Hackers?
It really is strange and my phone has been acting buggy lately but it is 18 months old now so I do expect some issues now
Why do you expect issues? An 18-month old phone, especially one that is still getting monthly security updates, should not have any issues.
My phone is 39 months old, and the only issue is that the battery is beginning to age. And frankly even that is a disappointment (I blame this "fast charging with no option to turn it off" nonsense for the fact that it has degraded a bit quicker than my previous device). If you expect problems with an 18 month old device you have set your expectations too low, which only serves the manufacturers interests and not yours.
Disappearing mouse pointer
It's an android TV box not Win 10 (sorry if I'm misunderstanding!)
Have a look at this video to see the issue, not great quality from my phone.
I also used a video app on the box to capture the behaviour and when I played that back the mouse pointer was moving normally but disappearing as I was watching.
Any ideas?
What happened to the built-in ringtones?
thanks Hadron. you've explained why I have a few ringtones that I didn't download but also can't find when I check the phone's folders from my PC.
Now that I realize how big the ringtone universe is, I see understand why Motorola didn't both providing any. Seems that only old farts like me had never felt the need to stray from the ones that came with all of my previous phones.
@olbriar is one of those people, I think Hadron is one too, but it is hard :) Also you got Luna and Mike :)
Nah you are not too old, hell I might as well put my hat in the ring too.
Help cannot rename folderx to .folderx in Android 5.1
It's 2021 and I'm having this exact problem that @rbd is having.
I can rename my folder to anything but as soon as I put a . (dot) in front of the folder name, it gives me an error. This is with the pre-installed file manager on my Oneplus 5. In the past I used to be able to do it but one day it just stopped working. I'm not sure if it was a system update that caused this or not. Has anyone found a fix for this? (preferably the fix doesn't involve installing annoying 3rd party file manager apps filled with ads etc.)
have you tried other file manager apps? what about hooking the phone up to the computer and have the computer change the name?
[ALPHA] [Unofficial] Orange Fox Recovery R11.0 for ZTE Avid Plus Z828
Code:
* Your warranty is now void.
* We're not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this recovery
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at us for messing up your device, we will laugh at you.
Working:
SD card access
Flashing
Brightness
Touch Screen
Everything else...
Not Working (Fixing Soon):
Backup to Data
Terminal
Internal Storage Access
Download
RS.1 - February 6 2021
https://roms.alexenferman.com/?/zte/achill/ofox
Installation
As this device is quite locked down from the factory, the installation process is a bit long, but is easy once you get used to it.
You will need:
Unlock the bootloader first: https://androidforums.com/threads/how-to-unlock-the-bootloader-of-the-zte-avid-plus-z828.1324697/
  • Download the "Files for QFIL" ZIP file and extract it to the desktop
  • Boot into Factory Test Mode (FTM) by pressing VOL- and POWER
  • Connect your Avid Plus to a PC
  • Using ADB commands, type "adb reboot edl"
  • Open QFIL
  • Select "Flat Build"
  • Click on "Load XML" and select the Patch0.xml and Rawprogram0.xml files from the desktop.
  • For the Programmer, click "Browse" and select the firehose called prog_emmc_firehose_8909.mbn
  • Rename the downloaded recovery to recovery.img, and make sure it is in the same folder as the Patch0 and other QFIL files.
  • Click on download.
  • Once done, remove and put back the battery and boot to TWRP using VOL+ and POWER
Contributors
@Alexenferman
ZTE (For providing me with the stock ROM after a month of E-Mails)
Device Sources
https://github.com/ZTE-Avid-Plus
Downloads
Froot Loops for Boot Loops, Moto Edition
Why not you try to re-install the stock ROM? You can get it from Lolinet.
from here https://mirrors.lolinet.com/firmware/moto/????
I have no idea how to do that. Wouldn't the phone have to be rooted? I just hope it holds up, which it has been doing fine since yesterday.
if so, then i believe your phone's codename is minsk.. not sure though that motorolla has a tool to flash those files from lolinet. at least it is hard to find using a google search. it is definitely not as easy as a samsung phone.
edit: and no you do not have to be rooted to flash a firmware update.
Root Upgrade to android 7
Hallo there,
I have a very old Samsung Galaxy Ace 2x (GT-s7560m) and I would like to upgrade to android 7, i know its possible, using Odin but I cant find any Roms
help?
Hello, check https://forum.xda-developers.com/f/galaxy-ace-ii-android-development.1983/ for the Galaxy Ace2. You will find many up to date ROMs for it. One maintainer has posted a lot of ROMs and even Android 9, but you will need to re-size the /System partition in order to flash it.
8 inch tablets in 2021
i agree with @Hadron there are not many high end 8" android tablets out on the market today. i have the tab s2 8" tablet that came out many years ago. i think it is the only one that i can remember that offered an 8" version of the top of the line tablet. i still use it, but they battery is terrible now. but it was a great tablet that is super thin and extremely light weight. kind of been eying the tab s7 myself......maybe when i get my stimulus check, i'll get one.
CertPathValidatorException Accessing Site with AWS ACM cert
I'm trying to hit a web service on our site which uses an AWS issued cert. The site comes up fine with a browser on the phone but the app is getting "java.security.cert.CertPAthValidatorException: Trust anchor for certification path not found."
This code worked fine with Android 9.
Has anyone else ran into this issue? My iOS app has no problem hitting the web service only my Android java code.
Code below.
