Accessories [Free] [App] QR Code Scan (Android App)
Good News!
We are happy to announce that we have developed new QR Code Scan (application to the Android platform. Now you can use the same application on Android Platform.
QR Code Scan (Android App) is the most updated application.
QR Code Scan application allows you to generate unlimited QR codes..
Download Details:
Application Name: QR Code Scan
Play Store Link:Download
URL: https://play.google.com/store/apps/details?id=com.wmdev.tools.qrcodescan
You can also rate our QR Code Scan application in the Google Play Store.
AUC8 BIG update for Global S21 series, camera & April security patch
Samsung are certainly putting their back into pushing out this 1.1GB AUC8 firmware with the April Android Security patch.
In under 6 days they have released no fewer than 100 updates for countries and carriers across the globe, from Afghanistan to Vietnam, for their Galaxy S21 Exynos global series.
Phone manufacturers are often criticised for the tardiness of their updates but Samsung are excelling themselves on this roll out.
Need Help With Input Jack
Actually you can. I've done it many times as this photo will show. It is a dual purpose jack and many phones have them but that information is not usually in the manuals... but a quick search on Google/YouTube will show it. For this shot I was using a Movo VXR10 microphone.
The issue I have is that when you do use an external microphone, the speaker is deactivated; on the G7 at least. I suspect the reason is the phone thinks you're using a headset with a microphone, even though it shows an external microphone option in camera settings. That makes no sense, but anyway. I would like to have the speaker functional as needed when I have a microphone plugged in.
OK that's something I've never used before. But I have used USB wireless mics with Android devices,
similar to this one... https://www.amazon.com/Microphone-A...ywords=usb+wireless+mic&qid=1617432192&sr=8-7
That I also use with Macbooks.
Help Set screen height to below camera setting removed in update?
Sorry for the late reply thought this site would auto update. Yes I was able to do this before the update.
I will try to look for some 3rd party camera apps but I think you might be misunderstanding me. What I meant was my screen size for my phone itself, not for the pictures my camera takes. The A40 is a phone which has one of those curved screens which goes to the very edges of the screen, which means it also invades the front facing cameras' space, the invasive space the camera takes up looks jarring to me.
These images should help explain exactly what I mean. The left image is what my screen looks like at the moment (meant to show the phone border plus camera at the top, everything in white is my screen space). But I want to hide the portion of screen in red like the right image shows. This used to be a feature in the past but I'm not sure if they removed it or if its just hidden, even then I'd love to know if there is any way at all to do this.
Action Director 2.0 How to more reliably frame videos
Action director was clearly specifically set up to work with Gear 360. However, I now have two different VR camera, one of which is a different brand. And the snag I've run into is that it technically has a 4K mode, but its 4K resolution is different and slightly higher than Gear 360's.
Now they are both 2:1 even though the numbers are different, so there is no "distortion" because of the difference. But it would be nice if I wasn't locked into specific resolutions..or it at least had a "keep the existing resolution" option. But instead, when you go to produce, it gives you a list of set resolutions and never lets you set it to anything different.
While there is no distortion...in watching raw video from the other camera, versus produced video, there is actually a pretty clear lost of resolution..and its also clear that video is more compressed. Which is kind of disappointing.
Filter
