Double apps
How would i know if a work profile is on here?can having 2 emails on one phone cause this?
Is the device new?
If so, you would need to activate the work profile yourself in order for it to be active.
A quick way to see is to look in your apps list and see if key apps are repeated- Google, Chrome, Play Store- that sort of thing.
If those apps are singular, you most likely don't have a work profile activated.
Another way to see is to pull down your quick settings menu, enter the edit mode, and look to see if the work profile quick setting icon is available.
It is a toolbox, or like an old time lunch box.
Graph data on Android
hi, everyone I have a question for you all, I have a graphic sample and I need to reproduce the same graphic, but I don't know how, my question which framework or library can I use in order to obtaint the result? for doing this I will attached the sample, if someone can help me out I really appreciate your support.
Filter