Java:
 URLConnection connection = null;
            BufferedReader reader = null;
            try {
                URL url = new URL(params[0]);
                //connection = (HttpURLConnection) url.openConnection();
                connection = url.openConnection();
                //connection.connect();
                InputStream stream = connection.getInputStream();
Google Calendar showing calendars that don't exist on my O365 account?
So, I'm baffled right now. A few months ago, I cancelled my O365 account. I decided yesterday to open it back up. It was a brand new mailbox. (It's OK because I transferred all my email and appointments to gmail and then transferred them back.) I'm trying to use the Google Calendar to view my O365 calendar. The main calendar seems to be syncing just fine. I've verified logging into OWA, the calendars are not there. But, I'm showing calendars that I had on my old O365 account that doesn't exist on the new O365 account. I've tried to delete and re-add my O365 account in android settings. I deleted the data for the Google Calendar to force it to redownload everything. It keeps pulling down these calendars that don't exist in the mailbox.
Television mood lighting
Coloured lights on the back of the TV that project onto the wall behind it. The colours are usually shown as changing to match/complementing the image on the screen (so different colours in different places around the set, changing as the image changes).
Philips, who are big on it, seem to promote it as enhancing the experience (it's usually shown with a white or pale wall behind the set in a semi-dark room, so it looks like the picture spreading out - which looks cool but, as I say, is not how my living room is arranged). There are 3rd party add-ons available, but I think Philips are the only people who integrate it with their sets.
I've seen one seller of a cheap 3rd-party add-on "mood lighting" claim it reduces eye strain, but they cited no evidence to support that claim (which means I did not take it seriously).
Help Hearing aids
My phonax, even in the most brutal conditions of snow and rain, somehow are water proof, but you have to kind of dig deep in your hearing aids, but also quickly wipe them off with a napkin out of a restraunt or even your own clothes :) But be warn though, always sit down when you are doing this :)
[Free Game] Candy Fruit Blast - Match 3 Fruit Link Puzzle
Candy Fruit Blast Game: Match 3 Fruit Link Puzzle is one of those exciting and delightful fruit match three games or matching fruits game that everyone will enjoy big time.
If you are searching for fun fruit games free, then this fruit puzzle game is something that might make you really happy!
This sweet puzzle fruit game comes with delightful gameplay and a wonderfully colored interface which will instantly catch your eyes at the first moment with delight, which will last for as long as you play. Therefore, if you want to play a colorful fruity puzzle game or a fruit super game, then the Candy Fruit Blast Game: Match 3 Fruit Link Puzzle game is perfect for you.
This candy matching or candy fruit blast game will allow you to have a lot of fun with fruit candy link matches. Candy crush fruit splash games are really fun to play, and it allows the player to relax and have a lot of fun for hours.
The Gameplay
When you enter the fruit match 3 puzzle game, you'll see fruits of different color and shapes. Match three fruits of the same kind or create a fruit line or fruit link, and see them crush with delightful visual effect and earning you points. When you crush enough fruit candies by fruit match or fruit merge, you'll get to the next level which will features new and exciting features. Keep playing this matching fruits game and earn rewards to unlock new and exciting abilities and features. If you enjoy fruit slasher or candy crush fruit splash or block puzzle fruit game, then this fruit puzzle link line game is perfect for you.
Take a look at some of the amazing features of this candy link fruit candy game has to get a clearer idea about this fruit fantasy puzzle game:
Fun and Easy:
If you are looking for fruit match three games free for android that is fun and easy to play and gives you great refreshment, then this fun fruit game is perfect for you. There's no complication in the interface, and you don't have to go through any complication to have fun with this fruit match 3 puzzle game.
Amazing Graphics:
When you play a candy fruit match three game, you kind of hope it to be amazingly colorful and refreshing, and this candy fruit crush game has a really colorful interface that will delight you at once. We have given our best effort to make the graphics in such a way that it delights everyone regardless of their age and gender.
A Fruit Puzzle Game with Many Levels:
Are you looking for a candy crush fruit splash game with unlimited levels? If so, then this candy fruit blast game features so many levels that you can enjoy it for as long as you'd like. Each level of this game has something new and exciting to offer. You'll enjoy new kind of challenges on every level and it will become fun and challenging as you continue to win levels.
For Everyone:
No matter how old are you, or what gender you are, you'll enjoy this fruit candy puzzle game very much. If you are looking for candy fruit crush games for girls or boys, or fruit puzzle for kids or adults, this fruity puzzle game will delight you big time.
Mostly Free and Totally Offline:
If you'd like to enjoy a delightful fruit merge or fruit match puzzle game for free or without internet, then this game is perfect for you. You don't have to spend any money to download this amazing fruit link puzzle game, and apart from some in-app purchase, almost all the features are totally free. Also, it requires no internet connection such as wifi or data. Therefore, you can enjoy this game anytime, anywhere without having to worry about anything. If you don't have internet of any sort, you can spend your time with utter delight if you have this game in your device.
Match 3 Fruit Link Puzzle has many amazing things that you can enjoy whenever you want, wherever you want.
Screenshot: https://imgur.com/a/ypbkYyj
Download Candy Fruit Blast Game: Match 3 Fruit Link Puzzle: https://play.google.com/store/apps/details?id=com.candy.fruit.blast.game.match3.fruit.link.puzzle
App info:
Current Version: 0.1
Requires Android: 4.4 and up
Content Rating: Rated for 3+
Filter
