Help What's...
- Apps & Games
- 4 Replies
Yeah that's what I was wondering about. If Play hadn't took my money I could probably afforded 2 by now.
Ah, crap. 'unauthorised' is what I was originally afraid of. ADB has connected to the phone but the phone wants you to allow the connection to proceed, which requires unlocking the phone.
I realize that you posted this answers years ago, but I was seeing if you could help me with a follow up question? If so, when the GattService is running in the background even with bluetooth turned off, you mentioned that other apps can trigger it to try and pair with a monitor, etc..Something must be invoking the BT service.
Your second images shows "GattService" as the running process, and that it was "started by application". GATT (Generic Attribute Profile) is a BT specification that essentially describes how individual BT devices interoperate.
Do you, for example, have S-Health enabled? This may have invoked the BT service in an attempt to find and connect with a heart rate monitor using the HRP profile.
I don't want to be difficult, but each forum is for a specific phone in this area. The name of this specific forum is LG V40 ThinQ. There are groups for specific phones so everyone can discuss issues on their specific model. When I had an HTC10, I posted in that forum. Now that I'm using an LG V40, I'm here. Discussing problems with a different phone just causes confusion. You can get more help if you talk to people that are using the same phone. If you check the name of this specific forum, it says:
View attachment 154585 You obviously can do whatever you want. But you would get more relevant information in the forum about your phone.![]()
How do you accidentally make an international call?
I created a channel for your app. Good luck!!
https://androidforums.com/apps/japes-hd-icon-pack.18625/
What's the gain? And if it's an app you barely use you can swipe that away individually, so "clear all" is only for removing all apps, including those you do use (and hence will waste energy reloading). It's an essentially pointless feature.Why on Earth not? It's fine to use. Especially with apps I barely use.
Up until yesterday, when the clock alarm "dismiss" button appears from a locked screen, a simple tap on the button stopped the alarm, the same as it would if the device was unlocked and the "dismiss" link that appears at the top of the screen was dispatched with a single tap.
Now, I must press on the button and maintain the pressure as I swipe up to get task done. Some times it takes multiple attempts to be successful.
I had a system update yesterday, and I didn't experience the change until after the update, so perhaps it is connected to that?
