Android Help
HI! I have an android that is newly setup. I am seeing two sets of screens with identical widgets and icons. Example I have two messenger apps, two chrome browsers. Is it easy and how do you switch between accounts or ? On the history I have noticed that on some it pulls from " UNKNOWN DEVICE " and on some it pulls from SM-G781V. Can some one explain what is going on.
Are we talking about on your home screen? The apps you see on your home screen are just shortcuts like on a computer. You can just long press them and remove them from the home screen.
And what accounts are we talking about switching?
And what "history" are we talking about? Where are you seeing this?
True antireflective screen protector, NOT matte
Newly released Samsung Galaxy Z Flip3 phone camera protector features Gorilla DX glass with AR coatings :) It helps let in more light, reduce ghosting halo in images around bright light and also is more scratch resistant almost like sapphire crystal which is hardest mineral used in displays. I'm getting it to replace camera protector for Huawei P20 PRO and later also P50 PRO. There are no yet phone screen protectors but Samsung Galaxy Watch 4 screen will use even better Gorilla DX+ crystal glass.
Apps Debugging Google Play Purchases
I have a task to upgrade an app to use the Google Billing API for allowing the user to purchase a one time premium item for a small amount. The documentation on the code was pretty clear and I implemented it, but I was told that it doesn't work for new users to buy the product (and somehow existing users lost their premium status, but that's something else).
I have to look further into that, but I still dont get how to test the purchase flow while debugging the app from Android Studio. When I try to purchase, Google tells me that the app version is not configured for Google Play payments.
I think that I've already configured myself as license tester in the Google Play Console.
Can anyone help?
New App: Protectile - An Endless Runner (Version 1.1)
Funny notes:
  • This was my second android game, a few years of a delay due to lack of interest/time
  • After I had published it, I realized I left the launcher icon as a default one. Amateur hour :rob:
  • Google reviewing it initially took about 5 days ( 2 on the weekend, but not sure if it matters)
  • All my patches after release have taken about an hour or 2 to review, so pretty quick to patch!
  • This is actually the 3rd patch, as my friend screen-shotted it on his phone and pointed out something that made it unplayable :oops::oops: - I believe this has been resolved.
  • The math to bounce the laser is actually quite high-level and can be found in University level Alegbra ll... but you can also just find it on the endless tutorials out there :D
  • I hope to use it to create a puzzle game.
Cheers!
Legion Watch Face
I've used the same watchface for years, simply because I couldn't find anything to match its timeless style, classy presentation of information and customization options. If this is everything you say it is, you may have stolen me away from it. Very nice!
EDIT:
@Thomas Hemetri I sent an email to you, via developer contact, with some suggestions for improvements. Hopefully they will be implemented soon.
[Working] Bootloader Unlocking on most Qualcomm ZTE Devices, /Devinfo partition modifiation
Hello all
a very interesting post i came across here and i wonder if this may help my issue
my wifes mobile phone is an Asus Zenfone 5Q ZC600KL X017DA the issue with it will flash up powered by android then the Asus logo will appear and its stuck on the logo i have tried the usual hardware keys to get into factory reset but no options show up other than going into CSC fastboot mode
have tried a number of firmwares for this model phone seems to be so many of them for this model and in fastboot mode they all fail they all show up an error write protected apart from the last firmware i downloaded that will say cannot flash in locked state
when checking some device info it will say bootloader is locked so i assume thats why i cannot flash via fastboot
i have tried using Qfil but i am always getting errors like i will give last line before the error and then the error message
12:25:26: INFO: Reading through sparse file 'system.img' and pulling out relevant header information...
12:25:38: INFO: File system.img is a sparse file, being split up into 7980 separate XML tags
error
12:25:41: {ERROR: StoreXMLFile:8890 2. Too many XML files in XMLStringTable, max is 8000
someone suggested shortening the firmware folder name and placing it on C dive same with the Gfil both have done but still the same error
my goal is obviously to get the phone flashed and running again so if anyone has any information on the flashing process using Qfil and how to resolve the error above i would much appreicate it
but as this topic is about unlocking bootloader and might be an option i am looking to do if i cannot flash via Qfil i wonder if the above instructions would work the same way with with the model phone i mentioned if not then any solution would be great at least keep the wife from chewing anymore of my a$$ off hahaha
many thanks
video editor that can cut the middle part of a video
I used movavi in past. Marketers feel more positive about the return on investment offered by video than ever, as it continues to strongly influence traffic, leads, sales, and audience understanding. Video is more interesting for me too. I apply to this guys https://darvideo.tv/ because needed to create video about my game for smatrphone
Movavi is difficult to use, and has a watermark.
Watermarks are hideous and not an attribute for professional results.
Not only is YouCut simple to use, the free version also has no watermark.
Hello I was wondering if there is any way as a parent you can check your children’s device usage?
I use google family link (https://play.google.com/store/apps/details?id=com.google.android.apps.kids.familylink) to keep track of my son and manage his phone usage and what apps he can install. You can control how controlling you are, depending on how much trust you have.
Help to change the execution rights on a Galaxy Tab
If your device is rooted and flashed with something that doesn't quite work, and you can't otherwise make it do what you want, it may help to "factory reset" it by flashing it with the original Samsung firmware. I'm not sure if you can get that from Samsung, but lots of sites claims to have it:
https://www.qwant.com/?q=samsung+firmware
Here is one such site, which also has a procedure for how to go about it:
https://samfw.com/firmware/GT-P7510/ROM
It's old stuff and the link they have to the Odin tool is gone, but I think this is it:
https://www.ydfile.com/file/odin/Odin3_v3.14.4.html
If it doesn't kill your device, it might get it working again :p
Thanks, the links are useful, but in this case the issue is not that the system does not work at all, there are some quirks but overall it's ok. As I said in the other reply there is probably a problem of file ownership
Filter
