Trouble with Android Studio
Here is my problem:
C:\Fluttermed\medrxflutter>flutter run
Launching lib\main.dart on SM N960U in debug mode...
Checking the license for package Android SDK Platform 29 in C:\Program Files (x86)\Android\android-sdk\licenses
License for package Android SDK Platform 29 accepted.
Preparing "Install Android SDK Platform 29 (revision: 5)".
Warning: Failed to read or create install properties file.
FAILURE: Build failed with an exception.
* What went wrong:
Could not determine the dependencies of task ':app:compileDebugJavaWithJavac'.
> Failed to install the following SDK components:
platforms;android-29 Android SDK Platform 29
The SDK directory is not writable (C:\Program Files (x86)\Android\android-sdk)
I have spend hours and now my vs code will not work. I have the same problem in Android Studio.
I have been working on this for two days.
Need to get a MVP done!!!
Apps Android Studio won't connect to Java
I have been using Kotlin in Android Studio but now want to use the Java code but I just can't get it to connect to Java.
So, I have:
  • Installed Java SDK into:
  • Checked that it works OK:
  • I have set the Windows environment variable’s:
But when I start a Java app I get:
Failed to find Build Tools revision 26.0.2
And in gradlew.bat I get: ERROR: JAVA_HOME is not set and no 'java' command could be found in your PATH.
Any help really appreciated. Cheers!
Image asset studio has No Legacy tab
1. Above is the official crop of image asset studio.
When you choose "Launcher Icons(Adaptive and Legacy)" as icon Type , there is supposed to be a Legacy tab, however, it didn't show on my studio. Anyone might know why?
2. What would happen if I upload a 512*512 dp image to foreground layer for adaptive launcher icon? (The official guideline says it must be at 108*108 dp)
Thank you.
AOSP: Can't Run Emulator
I'm a AOSP newbie. I am following this tutorial.
I have successfully synced my repo to tag android-11.0.0_r29.
I set lunch to aosp_arm-eng. The build reports:
Code:
[ 99% 90444/90520] //art/build/apex:art-check-debug-apex-gen generate art-check-debug-apex-gen.dummy
--bitness=auto, trying to autodetect. This may be incorrect!
  Detected multilib
[100% 90520/90520] Target vbmeta image: out/target/product/generic_arm64/vbmeta.img
#### build completed successfully (05:25:57 (hh:mm:ss)) ####
However, when I attempt to run the emulator:
Code:
clayton@ubuntu-20-aosp:~/aosp$ emulator
emulator: ERROR: Can't get kernel version from the kernel image file: '/home/clayton/aosp/prebuilts/qemu-kernel/arm64/ranchu/kernel-qemu'
Have not found a solution. Please help.
Deleted phone back up
My old 3a got water damage and wont turn on .i got a new pixel 5 and when I set it up from the 3a backup it asked for the security pattern (from the 3a)i accidently did too many wrong tries and then it said that the backup had been permanently deleted. Tried re setting again and sure enough the backup 3a option is gone.
The 3a backup still appears in google drive, so my question is how can I utilize this backup again? Is it permanently deleted? Why does it still appear in google drive? Am desperate as I need to get the call logs and sms logs from the 3a backup. Any help would be greatly appreciated
Help Oppo R11 Plus wont recognise Smart doorbell
My Oppo R11 Plus is running Android 8.1.0, connected to EE Fibre Broadband WiFi Router set to 2.4Gz band only.
I bought an "XSmart" video doorbell, Model # X20D00H002 last month. (2.4Gz band working only)
I've tried using the manufacturers recommended Play Store Android App for the video doorbell ( "Ubox") plus another App advised for the "XSmart" models on YouTube ("XSH Cam") with ALL the settings correctly inputed but am having problems.
On both Apps. when "adding new device" (the video doorbell) I can use the displayed "QR" code to get the doorbell to connect itself to my home EE Network, but boths Apps then fail to recognise the doorbell as a new device and add the doorbell to its' list of devices. Tried countless times with no success.
I even tried downloading both Apps to my wife's Samsung Galaxy A10 phone, with the same failures.
Has anyone else had similar problems, and how do I get my Oppo phone to recognise the Doorbell as a new device? Thanks! David (UK).
David, is it this app?
https://play.google.com/store/apps/details?id=cn.ubia.ubox
Looking at the many one star reviews, seems there's many users having the similar problems with it, with things like "Garbage, you can't connect devices..."
Suggest you return the video doorbell as unsatisfactory for a refund. And quite frankly cheapo no-name smart doorbells, and other cheapo IoT devices should be avoided as they might be unreliable, and may even be a security risk.
My new LG G7 ThinQ has a TV app on it
This phones was obviously from Korea but is brand new, brought on ebay
But it has a TV app that scans for channels and asks me to connect my headphones in the same ways as the FM radio
Doesn't pick anything up though, I assume its tuned to Korean TV wave-lengths.
Would this be hard-coded on to the chip or is it possible to change these values in another LG app or TV app
Never heard of such a thing in my life
It's for receiving DMB(Digital Multimedia Broadcasting) on VHF and UHF, only used in South Korea and China AFAIK. And it does use the headphone cable plugged in as an antenna, similar to FM radio. Some older phones actually had a telescopic antenna for receiving it. I suspect it is hard coded into the SoC, like FM radio, and if it can be changed by firmware or not, no idea. There are other TV apps, but they usually stream via the internet, e.g. Hulu, iPlayer, etc.
Auto Suggest not showing most useful suggestion.
Hi all was wondering if anyone knows how to set this up. I'm not even sure if my title explains it properly but here is my dilemma.
for example
I have a row widget placed in my project.
under row I want to adjust my mainAxisAlignment: //here if I start to type the word 'center' I'd expect 'MainAxisAlignment.center' to show up near the top of the suggestion list yet it is more near the bottom and I have to scroll thru the list to get to it.
See attached image. also I made sure that sort by name is unchecked yet the behavior persists.
Does anyone know how to change this behavior?
Thanks in Advance.
Filter
