Thanks for your great informatonyou might not be able to:
https://support.google.com/accounts/answer/19870?hl=en&co=GENIE.Platform=Android
Thank you, sir!I created a channel for your app. Good luck!!
https://androidforums.com/apps/flappy-chick-dodge-the-danger.19890/
FWIW I've been using paid Express VPN for 5 years now, and had good reliability with it here in China, and some of my friends here also use it. I also recommend Astrill VPN, also paid.
I did look at Proton VPN, but their sign-up site keeps on showing broken CAPTCHAs..
You should be able to access the phone's location by querying the fused location provider directly on-device. You shouldn't need to run a bunch of queries against a costly web API. (I think; I'm not actually a developer, but I wasn't able to find any sort of pricing or limitations on using the on-device resources.)
https://developer.android.com/training/location/retrieve-current
Yeah, I wanted somwtbing inbuilt instead of an app really.
I'll take a look at that second link, thanks!
Did you also clear all data from Google Play Services?
I know you say that was done for Google Play Store, but the two separate apps work together.
You can release an instant app through the internal test track, which enforces a 15 MB limit on feature module sizes. Only the alpha and production tracks enforce the 15 MB. Hope this helps. Researched it.Rephrasing the question, for a app/game to run smoothly , what is the maximum size a game can be , can anyone shed some insight on this ?
