Apps missing and nonfunctioning, and homescreen change
yep lets call this planned obsolescence. its most likely a glitch, but expect more of this as your device gets older. you will also run into your device slowing down as well as apps will slowly stop working. its mainly because app developers will stop supporting older android versions.
Well that sucks... I'm just a simple person, but I can see it from a business stand point. I guess it's time for an upgrade.
Mi 10T Lite schedule power on issue
It's a common feature on many smartphones, called Schedule Power on /off. In Xiaomi mi 10T Lite (and Mi Max 3), located in Settings / Battery and Performance,
But even without setting power off / on times, setting the alarm and turning the phone off manually, the alarm triggers the phone to turn on just before the alarm rings - that is, it's supposed to and works perfectly, for example in my Mi Max 3
Adjusted minimum brightness, got black screen often now, why?
It is rooted with CM13, a HTC M8, and the issue is that I can't go below the minimum on the pull down notification bar. Manufacturers have set a minimum higher than the real minimum, so it's very nice to go below that when in bed with someone else, and besides I think it feels better for the eyes with less light.
So there's a workaround to edit that brightness file in /sys/
Sim jack
I spoke to my isp yesterday morning & they confirmed they didn't send the provisioning msg, so was deffinatly a sim Jack. I have done what stated above it should get them out the phone but not holding my breath lol, taking phone into store as soon as lock down finished.
Filter
