Android Auto on Samsung Tablet "Not Compatible"
here try this:
and do not use crack.....just say no to drugs:thumbsupdroid:
I can't get the app to work. I get the following message on my phone "Incompatible Software Version!"
Downloading (paid!) APK from Google Play & sideloading it?
Hi all,
kind of a weird question due to some special circumstances:
I have an older (ca. 2019) Amazon 10" Fire tablet running something like FireOS 7.xx which AFAIK was still based on Android 5.x. I also have a Galaxy J-something smartphone (running Android 7.x IIRC) somewhere which I can't find atm, unfortunately (I've been using non-Android phones for years). So this is about said Amazon tablet primarily.
I have the Google Play store installed on the tablet (as per several instructions on the net), and it generally works fine. Since I installed the Google Play app, I only ever got apps from there.
Now I'd like to buy the Caustic 3 synthesizer Android app, which is still widely regarded as the best app of this kind for Android. It may (or may not) be abandoned, but you seemingly can still buy it at Google Play. Last version was (and probably will alway be) 3.2 from 2013.
This app comes as a freely downloadable base app and a separate for-purchase "Unlock Key" (no IAP). If I look it up in the Play Store from my desktop PC, it looks like both are still in the store and most importantly, you can still purchase the unlock key.
However, if I try to find it in the Play Store bolted-on to the Amazon tablet, both are nowhere to be found. That's a bit weird since the app should run fine on Anroid 5.x. Amazon's own (kinda joke of an) app store has the (v3.1!) program itself, but not the unlock key.
There have been some reports of people running the Amazon-downloaded app with a Google Play-acquired unlock key, but I can't see how that could work.
In my case, this would require me to purchase the unlock key in some way off the tablet (maybe inside the desktop browser?), and then to somehow get it onto the tablet and hopefully, the unlock magic would still work then.
I never read anything about downloading the APK files of your own purchases directly from Google Play to anything other than the final target device and, even if such an APK download was feasable, I have no idea whether or not the licensing-DRM-whatever magic can be made to work after an APK transfer.
Please note that I'm only ever talking here about making a legitmately purchased app work and not about 'hacks' or such of any kind.
Could someone tell me if and how this could work?
I apologize in case this has been discussed before in another thread but my search turned up nothing that hit the spot (downloading your "own" APKs and "messing with it").
TIA
Android hmmmmm... I mean Andrite is completely AOSP. LOOGLE is myself/yourself as far as no cost. Only Playstore requires payment for extra features. I mean I get you want youre purchase to follow you on youre devices and that should be by original google account/email you used when you purchased the full features of the APK. under that Gmail account. **** playstore root and use Lucky Patcher as we ALL know its safe to mention LP now the once double edged sword by non other than the great Chelpus. I mean Helpus. Dont pay for shit anymore Android is Open Source Not Open wallet. Shut the door on an open situation. FREEEEEEDOM!
How Did I Prevent Bloatware And Google From My New Device? (My latest experiment)
You're dealing with the first-time setup of a device. It won't let you pass without all that jazz.
Welcome to the modern era. Now you know why I try to steer clear of it and relive the past. Think it's scary now, just wait till Neuralink becomes a thing.
Naw, no terms or conditions apply with LOOGLE. EVVVERY! option is youre own and NO apks come on the devices i will be kickin out to you all from the Andritian WirlWind PC. PC now stands for Prowessing Creator/Ply-able CO owner/$ Build youre own fully optimable optional operations. Youre device youre options. Though now we wont be wondering if our operating systems/device makeup is built by a policing corp. and not a vauge term such as GOOGLE/GOV. operative conglomerate masked as a soft/hardware company wich is refered by itself as such. YOURE TERMS MY CONDITION. LOOGLE IS ALMOST HERE!
Help Does Google modify callers' voices broadcast from the Pixel's speaker to prevent recording by PC voice recorder apps?
What magic signal do you think they are adding that allows the human ear to hear the voices normally but stymies mechanical recording? If they were outputting any additional sound within the audible range you would hear the distortion yourself. A signal at a different frequency would be ineffective (because it would not affect the frequencies of interest). For sure you could add noise that would make life difficult for a mic, relying on the human brain's pattern recognition abilities to let you understand what is being said, but if you did that the voice would definitely not be normal or clear to you.
If you have 2 speakers you can use interference (in the specific sense of interference of waves, not just the generic term "interference") to cancel out a sound in a particular location. But that only works if you have 2 speakers and some electronics which knows where they both are and where you want the sound to be cancelled, so that one can output an inverse waveform with the correct amplitude and phase offset to achieve the cancellation where you want it. If you try to put a destructive interference out through the single speaker you get no sound out at all (the 2 electrical signals sent to the speaker would cancel each other out and the speaker would not receive any signal at all, and hence output no sound whatsoever). There is no way that a single phone can do this.
