MrBeast's new "Finger on the app" app made me a little bit mad... here's how you can avoid that!
I looked up "free online sms receiver" and select a US phone number and register with that then I installed a VPN when register, however it doesn't work. Anyone lemme know if it works for you in the comments.[Kodi](https://kodi.software/) [nox](https://nox.tips/)
Use HotspotShield for android (it's free) and use this website for the phone number: https://smsreceivefree.com/country/usa
Casting couched
even if a device supports it, i have seen issues with miracast. google chromecast is so much easier to use, but it does require wifi. its all i use in my house all my tv's have a chromecast device......been thinking about upgrading to the chromecast with google tv cuz it comes with a handy remote.
android 9 blu vivo x6 gestures issue
i think this is an issue with your phone then. such is the life of getting an off branded phone. if a factory reset does not fix the issue then it is either something wrong with the manufacturer's version of the android os or its a hardware issue(which i do not think this is the case).
you will have to either learn to live with it or go to your carrier and see what they say about the issue....or get a new phone.
i'm gonna contact them and see if they are going to fix it in an update.
Just as a phone
what about jitterbug?
Lively by Jitterbug
Yep, you need to look at a feature phone that can make calls, texts and take photos/videos (and store them on a microSD card). If you don't want the smart features of a smartphone, there's zero sense in paying for it. Many carriers will give you a feature phone for a service contract of a year or so.
Get rowId after inserted Room Persistence Library
re Do the changes in player (Asign the id) inside the AsyncTask. Something like this:
[code = java] la clase privada InsertAsyncPlayer extiende AsyncTask <Player, Void, Void> {
MyDao myDao;
public InsertAsyncPlayer (MyDao dao) {
myDao = dao;
@Anular
protected Void doInBackground (Player ... players) {
long idGetted = myDao.insertPlayer (jugadores [0]);
jugadores [0] .setId (idGetted); // aquí es donde se actualiza el objeto del reproductor.
devolver nulo;
}[/código]
No more headphones?
While a lot of people would tell you to get the Bose QuietComfort II or even the NoiseCancelling NC-700 headphones, I had both... and both just got on my nerves because of the clunky controls. I switched to the Sony WH-1000xm3 and was blown away - and pre-ordered the WH-1000xm4 as soon as they were announced. That's what I'm using now, and I can recommend them with no reservation. The sound quality is amazing (although it can't be any better than your source): in fact these headphones are capable of Hi-Res Audio. The controls are simple; the noise cancellation is uncanny.
video with internal sound?
I was wondering if there's an option to keep the internal sound on while shooting a video on this phone?
On my earlier phone (Huawei) I could do that, it was fun to have an own 'soundtrack' for the videos with editing afterwards, but with this Samsung, the sound is closed immediately when I push the record on Camera-video.
Filter
