Local Hotspot - Personalized and Fixed SSID
Hello everyone. I am quite new in the Apps development. I have been reading so many Q&A, forums, and post from so many people around. I have a question, and I hope someone of you could kindly give me support to clarify my doubts. I would like to enable a local hotspot on a tablet (Huawei Mediapad T5 with Android 8 - Oreo). I am developing an App with different functionalities, but I realized I need to switch between my Wireless connection and to enable my Local Hotspot (One it is already saved and configured on my tablet). And I have managed to do the switch in between the networks. The big problem comes with the SSID. If I enable manually my Local Hotspot, it connects automatically with my other device (Arduino MKR 1010), but if I do it programmatically, the Hotspot that I enable, changes every single time the SSID. Is there any way set a fixed SSID with this methodology? I read in some posts that this is already hardcoded and it is not possible to do as I wish. I hope you can help me to understand it better, clarify or to find a solution. Thank you so much in advance. I post my activity code, and the Logcat with two attempts. :-)
Java:
public class WiFi extends AppCompatActivity {
    private Button on_off_wifi;
    private Button discover_wifi;
    public TextView connectionState_tv;
    private ListView peerListView;
    WifiManager myWifiManager;
    private WifiManager.LocalOnlyHotspotReservation mReservation;
    private boolean isHotspotEnabled = false;
    private final int REQUEST_ENABLE_LOCATION_SYSTEM_SETTINGS = 101;
    public WifiP2pManager myWifiP2PManager;
    public Context context;
    WifiP2pManager.Channel myChannel;
    BroadcastReceiver myReceiver;
    IntentFilter myIntentFilter;
    List<WifiP2pDevice> peers = new ArrayList<WifiP2pDevice>();
    String[] deviceNameArray;
    WifiP2pDevice[] deviceArray;
    @Override
    protected void onCreate(@Nullable Bundle savedInstanceState) {
        setContentView(R.layout.activity_wifi);
        initialize();
        on_off_wifi.setOnClickListener(new View.OnClickListener() {
            @RequiresApi(api = Build.VERSION_CODES.O)
            @Override
            public void onClick(View v) {
                if(myWifiManager.isWifiEnabled()){
                    myWifiManager.setWifiEnabled(false);
                    on_off_wifi. setText("WiFi ON");
                    enableLocationSettings();
                }else {
                    turnOffHotspot();
                    myWifiManager.setWifiEnabled(true);
                    on_off_wifi.setText("WiFi OFF");
    private void enableLocationSettings() {
        LocationRequest mLocationRequest = new LocationRequest();
        /*mLocationRequest.setInterval(10);
        mLocationRequest.setSmallestDisplacement(10);
        mLocationRequest.setFastestInterval(10);
        mLocationRequest.setPriority(LocationRequest.PRIORITY_HIGH_ACCURACY);*/
        LocationSettingsRequest.Builder builder = new LocationSettingsRequest.Builder();
        builder.addLocationRequest(mLocationRequest)
                .setAlwaysShow(false); // Show dialog
        Task<LocationSettingsResponse> task= LocationServices.getSettingsClient(this).checkLocationSettings(builder.build());
        task.addOnCompleteListener(task1 -> {
            try {
                LocationSettingsResponse response = task1.getResult(ApiException.class);
                // All location settings are satisfied. The client can initialize location
                // requests here.
                toggleHotspot();
            } catch (ApiException exception) {
                switch (exception.getStatusCode()) {
                    case LocationSettingsStatusCodes.RESOLUTION_REQUIRED:
                        // Location settings are not satisfied. But could be fixed by showing the
                        // user a dialog.
                        try {
                            // Cast to a resolvable exception.
                            ResolvableApiException resolvable = (ResolvableApiException) exception;
                            // Show the dialog by calling startResolutionForResult(),
                            // and check the result in onActivityResult().
                            resolvable.startResolutionForResult(WiFi.this, REQUEST_ENABLE_LOCATION_SYSTEM_SETTINGS);
                        } catch (IntentSender.SendIntentException e) {
                            // Ignore the error.
                        } catch (ClassCastException e) {
                            // Ignore, should be an impossible error.
                        break;
                    case LocationSettingsStatusCodes.SETTINGS_CHANGE_UNAVAILABLE:
                        // Location settings are not satisfied. However, we have no way to fix the
                        // settings so we won't show the dialog.