If you were using a radio mic then you could imagine outputting a radio signal to jam its communications with the computer, but that would not affect just one side of the conversation. And I believe that's a USB mic, so we can dismiss that theory. Plus you need to be careful about using jammers in public places: even if you restrict them to the unlicensed radio bands (so that they are not illegal to operate), which you might guess is what a radio mic would use, they could easily affect other devices that use those bands (because you'd have to jam the entire band, not just a narrow channel, since you don't know which channel the radio mic is set to use). It would be a commercially risky move for Google to put something like that into a phone, as the potential downsides would way exceed any benefit.
Plus, on that last point, what would the commercial benefit of Google doing anything like this be? Google only gain from it if it increases sales, but it can't do that if it's an unadvertised, hidden feature.
My friend William of Occam suggests you look for a simpler explanation.
Damn SMART ****IN KID I GOT HERE A!? Wow! Hadron, Sounds almost like an evolved being/living PC you are refering to here.
Is there any way to find the source of these alert sounds?
I don't know from your description whether this is the default system notification tone: on my s21 that's 5 notes rather than 4
Just to update, I was wrong and it is 5. Since turning on the notification history I have identified one that made the sound without a message. It was Samsung keyboard. God only knows what triggered that but I went back into show system apps in Notifications and found it, along with a load more that I didn't see first time around. I've turned them all off. That was the only one that's popped up since the initial clearout so it's looking good.
Wireless charging for Moto G Pure
At work we had three employees at one time that had freshly upgraded to S9s, from S3/S4s. All three ultimately did the 'moisture warning' issue and wouldn't charge unless you used wireless.
I still blame USB-C. I have had a hostile relationship with it ever since it became 'mandated' without my approval. Literally NOBODY asked for this.
The 'moisture detected' error was pretty well-known at the time the S9 was the latest thing. search for 'Galaxy S9 design flaw moisture detected' and you'll get tons of results. It's a well known issue. None of the the mentioned phones EVER got wet.
My main gripe with Type C is that it usually always says it's charging but it drains while it says so. I can't trust it. Never had issues with Micro USB at all. EVER. Always worked if it showed it were charging. Even if you got the 'Battery with X or ! inside it' error it would still charge, just slower than normal. I wouldn't wake up to 18% 'charging' like today.
Micro USB also never had Android Auto issues with my Galaxy S5 either. Now, I'm lucky if I don't have to unplug/replug the damn Z Flip 4 five times before it works. The rest are either my Pioneer deck being blank, or it showing 'no signal/icon with ! inside it' and no connectivity (while the outer display shows plenty of signal) or it not responding to touch/voice control.
As harsh as it sounds, I feel whomever decided that USB Type C was a good idea needs to be lined up and shot. Change for change's sake. Micro USB was never an issue if you aren't an idiot. The little USB symbol faces up, for those who don't know. Even when Apple (and Samsung) had that wonky 30-pin connector, there was a visible icon that showed the 'up' side. But hardly anyone read the frelling manual to know that and blamed the wrong person for being an idiot.
Back in 2014 when Type C first launched (on the Nexus 6) the whole selling point was 'it's reversible!' and that was one of the 'remarks' that CrApple fans used to brag about their lightning connector, 'but you can plug it in either way!' So I always figured that was why USB-C happened in the first place. I wish everyone would stop looking to Apple for advice, or who to follow. I wish Android just remained its own thing like it was in Android 2.3, Gingerbread.
[UPDATE] [GAME] New Game: Dawn Restart: Survival [ANDROID 5+]
**Game Update Announcement - 20/12/2023**
Prepare for an enhanced gaming experience by updating to the latest version of our game! Dive into the following improvements:
1. Repaired connectivity issues for Google login.
2. Revamped the exploration system - experience the preliminary version now!
Stay on the cutting edge of gameplay! Update now and share your feedback with us.
Happy gaming! ✨
How to stop turn ON notification requests?
Each time I get a permissions request, and disable one or more, it asks about them again on further launches, although sometimes you get a 'don't ask again' option as well.
An app will usually run if you deny the notification request on first launch, but will nag about it each time you open it. It's treated a bit differently than simply turning notifications OFF in settings--Apps--App name.
