Is there any way to put a ViewPager2 inside an AlertDialog?
I'm losing my mind. Spent over 5 hours rearranging code thinking I was one step away from fixing the issue due to being able to have half the functionality with one parameter change, and the other half of the functionality with a different parameter. I WAS WRONG. NOT CLOSE. I'm hoping you guys can help me.
I'm trying to put a ViewPager2 inside of an AlertDialog that's inside of a RecyclerView. I was going back and forth between having the AlertDialog have the .xml with the ViewPager2 scrolling functionality with the save button not working to dismiss dialog, to having the .xml load, save button work, but no ViewPager2 scrolling. Here's my code for the latter:
editItem()
Code:
final AlertDialog.Builder alertDialogBuilder;
inflater = LayoutInflater.from(context);
final View contentEspressoList = inflater.inflate(R.layout.content_espresso_list, null);
//final View view = inflater.inflate(R.layout.activity_espresso_list, null);
final View editItemPageView = inflater.inflate(R.layout.edit_item_page, null);
viewPager2 = (ViewPager2) contentEspressoList.findViewById(R.id.editPager);
alertDialogBuilder = new AlertDialog.Builder(context);
//viewPager2.removeView(viewPager2.getRootView());
alertDialogBuilder.setView(editItemPageView);
final AlertDialog dialog = alertDialogBuilder.create();
viewPager2.setAdapter(new EditViewPagerAdapter(dialog.getContext()));
dialog.show();
saveButton.setOnClickListener(new View.OnClickListener()
    [USER=1021285]@override[/USER]
    public void onClick(View v)
        dialog.dismiss();
EditViewPagerAdapter.java
Code:
public class EditViewPagerAdapter extends RecyclerView.Adapter<EditViewPagerAdapter.ViewHolder>
    private String mName;
    private LayoutInflater mInflater;
    private Context ctx;
    public EditViewPagerAdapter(Context context)
        this.ctx = context;
        this.mInflater = LayoutInflater.from(context);
    public ViewHolder onCreateViewHolder(ViewGroup parent, int viewType)
        View view = mInflater.inflate(R.layout.edit_item_page, parent, false);
        return new ViewHolder(view);
Reviews Does S20 really contain 64 MP?
Well your main question was whether there was a 64MP sensor there
You'd have to ask Samsung why they made certain decisions, but the first thing to remember is that this isn't a 64MP telephoto camera: it's a 64MP wide-angle camera (almost as wide as the primary) and that the zoom comes from cropping and software interpolation (i.e. digital zooming). The difference is that the 64MP gives you a bit more scope for cropping before you start to rely heavily on software for the zoom (there is no real optical zoom on the S20(+), only on the Ultra).
So as for what's happening, I don't have one of these cameras so am just working from what I can read plus a bit of educated guesswork. But here goes:
The first thing to note is that you won't get 2MP from a 6x crop of as 12MP image, nor will you get 10MP from a 6x crop of a 64MP image. When people talk about zoom ratios they refer to the angle of view, i.e. the linear magnification, while 12/64MP refers to the area. So a 6x zoom by cropping a 12MP image would give you a 0.3 MP image (VGA resolution). So digital zoom isn't simply cropping: they crop and then they do a software interpolation to scale that back up to a higher resolution. Try taking a picture, zooming by a factor of 2 then taking another, then look at the properties of the images: you'll find that they both say they have the same number of pixels - that's using software to 'scale up' the resolution back to what you set it to. Of course you don't get extra information this way, so the real image quality is always inferior with digital zoom compared to a true optical zoom.
So my guess is that if you select '12 MP 6x zoom' it will produce a 12MP image using software zooming (about 4000x3000 pixels). Now set it to 64MP and tell it to take a 6x zoom image: what resolution does it say the image has? Does it give you a 64MP zoomed image, a 12MP one, or something inbetween (for small zoom factors)? My guess is that it will rescale to 64MP, to be consistent with what the setting said (you asked for 64MP so the camera gives you it), but I'd be curious to know whether I'm right. If it does something different then it changes what I speculate below.
Then it gets more speculative: you say that you get 30x zoom in the 12 MP setting. What resolution are the 30x zoomed images? My guess is 12MP. Now an actual 30x digital zoom would be utterly worthless: a 30x linear crop contains 1/900 of the original pixels, so scaling that up to the original resolution is going to look like crap. So my theory is that the '30x zoom 12MP' is actually using the 64MP sensor, just rescaling back to 12MP rather than to 64MP (it will still look like crap, but not as bad as doing it with the 12MP sensor would).