                        break;
    private void toggleHotspot() {
        if(!isHotspotEnabled){
            turnOnHotspot();
        }else {
            turnOffHotspot();
    private boolean isLocationPermissionEnable() {
        if (ActivityCompat.checkSelfPermission(this, Manifest.permission.ACCESS_COARSE_LOCATION) != PackageManager.PERMISSION_GRANTED) {
            ActivityCompat.requestPermissions(this, new String[] {Manifest.permission.ACCESS_COARSE_LOCATION}, 2);
            return false;
        return true;
    private void turnOnHotspot() {
        if (!isLocationPermissionEnable()) {
            return;
        WifiManager manager = (WifiManager) getApplicationContext().getSystemService(Context.WIFI_SERVICE);
        if (manager != null) {
            // Don't start when it started (existed)
            manager.startLocalOnlyHotspot(new WifiManager.LocalOnlyHotspotCallback() {
                @Override
                public void onStarted(WifiManager.LocalOnlyHotspotReservation reservation) {
                    super.onStarted(reservation);
                    System.out.println(reservation.getWifiConfiguration() + "*****************************************************");
                    //Log.d(TAG, "Wifi Hotspot is on now");
                    mReservation = reservation;
                    isHotspotEnabled = true;
                @Override
                public void onStopped() {
                    super.onStopped();
                    //Log.d(TAG, "onStopped: ");
                @Override
                public void onFailed(int reason) {
                    super.onFailed(reason);
                    //Log.d(TAG, "onFailed: ");
            }, new Handler());
    private void turnOffHotspot() {
            return;
        if (mReservation != null) {
            mReservation.close();
    @Override
    protected void onActivityResult(int requestCode, int resultCode, Intent data) {
        super.onActivityResult(requestCode, resultCode, data);
        final LocationSettingsStates states = LocationSettingsStates.fromIntent(data);
        switch (requestCode) {
            case REQUEST_ENABLE_LOCATION_SYSTEM_SETTINGS:
                switch (resultCode) {
                    case Activity.RESULT_OK:
                        // All required changes were successfully made
                        toggleHotspot();
                        Toast.makeText(WiFi.this, states.isLocationPresent() + "", Toast.LENGTH_SHORT).show();
                        break;
                    case Activity.RESULT_CANCELED:
                        // The user was asked to change settings, but chose not to
                        Toast.makeText(WiFi.this, "Canceled", Toast.LENGTH_SHORT).show();
                        break;
                    default:
                        break;
                break;
    private void mylistener() {
            @Override
                }else {
        discover_wifi.setOnClickListener(new View.OnClickListener() {
            @Override
                myWifiP2PManager.discoverPeers(myChannel, new WifiP2pManager.ActionListener() {
                    @Override
                    public void onSuccess() {
                        connectionState_tv.setText("Discovery started");
                    @Override
                    public void onFailure(int reason) {
                        connectionState_tv.setText("Discovery starting failed");
        peerListView.setOnItemClickListener(new AdapterView.OnItemClickListener() {
            @Override
            public void onItemClick(AdapterView<?> parent, View view, int position, long id) {
                final WifiP2pDevice device = deviceArray[position];
                WifiP2pConfig config = new WifiP2pConfig();
                config.deviceAddress  = device.deviceAddress;
                myWifiP2PManager.connect(myChannel, config, new WifiP2pManager.ActionListener() {
                    @Override
                        Toast.makeText(getApplicationContext(),"Connectect to "+device.deviceName,Toast.LENGTH_SHORT).show();
                    @Override
                        Toast.makeText(getApplicationContext(),"Not connectected ",Toast.LENGTH_SHORT).show();
    private void initialize() {
        on_off_wifi = (Button) findViewById(R.id.on_off);
        discover_wifi = (Button) findViewById(R.id.discover);
        connectionState_tv = (TextView) findViewById(R.id.connectionState);
        peerListView = (ListView) findViewById(R.id.peerListView);
        myWifiManager = (WifiManager) getApplicationContext().getSystemService(Context.WIFI_SERVICE);
        myWifiP2PManager = (WifiP2pManager) getSystemService(Context.WIFI_P2P_SERVICE);
        myChannel = myWifiP2PManager.initialize(this,getMainLooper(),null);
        myReceiver = new recovics.htwk.recovics_exo_hand.WifiDirectBroadcastReceiver(myWifiP2PManager,myChannel, WiFi.this);
        myIntentFilter = new IntentFilter();
        myIntentFilter.addAction(WifiP2pManager.WIFI_P2P_STATE_CHANGED_ACTION);
        myIntentFilter.addAction(WifiP2pManager.WIFI_P2P_PEERS_CHANGED_ACTION);
        myIntentFilter.addAction(WifiP2pManager.WIFI_P2P_CONNECTION_CHANGED_ACTION);
        myIntentFilter.addAction(WifiP2pManager.WIFI_P2P_THIS_DEVICE_CHANGED_ACTION);