A more modern issue I deal with is 'this app has been closed because it has a bug [ok][clear cache]'. I find that happens a lot on One UI after Android 13, and so far my only workaround has been to either live without the app in question or disable battery optimization in settings. This is very different from '[app name] has stopped/keeps stopping'
There are so many things that modern Android does that it makes my head spin and long for the simple days of Android 2.3. Today, we get pop-ups (screen overlays), toasts (little bar at the bottom that merely annoys me) bubble notifications (similar to iOS) and icons that clutter the status bar (a problem with Android as a whole, since the beginning, never have liked it).
For example, a way to fully turn off OTA updates is by disabling the screen overlay permission to Software Update and FOTA Updates and anything with the word 'update'. That has completely disabled my phone's ability to interrupt my flow by deciding at the most inopportune time to say 'hey! a new update is available!' hoping you hit the wrong button.
Transferring browser tabs
Yes both connected via home wi-fi. I found that your method is supposed to work for Chrome but it appears it only works for tabs open on a PC to sync to a phone. So it's looking more and more like I'm out of luck for get these tabs synced the easy way and will have to do it the hard way. I do appreciate you chiming in.
Samsung One UI/Android 13 'app has been closed because it has a bug' issue
This seems to happen with certain older apps I still like to use, and only on Android 13/One UI 5.1 devices. It's not a crash, because then it'd say 'app has stopped/app keeps stopping' instead. In this case, it shows 'Angry Birds has been closed because it has a bug' which appears to be a Device Care issue, perhaps it's not liking the resources it wants to use, or it's using too many bits of RAM/CPU, in either case, Device Care is closing the app assuming something is wrong. However, if running Android 12 or below, with One UI 4 or below, it runs without an issue.
Angry Birds 1.6.2 isn't the only time this has popped up, but I do not know how to circumvent the issue. I've turned as many things off in Device Care as I can, but it still happens. The wording 'has been closed' vs ' has closed/stopped' indicates something actually shut the app down, not the app actually crashing. I have had apps crash but the wording is very different, saying 'ES File Explorer has stopped'.
Does anyone know any method to circumvent whatever idiot proofing Samsung has apparently enabled that is shutting apps it thinks 'has bugs' down? I know for certain Angry Birds 1.6.2 has NO bugs at all. It ran fine until the last security patch that upgraded One UI from 5 to 5.1.
EDIT: Fixed the issue by setting battery optimization to unrestricted. Stupid Samsung!!!
Grammarly.. Yeah... WTF?
You've downloaded an APK of this app and it's not installing?
If you try to install the APK from My Files, you will probably see something saying 'security policy has prevented My Files from installing this app' with options to allow or deny. If you tap allow, it will present some prompts with 'allow once' or 'allow all the time from My Files' and then work. It's no different from having to check 'unknown sources' in older versions of Android.
If it's saying something like 'This app has been closed because it has a bug' that's stupid Samsung Device Care closing it because it doesn't like the app. I have not found any method to circumvent that particular error, it's not crashing because then it'd say '[app name] has stopped' or '[app name] keeps stopping'. The 'closed because it has a bug' has something to do with Device Care thinking something is wrong with the app, maybe it's using resources it doesn't like, but either way it shouldn't even happen, but that's Samsung for ya.
[FREE]newest digital currency you can mine using your phone for [free]
Ice is the newest digital currency that you can mine for free using your phone​
The Ice project has been imagined to bring back trust in digital assets and deliver a true sense of community for users who don’t have the financial resources to mine Bitcoin or are simply too late to enter the game.
Too late to join mining pi or bitcoin?
Do not worry.@ice_blockchain is coming
Join our team on ice and receive 10 ice coins
when you sign-up using my referral code:
invite code :cakzxd
Good points about ICE Network:
1. 100% open source
2. No ads
3. Fast KYC process
4. Strong governance structure
5. Planned open mainnet date: October 7, 2024
6. Very popular, probably the fastest growing mobile mining crypto project at the moment.
ICE Network Informations:
Planned mainnet date: October 7, 2024
Number of miners: 3.255 million+
Total supply: to be determined later
Twitter followers: 3.271 million (as of August 26, 2023)
Google Play downloads: 1 million+
Mining start time: July 6, 2023
Mining method: need to restart every 24 hours, no ads
Reward method: 2 level referral reward
How to join mining:
Referral code: cakzxd
Samsung Fold4-Stable Android 14, One UI 6.0 rolling out
I swonney I keep reading the title as 'flip 4'.
At one time Samsung devices if set to auto download on wifi would only let you bypass updating for like three times then it'd force it. The only solution was to turn off auto download over wifi. If you turn screen overlay permission off the updater 'app' it disables the pop-ups. Doesn't stop it from still counting down and updating if set to auto download over wifi though.
Filter
