts and phone, everything else is red. I only rarely make phonecalls, so I have a strange simcard for phone only, which costs almost nothing, as long you do not make mistakes. And I need to be reached at all times....
I have disabled everything Google completely and it also seems to work against Playstore, which alsways used to tell me this or that will no longer work, which was not true.
Help What's wrong with my phone
He ninja'd me, but more or less this. In my experience it will charge veeeeeery sloooooowly until the charge level reaches a safe level as I said above.
^^ Agreed. That's what I was trying to remember. What the OP is describing has occurred with mine severally (?)
There should be life in it yet depending on it's history and use, but can't know for sure.
It's definitely not an old device, my shampoo bottle is older than that, but I guess anything over 2 years is still suspect, sadly.
S21 not yet received android 12 update
Hi all.
I live in Belgium and bought an S21 5g (international version) from the US back in June. I was receiving security patches as and when they were released. Now (Dec 15th) I am still on the patch for October and still haven't received the android 12 and one UI 4 update. Is anyone else in this boat, had anyone found any literature on when we might expect the update or if there might be an issue. Current Software version is G9910ZHS2AUIN.
Any help or info would be greatly appreciated.
That's actually the Hong Kong(SAR), Qualcomm Snapdragon variant of the S21 you've got there. although it will work internationally no problems. I believe Samsung haven't rolled out Android 12 for the China S21 Snapdragon variants yet, including HK and Macao. And if you bought it in the US and not HK, then it was a grey import there.
Also FYI Samsung Belgium many not be able to deal with warranty claims for any issues on Snapdragon devices that were intended to be sold in China, etc. The EU countries get the S21 Exynos variants.
[07/DEC/21] BUL1 December Security update
Even more BUL1 December Android Security patch updates for the international S21 devices and CSC codes...
  • Israel (ILO)
  • Italy (OMN)
  • Albania (AVF)
  • Kenya (AFR)
  • Serbia (TOP)
  • Romania (CNX)
  • France (XEF)
  • Ireland (MET)
  • Ireland (TSI)
  • Serbia (MSR)
  • Netherlands (VDF)
  • United Kingdom (VOD)
  • Ireland (VDI)
  • Czechia (VDC)
  • Germany (VD2)
  • Switzerland (SWC)
  • Greece (VGR)
  • Spain (ATL)
  • Portugal (TCL)
  • Netherlands (TNL)
  • Czechia (TMZ)
  • Poland (PLS)
  • Sweden (HTS)
  • Greece (COS)
  • Macedonia (MBM)
  • Croatia (CRO)
  • Slovakia (TMS)
  • France (FTM)
  • Germany (DTM)
  • Austria (MAX)
  • Ireland (3IE)
  • Slovenia (SIM)
  • Poland (TPL)
  • Romania (COA)
  • Hungary (TMH)
No news yet on the Canadian (G99*W), China/Taiwan (G99*0), Korean (G99*N) or U.S. (G99*U/U1) models.
  • Israel (ILO)
  • Italy (OMN)
  • Albania (AVF)
  • Kenya (AFR)
  • Serbia (TOP)
  • Romania (CNX)
  • France (XEF)
  • Ireland (MET)
  • Ireland (TSI)
  • Serbia (MSR)
  • Netherlands (VDF)
  • Ireland (VDI)
  • Czechia (VDC)
  • Germany (VD2)
  • Switzerland (SWC)
  • Greece (VGR)
  • Spain (ATL)
  • Portugal (TCL)
  • Netherlands (TNL)
  • Czechia (TMZ)
  • Poland (PLS)
  • Sweden (HTS)
  • Greece (COS)
  • Macedonia (MBM)
  • Croatia (CRO)
  • Slovakia (TMS)
  • France (FTM)
  • Germany (DTM)
  • Austria (MAX)
  • Ireland (3IE)
  • Slovenia (SIM)
  • Poland (TPL)
  • Romania (COA)
  • Hungary (TMH)
Filter