    WifiP2pManager.PeerListListener peerListListener = new WifiP2pManager.PeerListListener() {
        @Override
        public void onPeersAvailable(WifiP2pDeviceList peerlist) {
            if(!peerlist.getDeviceList().equals(peers)) {
                peers.clear();
                peers.addAll(peerlist.getDeviceList());
                deviceNameArray =  new String[peerlist.getDeviceList().size()];
                deviceArray = new WifiP2pDevice[peerlist.getDeviceList().size()];
                int index = 0;
                for (WifiP2pDevice device : peerlist.getDeviceList()){
                    deviceNameArray[index]=device.deviceName;
                    deviceArray[index]=device;
                    index++;
                ArrayAdapter<String> adapter = new ArrayAdapter<String>(getApplicationContext(),android.R.layout.simple_list_item_1,deviceNameArray);
                peerListView.setAdapter(adapter);
                if(peers.size()==0){
                    Toast.makeText(getApplicationContext(),"No Devices found",Toast.LENGTH_SHORT).show();
                    return;
    WifiP2pManager.ConnectionInfoListener connectionInfoListener = new WifiP2pManager.ConnectionInfoListener() {
        @Override
        public void onConnectionInfoAvailable(WifiP2pInfo info) {
            final InetAddress groupOwnerAddress = info.groupOwnerAddress;
            if(info.groupFormed && info.isGroupOwner){
                connectionState_tv.setText("host");
            }else if(info.groupFormed){
                connectionState_tv.setText("Client");
    @Override
    protected void onResume() {
        super.onResume();
        registerReceiver(myReceiver,myIntentFilter);
    @Override
    protected void onPause() {
        super.onPause();
        unregisterReceiver(myReceiver);
The Logcat looks as next:
D/WifiManager: LocalOnlyHotspotCallbackProxy: handle message what: 0 msg: { when=-2ms what=0 obj=* ID: -2 SSID: AndroidShare_6018 PROVIDER-NAME: null BSSID: null FQDN: null PRIO: 0 HIDDEN: false
NetworkSelectionStatus NETWORK_SELECTION_ENABLED
hasEverConnected: false
KeyMgmt: WPA2_PSK Protocols:
AuthAlgorithms:
PairwiseCiphers:
GroupCiphers:
PSK: *
Enterprise config:
IP config:
IP assignment: UNASSIGNED
Proxy settings: UNASSIGNED
cuid=-1 luid=-1 lcuid=0 userApproved=USER_UNSPECIFIED noInternetAccessExpected=false roamingFailureBlackListTimeMilli: 1000
target=android.net.wifi.WifiManager$LocalOnlyHotspotCallbackProxy$1 }
OR
D/WifiManager: LocalOnlyHotspotCallbackProxy: handle message what: 0 msg: { when=0 what=0 obj=* ID: -2 SSID: AndroidShare_6787 PROVIDER-NAME: null BSSID: null FQDN: null PRIO: 0 HIDDEN: false
AuthAlgorithms:
PairwiseCiphers:
GroupCiphers:
PSK: *
Enterprise config:
IP config:
Interesting Verizon Visit
I wasn't even changing providers. I was just changing my Note for the S21 Ultra. My phone was activated and I updated the device info and they confirmed it was all good on their networks through their web pages. The phone has been working flawlessly since. Everything except my recorded voice mails.. I'm paying three bucks a month to have the feature active on two of the four phones on my plan. I wanted it to work. :) They informed me today that I've had a plan with Verizon since 1981. The guy trying to help explain away the feature not working said he was born in 1991. :)
That's funny that you have a phone older than he is, these Mellinials lol
Anyone using this?
I'd like the hear from @codesplice since he's the one that turned me onto this. What are the other cool things this does.
Yeah dude, I love this launcher. It's a big departure from the typical Android launcher so I totally get that it won't work for how everyone wants their homescreen to behave - and that's fine, we've got options!
Some of my favorite features/tricks:
  • Selected media app(s) automatically jump to the top of the home screen when I connect my headphones, and slick playback controls appear when something's playing.
  • The minimal Niagara widget shows the current date and weather as well as any upcoming appointments. Tapping it expands a more detailed weather panel as well as the next few days worth of calendar events.
  • You can use swipe actions to emulate folders; a single tap on my Chat shortcuts opens chat, while swiping right on that shortcut allows me to pick one of my other messaging apps.
  • Niagara integrates with Sesame to provide ultra-fast super-powered search. Just swipe up to instantly search through contacts, apps, settings, shortcuts, playlists, web results, and more.
New app: Send SMS HANDSFREE by Voice: Unlimited message
UPDATE: Version 1.0.1
We have just released an update which:
  • Fixes the issue on voice recognition library visibility on Android 11 (for those who have experience with Android 11, this library visibility might be no stranger to them)
  • Improves the flow between searching contacts and editing message. For example, if the application is currently focusing on the message editing, and you say "Drop all contacts", the application will unselect all selected targeting contacts for you, and also switch the focus to contact autocomplete box.
  • Allows users to re-enable the tutorial. It will be useful if you forgot how the application works and want to see the showcases again.
Filter