As I say, I don't have one of these phones to test, so I may be wrong. But my guess is that it will do something like this:
* When you select 12MP or 64MP you are not so much choosing which sensor you use but what resolution the image is.
* If you set 12MP mode and start zooming, at some point it will switch from using the 12MP sensor to using the 64MP sensor, but it will always rescale the zoomed image to 12MP. At what point it will switch I don't know (6x would be an obvious guess, given where the 64MP mode ends, but it might happen earlier - it might even happen the moment you start to zoom).
* If you set 64MP mode it will use a digital zoom up to 6x, rescaling the image to 64MP. Above that it will stop because the image quality loss is too large for it to be worth rescaling up to 64MP, and so if you want a &gt; 6x zoom you have to choose lower resolution (i.e. 12MP, even if that actually uses the 64MP sensor for part of the range).
But as I say, that's only a guess. It could even be that they just use digital zoom on the 12MP sensor all the way to 30x and the purpose of the 64MP sensor is to give higher quality zoom images, and they cut that at 6x because anything more than that is losing too much quality. But given how outlandish a 30x digital zoom is my guess is that they actually use the 64MP sensor for that then rescale to a lower resolution - at least if you asked me to implement a 30x zoom with that hardware, that is the way I'd do it.
Well detailed and think ur correct on ur statement
How tough is the glass on the S10?
I don't own this phone, but I can tell you silica sand (6-7 Mohs) and quartz (7 Mohs) are both harder than GG5 or 6, so it is possible for the sort of fine grit you come across in everyday life to scratch it. You shouldn't be paranoid, the stuff is pretty scratch-resistant, but if you want assurance that it will never pick up scratches I can't give that.
Flight mode not working, still notified by "Messages"
Here is a short video showing about what I stated above.
I have already activated the System Tuner UI, so my toast message is different.
I made a couple errors, but I think you can see how to find what I was talking about.
I also included a bit about the Priority Only / Do Not Disturb function.
I think that the combination of these settings should help keep your device from driving you nuts all night.
At least it did for me.
I actually leave my device in Priority Only/Do Not Disturb mode all the time, as I have allowed only the apps that I want notifications from in the ways that I have mentioned.
https://cloud.degoo.com/share/qGIHtmiXiF1G85
Notebook to android to projector?
I knoww that NitroShare can transfer the files.
https://f-droid.org/en/packages/net.nitroshare.android/
What I don't know how to accomplish is the ability to control other devices with your phone.
It probably is possible, somehow, with certain devices, but it is more simple if you remove 'the middlemen'- just like everything else.
If you had the files on the phone, and sent them directly to the projector, then the phone is already in control.
Casting apps should be able to accomplish this.
NitroShare will easilly transfer files back and forth from these sevices (I use it all the time).
A casting app that may work for you...
PlainUPnP (Stream images, video, music to your Smart TV, Android TV and UPnP / DLNA player) - https://f-droid.org/packages/com.m3sv.plainupnp
whole lot of shaking going on!!!!!
Hey @ocnbrze and other Californians, I just got this alert:
It's a good time to remind you about, or introduce you to, the MyShake app. If you don't already have it installed, now's as good a time as any! :)
I do not have it installed on my note 10+.....on my note 8 i did. i did smart switch and thought it got transferred over and just forgot about it, but it is not there....weird. i'm gonna install it right now.
Camera app issues/advice
Hi,
I just bought a Xaomi Mi Note 10, mainly because I wanted a better camera, and the camera set-up gets good reviews. But I'm having a couple of issues. Things that were better on my older Moto G6 (which was half the price).
Selfies - depth of field.
When I take a selfie my face is sharp and detailed but anyone behind me - a metre or more away is totally blurred out. This is terrible for group selfies, especially when everyone is a bit distanced ( which is always the case now :( ). Is there anything I can do about this, or is it just a problem with the hardware (lens)? It was much less of an issue on the Moto.
I've not had the rear "selfie" camera do anything like that on phones I've had. Is it like a bokeh effect, where the background is really out of focus and blurry, or is just slightly out of focus? It could be an effect that's been applied by the Xiaomi camera app the Mi uses? I know some manufacturer camera apps automatically apply a beauty effect to selfie pics, that's ON by default.
Suggest you post a sample pic, so we might have a better idea of the issue. Also try another camera app?
Filter
