Multiview split screen
Dear,
By code:
1) I want to know how can i start Activity A on a screen on the top and external application on the bottom by multiwindows.
2) How can i restore Activity A on full screen?
I have TabLayout with ViewPager2, each tab selected must display what i want, so i want to display sometimes an other external application below tabs. That's why i think you must use multiwindows : http://www.tutorialsface.com/2020/0...d-fragments-with-latest-android-api-androidx/
Thank you.
Help adb uninstall failure on Android 4.4.4 (bloatware removal)
If you have TWRP custom recovery, you don’t need to root. In TWRP go to mount and select system as well. Then go to advanced->file manager, navigate to system/app or system/priv-app and delete the folder containing the app. The app's data should also be deleated (data/data). After that go to wipe, tap advanced wipe and check dalvik/cache followed by swipe to wipe and reboot system.
If you wish to reinstall stock recoery just flash the stock boot.img. using Odin.
Personally, even as a rooted user for many, many years, I would not choose this route. It's definitely not for the novice.
https://www.reddit.com/r/androidroo...ooting_is_not_enough_to_remove_bloatware_the/
Turning off permissions of other apps
The apps that can successfully keep other apps from accessing the camera on your device use a Device Administrator to do so.
Basically, this gives the user a prompt to allow this administrator, and then that app can cause the camera to be unavailable.
The camera will appear to be nonexistant, or already in use by any other USER app that tries to access the camera.
I emphasize 'user' apps, because it is not known if system apps or other built in apps can bypass this restriction.
After I typed the above, I went to three different app stores to get the link to the app that I use, so that you could check it out.
It seems to have disappeared.
It is called Pandroid Camera, and works just as I explained above.
As I cannot find the link, I could upload the apk to cloud storage and then post a link to that.
I use this app on all of my devices, and highly recommended it.
Xiaomi Mi 10 MIUI 12 Software Update Tracker [Update: Android 11 update rolling out widely]
Xiaomi launched Mi 10 in India last month running MIUI 11.0 Global Stable on top of Android 10. Xiaomi has already rolled out Android 10 based MIUI 12 update to Mi 10 in India. MIUI 12 brings all-new design and animations along with new features such as Super Wallpapers, Floating Window, New Control Center, Enhanced Privacy Protection features such as Interceptor, Flare, Hidden Mask Mode and more to the devices, check out this post to learn more about MIUI 12 features.
https://shrinke.me/chr2FAb
Filter
