What do you do with the videos? If you only play them on the phone, then the phone screen has approximately 2k resolution and hence 4k will be downscaled in order to play it. And if you upload to social media for others to watch on their phones the same will be true (and probably the social media platform will either downscale or further compress the video when you upload it). What I'm saying is that whether the limited resolution is important depends on what you do with the videos: if you watch them on a 4k or 8k screen it might make a difference, if you don't then it may well not matter.
That is not to say that you don't have to worry about the quality, I'm just saying don't get hung up on the resolution, which in any event is not the most important factor in image quality.
I can't answer the question about the quality of videos because (a) I don't own this phone, and (b) I don't know what you consider good enough. But you can find reviews that include video samples, e.g.
Samsung Galaxy S23 FE review, which you can compare to other cameras.
