[App] TapeMyCar
Tape My Car is a headway technology of GPS tracking which provides you a live location of your car anytime and anywhere. Thanks to the easy-to-use app TapeMyCar and its' super fast service.
You can watch every moment of your vehicle with your smartphone without any hassle. With the app, users can see the live location of a vehicle, See the report of every moment of vehicle, Watch the stoppage and movement with gridline, Set the notification for different movement, manage many vehicles at the same time, and more.
Screenshot: https://imgur.com/a/3gLxuGd
Google Play: https://play.google.com/store/apps/details?id=com.redgates.tapemycar
Learn more: tapemycar.com
App Info:
Current Version: 1.0.2
Requires Android: 4.1 and up
Content Rating: Rated for 3+
I have YouTube channel AR Reactions
No it's not my YouTube channel
https://youtube.com/channel/UCnqY4Ot6iXIbAT9k0
It's my YouTube channel
FYI the uploaded videos on your channel play fine here as well, on Android phone and Macbook. However I can't understand a word, as it's in some foreign language. AF is an English language forum, although I can understand Mandarin as well. :) But what is the exact problem you're having, and what phones, tablets, and/or computers are you using?
editView- character selection
Hello, I am new here. I hope someone knows anything on Android Studio and Java.
I have editView and input something, I can't to select some characters,
but if I use textView I can select characters.
How to using editView, can I select a few characters, not all text entered in 'editView'?
Please help me to fix this.
HELP: App Refreshes Upon Bring to Foreground
Hello... Ive got an app that is utilized to connect to a brand of baby video baby monitors. The app is fairly feature rich. It can record, has two way audio, supports multiple resolutions, etc.
The issue at hand is that the app performsv well when it's front and center. It even works efficiently in the background. One can open the app, start a recording with sound, then minimize or pop-up/multi-window the app and it'll still record and play the audio... But as soon as you go to bring the app back to the foreground, it refreshes nearly (or possibly) everything. The recording send audio gets cut off, the video loading screen resets, is almost as if you're just starting the app for the first time since it was last cleared from memory. It still retains your login and all that, but it's an amazingly counter-productive glitch.
I was wondering what line of code i should be looking to modify, or add, to make it so the app keeps running fluidly (?)
first off there is no code for you to manipulate. what phone do you have? have you tried uninstalling and re-installing the app? how much memory do you have on your phone?
Help Easiest and safest way to root android 6?
I want to disable/remove "com.android.providers.calendar", calendar and google play services, somehow they are giving android problems.
Can you help me please?
Will i lose any datas if i root my android?
Thanks
also if you are having issues with google apps especially play services then please read this:
https://9to5google.com/2021/03/23/android-apps-crashing-webview/
and yes you will loose data if you root your phone.
Think I am hacked
Please help me how to recover my Redmi Note 5 Smartphone as it was recently lost. I used the find my device service service and left a message for the stealer. The stealer seemed not to use my phone and remove his sim card from my phone. Now, it's impossible to track him. Moreover, I can't disable the screenlock remotely that he can use my phone and can be caught red handed. Please help me with my IMEI No.
I think the best you can hope for is to report the phone stolen to your carrier so the imei can be blacklisted. That would prevent anyone from using it as a phone. It's most likely already been wiped and sold. You should change all your passwords, though. And enable two-factor authentication on your accounts just to be safe.
Filter
