New App: MapTiler Mobile (Version 2.1.8)
- By Unforgiven
- Apps & Games
- 1 Replies
scroll to the bottom of the page, the play link is there.Can you please share the link.
http://play.google.com/store/apps/details?id=com.maptiler.geoeditor
No problem. I created a channel for your app. Good luck!!Oh my I totally forgot about the link... Edited the post.
My lg with androud 7 oreo can save a memo for each picture in my gallery.
Now gone in v 9,10
Double tap on- off is great. Gone in 9,10. Why
Every version going backwards ! Keyboard word correction. Is as smart now as the democrats!
@ocnbrze bro yes I know magisk root by writing in boot partition and super user and other method write on system partition and twrp on recovery partition ...but kingoroot iroot one click write a bulk of files garbage files....but super user user writes minimum files ....but I foud magisk procedure little complicated it patches the boot.img and that boot image it patch is provided from 3rd party can we patch our original adb pull .../mmcblck0p24/ boot.img file self copied by. I doubt the 3rd party boot.img may not be modified so is did not used itWell if you read the posts....... it will depend on how you rooted will determine if you have to re- root the phone, after doing the factory reset. And yes a factory reset will erase the malware, if that is what you have.
Yes, my Linux desktop has a wired internet connection, but no wireless connection. Also, my android device is a tablet: it has no cellular connectivity. It has WiFI, but I don't use it.
Anyhow, I'll weigh my options. I was not planning on downloading apps and entering the modern world, but I might. Or, it might be easiest to simply rename the files. Thanks again for providing options.
@ocnbrze bro okay but in India I don't think cellular companies provide such service they sell Chinese phone with their brand name I have to purchased 5 year before this mobile lyf water 7 (the mobile device I asked in question)from Jio India as they were giving free unlimited 4gb as launching offer for first 6 moths but mobile config is no ot much but they cost high 8k -12kIt is not really that way.
A 'burner phone' is a phone that is usually locked to a single cellular provider for a year or so.
The phone is bought at a great discount because of this.
In this way, a person with little money can have a decent phone.
You do not reallt rent it, but pay for minutes/data periodically.
After the year or so is up, you can have the provider unlock the device for you.
The drawbacks are that these devices are usually 1-3 model years old, and so by the time the term is up they are even more out of date.
The good news is that you can buy one and never pay for anything more if you only use the device on Wi-Fi.
